- Other Stuff
- Off Topic and Test Posts
- Writting a PP w/ATC PP will not post plunge feed rate after toolchange
- allenwg2005
- Topic Author
- Thank you received: 4
16 Mar 2019 22:19 #128778
by allenwg2005
Writing PP for Vetric Aspire CAD/CAM software.
I was just running this test file for my PP and noticed something I can't explain or change, no mention of it in the Vetric manual either.
You will note there is a plunge rate on G01 under "Outside Profile", under "Inside Profile" and "Line" the G01 has no plunge rate.
How do I get those plunge rates to load when I post the file?
Thanks in advance.
(Vectric post test file File created: Saturday March 16 2019 - 02:27 PM)
G17 G20 G90 G40 G49 G64 P0.001
(Outside Profile)
T1 M06 (T1 End Mill 0.25 inch)
G43 H1
M03 S12000
G54 (Coordinate System)
G0 Z0.5000X1.0364Y3.3945
G0 Z0.2000
G01 Z-0.2500 F10.0000 G4 P0.5
G2X0.4114Y4.0195I0.0000J0.6250F52.2500
G2X1.0364Y4.6445I0.6250J0.0000
G2X1.6614Y4.0195I0.0000J-0.6250
G2X1.0364Y3.3945I-0.6250J0.0000
G0 Z0.5000
(Inside Profile)
M6 T21 (T21 End Mill 0.125 inch)
G43 H21
S12000 M03
G0 Z0.5000X3.3272Y1.3472
G0 Z0.2000
G01 Z-0.2500 G4 P0.5
G2X3.7647Y1.7847I0.4375J0.0000F52.0000
G2X4.2022Y1.3472I0.0000J-0.4375
G2X3.7647Y0.9097I-0.4375J0.0000
G2X3.3272Y1.3472I0.0000J0.4375
G0 Z0.5000
(Line)
M6 T1 (T1 End Mill 0.25 inch)
G43 H1
S12000 M03
G0 Z0.5000X1.4093Y2.6212
G0 Z0.2000
G1X3.9449F52.2500
G0 Z0.5000
G0Z0.5010
G0X1.0000Y1.0000
M2
Thanks in advance.
(Outside Profile)
G43 H1
M03 S12000
G0 Z0.2000
G0 Z0.5000
(Inside Profile)
G43 H21
S12000 M03
G0 Z0.2000
G0 Z0.5000
(Line)
G43 H1
S12000 M03
G0 Z0.2000
G1X3.9449F52.2500
G0 Z0.5000
G0Z0.5010
G0X1.0000Y1.0000
M2
16 Mar 2019 22:58 #128779
by FariaAl
Replied by FariaAl on topic Writting a PP w/ATC PP will not post plunge feed rate after toolchange
Do you have this in your Vectric PP?
+ Commands output for PLUNGE Moves
begin PLUNGE_MOVE
"G01 [Z] [F]"
begin PLUNGE_MOVE
"G01 [Z] [F]"
- allenwg2005
- Topic Author
17 Mar 2019 01:23 #128792
by allenwg2005
Replied by allenwg2005 on topic Writting a PP w/ATC PP will not post plunge feed rate after toolchange
Here's what I have:
+ Commands output for First_PLUNGE Moves
begin FIRST_PLUNGE_MOVE
"G01 [Z] [FP] G4 P0.5"
begin PLUNGE_MOVE
"G01 [Z] [FP]"
begin PLUNGE_MOVE
"G01 [Z] [FP]"
17 Mar 2019 02:48 #128796
by FariaAl
What is the "P" after the "F" for?
I tried with a "P" as you have and it did not work, but it did without it.
Try removing it..
Try removing it..
17 Mar 2019 12:33 - 17 Mar 2019 12:46 #128814
by bevins
That's F for Feed P for plunge.
I dont know why he is using that as it is for the Shark CNC. Doesnt need it. The default linuxCNC PP works just fine with Linuxcnc, at least in Aspire. I just added the ToolChange to mine and it works fine.
I would think LinuxCNC interpreter would not like it and spit at you or just ignore it.
Replied by bevins on topic Writting a PP w/ATC PP will not post plunge feed rate after toolchange
Try removing it..
Last edit: 17 Mar 2019 12:46 by bevins.
- allenwg2005
- Topic Author
17 Mar 2019 14:58 #128824
by allenwg2005
Interesting, let me share results both ways.
In the truncated file "Vetric post test" below I used the var commands in the PP for plunge, the first G01 move is at the "Plunge" rate in the tool library, and only the first G01 move has it, any G01 moves under it are at the "Feed" rate in the tool library.
In the file "Vetric post test file" I removed all the plunge commands in the PP, the result is without the plunge commands in the PP G01 moves are all at the "Feed rate".
Any ideas or thoughts?
(Vetric post test File created: Sunday March 17 2019 - 07:21 AM)
(Outside Profile)
G43 H1
M03 S12000
G0 Z0.2000
(Vetric post test file File created: Sunday March 17 2019 - 07:17 AM)
(Outside Profile)
G43 H1
M03 S12000
G0 Z0.2000
G1Z-0.2500F52.2500
(Outside Profile)
G43 H1
M03 S12000
G0 Z0.2000
(Outside Profile)
G43 H1
M03 S12000
G0 Z0.2000
G1Z-0.2500F52.2500
17 Mar 2019 15:27 #128826
by bevins
What are you trying to do? Editing the post ok, but for what?
Aspire comes with Post processors that work perfectly for linuxcnc.
17 Mar 2019 15:34 #128828
by Leon82
Replied by Leon82 on topic Writting a PP w/ATC PP will not post plunge feed rate after toolchange
Is there a way to force output?
For example in mastercam adding a * in front of the string will force the output
- allenwg2005
- Topic Author
17 Mar 2019 15:36 #128830
by allenwg2005
You bet, the standard post in Vetric works fine for paths without toolcahnge in them, you run them one at a time and have to remeasure
the tool each time you change it.
I decided to do a PP with ATC so LCNC could use the tool table G43 H[T] to load tools as the file progresses.
That all works, I just need to get the G01 calls to work with the "Pluge " rate in the library.
- allenwg2005
- Topic Author
17 Mar 2019 16:01 #128833
by allenwg2005
I should add, when you look at the PP in Vetric there are no VAR's for the plunge call to happen, but it's in each ngc file where it's needed. (One tool at a time).
Adding ATC seems to have changed this and the only way I could find to add plunge was the VAR's I shared above, the only problem is it just adds it once.
And thanks for all your help folks, I appreciated it.
- Other Stuff
Time to create page: 0.624 seconds
