- Other Stuff
- Off Topic and Test Posts
- Writting a PP w/ATC PP will not post plunge feed rate after toolchange
17 Mar 2019 16:06 #128834
by Leon82
Replied by Leon82 on topic Writting a PP w/ATC PP will not post plunge feed rate after toolchange
There's probably a switch or variable somewhere which decides this.
If it's anything like a mastercam post it may be in the top area
17 Mar 2019 16:18 #128835
by bevins
I changed a few lines in my post and it works perfectly with linuxuxcnc. Toolchange and all.
Replied by bevins on topic Writting a PP w/ATC PP will not post plunge feed rate after toolchange
I should add, when you look at the PP in Vetric there are no VAR's for the plunge call to happen, but it's in each ngc file where it's needed. (One tool at a time).
Adding ATC seems to have changed this and the only way I could find to add plunge was the VAR's I shared above, the only problem is it just adds it once.
And thanks for all your help folks, I appreciated it.
- allenwg2005
- Topic Author
- Thank you received: 4
17 Mar 2019 17:00 #128836
by allenwg2005
Replied by allenwg2005 on topic Writting a PP w/ATC PP will not post plunge feed rate after toolchange
bevins, it certainly dose work!!
I do see one thing that I have a question on.
Under each toolchange your PP generates a G43H[T], but there is no mention of H[T] under the first tool.
How dose the machine know the correct offset for the first tool?
This must work, you use it, I'm just curious.
Leon82, thanks for your suggestions as well.
17 Mar 2019 17:23 #128837
by bevins
The las TxM6, which is the current...lol
You could remove All the HT and just use G43. Thats what I do. I created a custom one for my machine and just use G43 everywhere.
- allenwg2005
- Topic Author
17 Mar 2019 19:12 #128846
by allenwg2005
I wondered if it was that simple, makes sense.
I must admit seeing HT gives me piece of mind as I glance at the code, but as you say, G43 gets it done.
Thanks again for all the help.
Wish we worked closer to each other, I would enjoy a FTF with you from time to time. Vetric seems to be the best I can find to work with .STL's.
- Other Stuff
Time to create page: 0.152 seconds
