Using ngcgui with axis
05 Jun 2011 09:29 #10304
by flintmill
Using ngcgui with axis was created by flintmill
Having learnt some of my mistakes from help given here I have rebooted my whole system and manged to get EMC2 to work correctly as soon as reloaded.
I have tried to integrate ngcgui with it following instructions on the site to copy files to new locations and amend DISPLAY in the ini file. All appeared to go well and I can find the correct files such as gosper.ngc.
When I try to load it I get message
no % sign or end of program
although the file appears to be in the window underneath AXIS.
What am I doing wrong
05 Jun 2011 11:02 #10305
by Rick G
Replied by Rick G on topic Re:Using ngcgui with axis
Hello John,
EMC is looking for a end of program such as "M2"
ngcgui will add it to the file when you run ngcgui and ...
Create feature
Then
Finalize.
Did you perhaps just load the gosper.ngc as you would a normal file?
If you just want load the gosper.ngc to try it edit it and add "M2" as the last line.
Take another look at the ngcgui instructions for starting, running and even embedding ngcgui to get the full benefits of the program. I wonder if it is possible you just missed a step.
Rick G
Create feature
Then
Finalize.
Rick G
05 Jun 2011 13:04 - 05 Jun 2011 13:38 #10307
by flintmill
Replied by flintmill on topic Re:Using ngcgui with axis
Rick,
The instructions I am following were from a discussion on the forum some time ago and involved copying files to the nc directory and also altering the ini file .
When I say the program is in the window under AXIS I can see the actual code from gosper, not any generated gcode.
I loaded EMC and then opened the gosper.ngc file, Is that correct. the instructions I had show how to set up files but don't mention running anything such as ngcgui before using it as an embedded function. Can you point me to the instructions you would recommend
many thanks
EDIT I have added the file I was using as instructions
many thanks
Last edit: 05 Jun 2011 13:38 by flintmill. Reason: Added instruction file
05 Jun 2011 15:00 - 05 Jun 2011 15:02 #10308
by BigJohnT
Replied by BigJohnT on topic Re:Using ngcgui with axis
Here is a demo of Dewey using ngcgui
www.linuxcnc.org/component/option,com_ku...d,3408/lang,english/
Last edit: 05 Jun 2011 15:02 by BigJohnT.
05 Jun 2011 15:30 #10309
by flintmill
I wonder whether I have completely misunderstood ngcgui.
I have tried to embed it by following instructions on where to move files and amend ini and then expected to be able to load one of the subroutine files such as gosper and expected a tab to come up so I could input parameters.
Is there another program I need to run, people talk about Finalise as though I need to go through some sort of compilation process.
05 Jun 2011 16:12 #10310
by BigJohnT
To use a subroutine you load it in your ini like
NGCGUI_SUBFILE = /home/john/emc2/nc_files/gosper.ngc
When you start Axis the gosper tab will show up. Then you fill in the blanks for your subroutine and press the Create Feature button. Once all sub's have had the features created you press the Finalize button. That concatenates all the features in the order you have placed them into one file and loads it into Axis.
05 Jun 2011 17:32 #10311
by flintmill
John,
I see that is my problem, no additional tabs are opening. Have attached copy of my amended ini file. Have I done that correctly
05 Jun 2011 17:52 #10312
by BigJohnT
That looks fine so long as your user name is john and you have placed the ngc files in the nc_files directory. Do you get an warning about something when you start axis?
05 Jun 2011 17:54 #10313
by BigJohnT
You might need the space after 10 in this line... not sure.
NGCGUI_FONT = Courier -10 normal
05 Jun 2011 18:16 #10314
by flintmill
no warnings at all =it just loads same as before with the emc2.4 axis code- still get the axis manual toolchanger window up and gone
Time to create page: 0.098 seconds
