Cannot JOG Plus/Minus move in TeleOp mode
- tar_san
06 Feb 2026 08:50 #342537
by tar_san
Cannot JOG Plus/Minus move in TeleOp mode was created by tar_san
I'm trying to configure an existing LinuxCNC machine (simple XYZ) in manual mode using physical mechanical switches for axis selection and Jog Plus/Jog Minus.
It works in joint mode.
But it doesn't seem to work in TeleOp mode.
I operated same things from using HAL Pin manually without wireing configuration, but I got the same result.
What I did using HAL Pin (in TeleOp mode) was..
1) confirm manual mode in LCNC. (all axis homed )
2) Turn on/off some pins in Show Hal configuration (N=axis char)
halui.axis.jog-speed ( set to 500 )
halui.axis.N.selected
halui.axis.N.is-selected
halui.axis.N.plus/minus
I tried another method using halui.axis.selected.plus/minus, but same.
Should I use another pins?
What am I missing ?
Which pin should I check ?
Could you guys help me solve this problem, please ?
What am I missing ?
08 Feb 2026 18:46 #342664
Replied by andypugh on topic Cannot JOG Plus/Minus move in TeleOp mode
Which GUI are you using? I seem to recall that Axis needs to be on the manual tab for jogging to work.
Can you share your HAL file?
The following user(s) said Thank You: tar_san
- tar_san
14 Feb 2026 10:03 #342931
by tar_san
Replied by tar_san on topic Cannot JOG Plus/Minus move in TeleOp mode
Thanks !
I was using LinuxCNC Ver 2.4.5 at that time.
But Today, after I just upgraded to Ver 2.4.8, everything works well.
26 Feb 2026 13:05 #343531
Do you mean 2.4.8 or 2.8.4 ?
(2.4.8 was released around 15 years ago)
- tar_san
28 Feb 2026 00:32 #343627
by tar_san
Sorry. Let me fix, I used 2.9.5 and 2.9.8.
I'm sure 2.9.5 have some bugs for jogs.
Time to create page: 0.082 seconds
