New CNC Mill, Expert LinuxCNC person wanted for new VMC Project.
7 years 7 months ago #127790 by pl7i92
Around here some People Mashine Builders sold there Nearly comparable mashinings at around 30k Euros
with 12 ATC
7 years 7 months ago #127902 by KoenigCNC
Hi what size machine are they putting together. My machine is 40x40x30 Inches
20HP 24 tool side mount machine weight approx 11,000 lbs. Its a full size VMC and will have full enclosure Ground Ball-screws and 45 mm Linear rails flood coolant
7 years 7 months ago #127903 by KoenigCNC
Hi Tommy. For a complete Frame, Base Risers, Bridge Z axis, completely machined, stress relieved drilled and tapped ready mount ball-screws and linear rails along with drawings required for assembly around $20,000 I will make available the ballscrews, tool changers, Linear guides, spindle, enclosure, chip augers and all the other parts. I will also make available drawing for the parts in case someone can acquire the parts for less than I can get them for. Ball-screws I use are Ground, Linear rails are 45mm Precision. It intended to be an industrial quality machine comparable to other VMC in the marketplace.
Once of the biggest challenges to building a machine like this is building and machining the frame sourcing the parts and doing it at a reasonable price. I would it to cost about 40% less than a comparable machine sold. The savings is in using the Linuxcnc control and assembling the parts by the end user. Much like building a Kit Airplane.
I have a source for Yaskawa, Delta and other Servos and Drives.
First 3 frames will be ready ion about 30 days. I am making test cuts today on my gantry. Just did a 24 hour run off with no alarms. Today I am doing a 24 Hour test cut program.
I still have a lot of loose ends to tie up but its looking good
7 years 7 months ago #127968 by pl7i92
i got some problem with theis Gantry setup you choosen
as there are all rotation axis in the Z
this loses alot of space and need bigger mashine
insted using a XC setup and a Z,BAxis at the Gantry moving on Y railing
this gives the full space and only ads the toollength to the Rotation Table Diameter
Best to go for
7 years 7 months ago #127997 by KoenigCNC
Hi, Which machine? My new mill is a Bridge Mill not a Gantry. It has 40 x 40 x 30 inches of travel. My Big Gantry has 150 x 72 x 60 with 6 Feet under the Bridge With the new mill the Y axis is the Table and the x and z or on the Bridge. I one or two axis rotary table could be fitted on the table to allow 4 or 5 axis machine work. I have several other small machine designs I am working on also Small bridge type machine. Getting more Y axis travel in a small footprint is the goal.
7 years 7 months ago #127999 by pl7i92
Ich meinte diese Hier
forum.linuxcnc.org/54-user-exchange/3283...ject?start=10#126720
der Kopf soll ja um das werkstück da ist nicht viel platz bei einem 300mm langen Fräser
bei einem Dehtisch wäre in der Längsrichtung massig platz
Time to create page: 0.380 seconds
