Strange Gantry Squaring/Homing
8 months 2 weeks ago #343111 by Clark222
Hi - I've gotten Linuxcnc to work well on several machines but each time the machine wasn't constructed with enough precision to make it reliably work the way I wanted.  On this machine I finally built it the way I should have.  I used the files from my old machine and adapted them to this machine If something is commented out it is because I haven't got to that yet.  The machine moves great and the X and Z axis move and home really good.  The Y axis moves good but I can't get it to home properly. If things are set up so that each axis has a pnp sensor on side will respond to the sensor but the other side will turn off the led acknowledging it should home but it keeps moving towards the sensor.  If I tie both sides to a single side it works as expected.  This is fine but it prevents squaring.  I've included my files so maybe somebody could see where I've gone wrong.
8 months 2 weeks ago - 8 months 2 weeks ago #343115 by PCW
Replied by PCW on topic Strange Gantry Squaring/Homing
Both joints of a gantry need negative home sequence numbers,
but your ini file has a negative and a positive:
[JOINT_1]
HOME_SEQUENCE = -3
[JOINT_2]
HOME_SEQUENCE = 3
Last edit: 8 months 2 weeks ago by PCW.
8 months 2 weeks ago #343116 by Clark222
Thank you for getting back to me. That had already been changed in the original file but I forgot to change it in what I posted online. It still has the same problem. Currently it is on joint 2. The constant homing issue has left the gantry a little out of square. It seems like whichever side is closer at the start has the problem
8 months 2 weeks ago #343119 by PCW
You  might do a halscope plot of both limit switches and both joint positions
when homed to get a better idea of whats going on.
8 months 2 weeks ago #343120 by rodw
Replied by rodw on topic Strange Gantry Squaring/Homing
To square add HOME_OFFSET to your ini. If you are 2mm out of square, the difference in this value needs to be 2mm
8 months 2 weeks ago #343125 by Clark222
Thank you for the tip about using offset to square it up. I was never really sure what it was used for. One of the things I added to this machine was adjustability. I'm sure glad that I did. I worked on it a bit getting it back to square and it's now within .5mm. I'll use the offset to get it the rest of the way. I would like to get auto square working. I've confirmed the inputs and the state of homing using halshow. I've never used halscope before. Do I set it up like halshow? What should I be looking for? Thanks both of you for the help!
Time to create page: 0.275 seconds
