Inaccurate milling - what could it be?
14 Mar 2026 23:30 #344283 by vetsin
I went to make what should have been a 29.534mm hex bolt, however it came out very off spec. I've no real idea why.  I did go through the process of checking backlash and ensuring my velocity was alright a long time ago -- but honestly it's been a very slow project and I forget what I did. Any ideas what the reason for the problem could be? What should I check first?
15 Mar 2026 00:16 #344284 by tommylight
Replied by tommylight on topic Inaccurate milling - what could it be?
Upload the pictures here on the forum, not on third party websites, way to many scripts running on those websites.
The following user(s) said Thank You: dbtayl
15 Mar 2026 15:12 #344316 by dbtayl
Replied by dbtayl on topic Inaccurate milling - what could it be?
You might also want to mention what tools/holders, speeds, and feeds you're using, as well as how far off the dimensions are.
That said, my first reaction to the above is deflection- the gouge looks like where the tool ended the cut, possibly dwelled there a bit before/during retract, giving it more time to cut. If it is deflection, there's a good chance you'll feel ridges if you run a fingernail along the floor of the machined surface perpendicular to the direction of cut.
Adding a finishing cut might be all you need- I generally leave 0.1~0.2mm of stock during roughing operations for the finishing cut(s).
Generally increasing rigidity should help as well (shorter tools/toolholders/stickout, bigger tools, better worktholding, working closer to the table), but I've always thought the columns on benchtop mills look too small, so you may be limited in options if that's the root cause. The good news is that so long as it cuts OK, taking a light finish cut should still get you on dimension.
The following user(s) said Thank You: timo
16 Mar 2026 03:25 #344342 by timo
Replied by timo on topic Inaccurate milling - what could it be?
The question is how far are you off dimension?
Are we talking about 0.005 mm? Or mor like 0.2 mm? :-)
On the video it looks like your endmill sticks out "far too" long.
You probably can put it further up into the holder.
Follow suggestions of #344316, finish pass.
14 May 2026 07:57 #346391 by winterkills
Replied by winterkills on topic Inaccurate milling - what could it be?
As someone else said that gouge at the end is from the retract (when the endmill was coming up). Usually you'd want to add a line to move the endmill off the part before coming up. Not being the right size isn't a big issue as long as there is no taper. Can you measure the hex across the flats at the top and at the bottom of the part? How far out is it? Could it be the endmill is not the size you thought it was or that in whatever software you used you left material for a finishing pass?
Time to create page: 0.099 seconds
