Leave enabled pin active when leaving linuxcnc
26 Mar 2026 06:29 #344764 by mooser
I've got a SSR in the latching loop of my spindle contactor being controlled by one of the outputs from the 7i76
net machine-is-enabled hm2_5i25.0.7i76.0.0.output-07
Short of re-wiring, is there a way to temporarily leave that output turned ON when linuxcnc is being closed and re-started to pick up new config changes as I mess around inside the HAL and ini files setting up my new VFD and gear selection code? I can't help but think having the 220v power ripped out from the vfd over and over again isn't doing it any good :)
M
26 Mar 2026 06:58 #344766 by rodw
you could try a shutdown.hal file that setp's it to what you want. You may have to unlink the pin as well
26 Mar 2026 08:11 #344772 by tommylight
Replied by tommylight on topic Leave enabled pin active when leaving linuxcnc
Hmmmm why are you switching the VFD power?
That should be done only on E-stop, normally use the VFD ON pin to enable and disable VFD.
Also, not sure but i think Mesa will reset all it's pins when connection is lost or LinuxCNC is closed, but this should be verified.
26 Mar 2026 09:16 #344773 by PCW
Yes, all 7I76 output pins will be forced off when communication stops.
26 Mar 2026 10:14 #344777 by mooser
I wired it so that if the control was closed or the e-stops tripped, it would cut power to the axis drives and spindle vfd. The enable button on the screen does as you say.
until now I've not really wanted the vfd powered without the control software running so it wasn't an issue
26 Mar 2026 10:18 #344778 by mooser
That's what I kind of figured. I'll have to run a temp bypass on the SSR for now and also re-think how it's wired to keep the vfd on without the control program running. The old vfd was analog so this never came up before
M
26 Mar 2026 10:30 #344780 by tommylight
That is why the e-stop is used, no power till LinuxCNC is running and out of e-stop.
26 Mar 2026 16:32 #344802 by mooser
And that's why it keeps turning off the 220v going to the vfd when I close linuxcnc to pickup the new settings I'm working on in the HAL and ini. For me it's a lot of brute-force and ignorance working in there sometimes and trial & error to get things working. (And a whole lot of help from you guys, thank goodness)
I'll hot-wire the SSR to keep the vfd from having to reboot every few minutes until I get this somewhat sorted out. I think I've at least figured out what's causing my gear function, that'll be the next series of questions lol
Thanks again
M
Time to create page: 0.246 seconds
