ATC spindle with iso30/bt30 or hsk63f
05 Jun 2020 12:05 #170246 by andypugh
Replied by andypugh on topic ATC spindle with iso30/bt30 or hsk63f
One advantage of BT30 is that it is easy to make your own tooling.
But given that that is the only advantage that I can think of, HSK is probably the way to go.
I have BT30 on my milling machine, and like it, but I am not commercial so DIY tooling and cheap second-hand tooling is an advantage to me irrelevant to you.
This chap uses HSK on his lathe (both on the machine spindle _and_ the toolpost) because it is very repeatable.
The following user(s) said Thank You: johnmc1
05 Jun 2020 23:00 #170296 by Marcodi
Replied by Marcodi on topic ATC spindle with iso30/bt30 or hsk63f
What do you mean with making your own tooling?
05 Jun 2020 23:23 #170298 by andypugh
Just that. I recently made a 1.25" horizontal arbor for my mill with a 30INT shank.
I have also made sockets to mount the BT30 holders in my lathe and milling machine 4th axis for holding small work.
And made shanks to hold my probe.
It's not important for many users, but you can make BT / INT tooling with just a lathe.
[1] I have a universal mill with horizontal and vertical spindles. The vertical spindle uses either BT30 or SK30-with-the-wrong-pull-stud but the horizontal is still 30INT as originally supplied. I made a BT30 pneumatic drawbar for the vertical spindle, but did not convert the
05 Jun 2020 23:35 #170300 by Marcodi
Interesting. Cool to make your own tooling.
I am still trying to find the necessary money to buy the HSK spindle. The toolholders are also more expensive so the while thing comes out 2000 USD higher than the bt30. I don't know if I can, but as most say the HSK is most future proof and specifically made for high speed spindles.
05 Jun 2020 23:41 #170301 by andypugh
If it's hard, then the question has to be whether HSK is better _enough_ to be worth the extra. It's certainly objectively a bit better, but is that improvement enough to make it worth the expense _now_? BT30 works, after all. They wouldn't even make the spindles if it was a terrible idea.
06 Jun 2020 00:02 #170302 by Marcodi
That's true, that is what I am trying to outweigh.
But bt30 toolholders are more difficult to come by in Belgium , certainly the ones that are 30000rpm balanced. So in that case I would be better of with ISO30, this I can have delivered any day within 24 hours. (HSK is also readily available)
But as many said bt30 or ISO30 seem to be quite the same in performance and torque power.
06 Jun 2020 00:13 #170303 by andypugh
ISO30 seems to be BT30 with a different pull stud?
SK30 is a (German?) variant of BT30. It adds a notch to the holder and makes one dog shorter.
All the "30" tapers are identical in the taper. 7/24 taper and common large-end diameter.
The differences are in the drawbar / pull stud and the drive dogs.
  • kris321
  • kris321's Avatar
  • Visitor
  • Visitor
01 Sep 2020 10:38 #180298 by kris321
Replied by kris321 on topic ATC spindle with iso30/bt30 or hsk63f
the price with encoder and vfd is 2500 USD.
  • Moderator
  • Moderator
01 Sep 2020 10:43 #180302 by tommylight
Replied by tommylight on topic ATC spindle with iso30/bt30 or hsk63f
For what? Any pictures or links ?
Time to create page: 0.247 seconds
