Universal dividing head with absolute encoder
- Dinuka_Shehan
- Thank you received: 26
30 Oct 2019 03:52 - 30 Oct 2019 04:02 #149136
by Dinuka_Shehan
Universal dividing head with absolute encoder was created by Dinuka_Shehan
I recently watched YouTube on dividing head with stepper motors and non of them used encoder to calculate exact position.
4th axis not mentioned here.I just want to make universal dividing head work with ordinary /manual universal milling machine.
It helps to increase efficiency,time saving and reduce errors while indexing.
I am like to make an dividing head running with absolute encoder to rotate divisions or angles with exact location with aid of linux cnc.
Any ideas or previous projects according to this topic?
By
DS
By
DS
Last edit: 30 Oct 2019 04:02 by Dinuka_Shehan.
- pl7i92
- Thank you received: 359
30 Oct 2019 07:20 #149158
by pl7i92
Replied by pl7i92 on topic Universal dividing head with absolute encoder
you can do a Hybrid stepper and connect the system to the encoder input
the PID will correct the encoder system
but a universel divider got most alot of space it is comen to drive only one direction
and on backwards to edit postprocessor to move over 5deg and then go forward to work
- Dinuka_Shehan
30 Oct 2019 08:55 #149170
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Universal dividing head with absolute encoder
I want to add the encoder to the spindle not to the motor
- Leon82
- Thank you received: 79
30 Oct 2019 11:16 #149184
by Leon82
Replied by Leon82 on topic Universal dividing head with absolute encoder
You can make a bracket and put a toothed pulley on the indexer shaft and another on the encoder. But on a motor would seem to be the best option as there is no error with a belt setup
- Dinuka_Shehan
30 Oct 2019 11:35 - 30 Oct 2019 11:38 #149186
by Dinuka_Shehan
My plan is stepper motor mount with bracket to index crank to worm drive at 40:1 and absolute encoder with toothed pulley 1:1 to back side of spindle.
My idea is when i divide to parts encoder can precisely index to required parts and if there can backlash or lose of steps but encoder can retract to the correct location.
By
DS
But if there a error how can i compensate it.But on a motor would seem to be the best option as there is no error with a belt setup
By
DS
Last edit: 30 Oct 2019 11:38 by Dinuka_Shehan.
- Leon82
30 Oct 2019 11:37 #149187
by Leon82
It's probably not that much of an error as industrial lathes have belt driven encoders
- Dinuka_Shehan
30 Oct 2019 11:48 #149190
by Dinuka_Shehan
No I mentioned here that,
Worm gear have play when CW to CCW vice versa.
I want to calculate current position with encoder.
- Leon82
30 Oct 2019 19:30 #149243
by Leon82
I understand now, it seems like fabricating a bracket to hold the encoder and a cog belt would work.
01 Nov 2019 09:02 #149362
Replied by andypugh on topic Universal dividing head with absolute encoder
You need a very high-count encoder for it to be useful if directly connected.
(Heidenhain ERA for example)
- Dinuka_Shehan
01 Nov 2019 11:53 #149374
by Dinuka_Shehan
1 to 1 timing pulleys will also.give same results is not it?
Time to create page: 0.111 seconds
