I can't reverse the spindle rotation.
4 months 1 week ago #347327 by Ismacr63
ok this is driving me crazy. today i fired up the machine, turned on the spindle, hit reverse... and it worked. first time since swapping to the 7i92.
i thought maybe the gremlins had left, so i shut down the machine, powered it back up again, tried reverse — nothing. spindle just keeps going forward. led on the module still lights up, wiring is solid and untouched. literally didn't touch a single wire between the time it worked and the time it stopped.
any clue what could cause this?
4 months 6 days ago - 4 months 6 days ago #347328 by tommylight
Deleted as i missed the 5V to 24V level shifting mentioned above.
Last edit: 4 months 6 days ago by tommylight.
4 months 6 days ago #347329 by Ismacr63
What do you recommend I use instead?
4 months 6 days ago #347330 by PCW
I would check the output of the direction control PC817 with a voltmeter/ohmmeter
4 months 6 days ago #347331 by Ismacr63
I checked for continuity between the V output and GND using a multimeter, and even though the LED is lit, there is no continuity.
Tomorrow I’ll check the resistance at the output. It’s all very strange because I have two brand-new modules, and they behave the same way.
They always worked perfectly on a parallel port, but I no longer have the PC with a parallel port to test them again...
4 months 6 days ago - 4 months 6 days ago #347332 by tommylight
Deleted as i missed the part about level shifting.
Sorry.
Time to create page: 0.230 seconds
