I can't reverse the spindle rotation.
- Ismacr63
- Thank you received: 11
25 Jun 2026 17:30 #347331
by Ismacr63
Tomorrow I’ll check the resistance at the output. It’s all very strange because I have two brand-new modules, and they behave the same way.
They always worked perfectly on a parallel port, but I no longer have the PC with a parallel port to test them again...
Replied by Ismacr63 on topic I can't reverse the spindle rotation.
I checked for continuity between the V output and GND using a multimeter, and even though the LED is lit, there is no continuity.I would check the output of the direction control PC817 with a voltmeter/ohmmeter
- Thank you received: 7504
25 Jun 2026 17:36 - 25 Jun 2026 17:44 #347332
Replied by tommylight on topic I can't reverse the spindle rotation.
Deleted as i missed the part about level shifting.
Sorry.
Sorry.
Last edit: 25 Jun 2026 17:44 by tommylight.
- Thank you received: 5336
25 Jun 2026 17:41 - 25 Jun 2026 17:42 #347333
Replied by PCW on topic I can't reverse the spindle rotation.
The Isolator is doing 5V to 24V translation so unless the BOB has a relay/24V output
it cannot go directly to the VFD
Sounds like maybe grounding issue (or damaged OPTO)
Note that a parallel port ground is nearly always frame ground
but the 7I92 ground may be floating
Last edit: 25 Jun 2026 17:42 by PCW.
25 Jun 2026 17:46 #347334
Sorry, i missed 5V/24V thing above.
I edited the above posts.
The following user(s) said Thank You: Ismacr63
25 Jun 2026 17:49 #347335
Now the question becomes:
will the servo drive work with 5V on the inputs?
Did you check the manual?
Older drives do not, but all new-ish ones do.
Now i wonder if i missed how old is your drive!
- Ismacr63
25 Jun 2026 18:05 #347336
by Ismacr63
The servomotor uses the ECAC XP200 driver, and according to the manual, the digital inputs can only be controlled with 24V.
I also have the ground for the 7i92 tied to the common ground.
- Ismacr63
26 Jun 2026 16:18 #347354
by Ismacr63
Alright, bit of progress. I did some testing and managed to get the PC817 module working — at least for now.
The module has a 302Ω resistor on both the input and output side. When the LED turned on, the output voltage only dropped to about 21V, so the servo driver wasn't seeing it as a proper low signal.
I tried putting another resistor in parallel with the one already on the output side, and bingo — reverse works. With a 3k resistor in parallel, the output drops to around 14V. With a 1.5k, it drops to about 10V. Both values make the servo reverse properly.
So my question now is, what's a safe resistor value to leave in there permanently? I don't want to damage anything, but I need it to work reliably. What would you guys recommend?
26 Jun 2026 17:23 - 26 Jun 2026 17:27 #347356
Honestly it sounds like you should be using a Darlington OPTO in place
of the low CTR PC817, say a LTV-815 or similar.
( PC817 mas a minimum CTR of 50% vs the LTV-815's 600% minimum )
Last edit: 26 Jun 2026 17:27 by PCW. Reason: wrong PN
The following user(s) said Thank You: tommylight, Ismacr63
Time to create page: 0.260 seconds
