Breakout Board Speed Control
- Logthor
- Thank you received: 5
- tuxcnc
- Thank you received: 52
Yes, this is a very similar circuit to the one used in BOB and will work identically.this would work, right?
The difference is that the power supply for this circuit should be not used for anything else, that BOB does not provide.
Voltage is a potential difference and is measured between two points.
The same wire, it may be 12V to the second pole of the power supply, but hundreds of volts to machine chassis.
- Logthor
- tuxcnc
If a device is not isolated from the power grid, it may cause fatal shock, damage to the electronics or its incorrect operation.So I need a separate power supply for this converter?
What's worse, it all depends on which wire you connect where.
The machine can operate safely and without failure for years, and when connected to another wall socket, it may burn itself or kill the operator.
To prevent this from happening, all you need to do is spend a few dollars more on an already expensive machine.
I really don't know what to discuss here...
- Logthor
- Logthor
- tuxcnc
For electric current to flow, two conditions must be met - there must be a potential difference (voltage) and a closed circuit. Until you close the circuit (e.g. by touching the controller and some ground with your body at the same time) you will not be aware that there is dangerous voltage there. Current may flow, for example, from the controller terminal's power grid, through the controller input to the 0-10V board, from there to the 12V power supply, through the power supply to the homing limit switch, through the limit switch and your body to the housing of the device grounded to the other pole of the power grid. Believe me, there will be voltage and a closed circuit...I am doing this like I said, but I am still quite confused on how this could pose a shock hazard. It doesn't matter if the e-stop, homing switches, etc. are connected to the spindle control circuit if it is optically isolated between the KBIC and break out board. I just don't see how buying a separate supply and separate PWM to 0-10V analog unit is going to make it any safer.
- Logthor
Yes, but there is an optocoupler between the KBIC and BoB I'm not sure where the danger is. Assuming that the optocoupler is functioning as it should mains shouldn't even reach the BoB.Current may flow, for example, from the controller terminal's power grid, through the controller input to the 0-10V board, from there to the 12V power supply, through the power supply to the homing limit switch, through the limit switch and your body to the housing of the device grounded to the other pole of the power grid. Believe me, there will be voltage and a closed circuit...
- Logthor
