- Configuring LinuxCNC
- Basic Configuration
- First Analog Build - 7i97 - Anilam - Issue enabling machine
- bnet
- Thank you received: 5
17 Jan 2026 15:50 #341499
by bnet
First Analog Build - 7i97 - Anilam - Issue enabling machine was created by bnet
I am working on integrating my first analog servo build. 7i97 and Anilam drives. I am following the steps
here
. I have the encoder scaling correct but when I go to enable the machine, there is a brief moment of runaway before I get two errors:
"joint 1 following error"
"could not switch the machine on. is limit switch activated?"
I am only working on joint 1 at the moment.
No limit switches are in use at the moment.
I have tried inverting 'output scaling' and 'encoder scaling' in every possible combination on the configuration page.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
- Thank you received: 7502
17 Jan 2026 20:17 #341519
Replied by tommylight on topic First Analog Build - 7i97 - Anilam - Issue enabling machine
Those are two separate issues, first is always (granted wiring is OK) hal/settings issue, the second is a limit switch triggered or inverted issue.
For the first, some checks:
-disconnect one of the analog output wires from mesa, power on the machine and enable shortly = the motor should very slowly turn. Be aware that if wiring is not OK the machine might run away at full speed
-reconnect the wires
-use a DVM set in beep or resistance mode and check between analog ground on the drive and machine ground = there should not be low resistance, usually. machine should be powered off.
-use the DVM and measure the analog output voltage on Mesa or on the drive while LinuxCNC is disabled but the machine is powered on and LinuxCNC is running = there should be no voltage
-use the calibration screen to invert the output, or encoder, but NEVER both, test by enabling the machine
-if you still get joint errors, lover the P value to 10 or 5 or 2 and test.
The following user(s) said Thank You: bnet
- Thank you received: 5336
17 Jan 2026 20:32 #341521
Replied by PCW on topic First Analog Build - 7i97 - Anilam - Issue enabling machine
You MUST set the 7I97 PWMgens offset mode to true or runaways are guaranteed.
- bnet
22 Jan 2026 12:29 #341714
by bnet
For those who run into this in the future, I needed to add to each axis definition in the .hal:
Where "xx" = joint number.
Now the machine is stable and jogging smooth and silently. Beauty.
Replied by bnet on topic First Analog Build - 7i97 - Anilam - Issue enabling machine
Yep, that fixed everything! Thanks a million!You MUST set the 7I97 PWMgens offset mode to true or runaways are guaranteed.
setp hm2_7i97.0.pwmgen.xx.offset-mode trueWhere "xx" = joint number.
Time to create page: 0.094 seconds
