Using ngcgui with axis
05 Jun 2011 19:41 #10315
by BigJohnT
Replied by BigJohnT on topic Re:Using ngcgui with axis
Do you have the following files in your config directory?
tkapp.py (2.4 only)
ngcgui_app.tcl
ngcgui.tcl
ngcgui_ttt.tcl
tkapp.py (2.4 only)
ngcgui_app.tcl
ngcgui.tcl
ngcgui_ttt.tcl
05 Jun 2011 19:55 #10316
by flintmill
Replied by flintmill on topic Re:Using ngcgui with axis
Yes all those files are there. I note that my ini file is not directly in the config directory but is in Taig-mill which is a sub directory of configs which is in emc2. Could that be the problem?. emc2 created Taig-mill itself when I used Stepconf to set it up.
05 Jun 2011 19:56 #10317
by BigJohnT
Yes, that would be the problem if the ngcgui files are not in the same directory as the ini file.
05 Jun 2011 20:02 #10318
by flintmill
05 Jun 2011 20:04 #10319
by flintmill
So when instructions say copy to config I should copy to directory with ini file?
05 Jun 2011 20:04 #10320
by BigJohnT
Yep, they need to go in the same directory as your ini file /configs/Taig-mill not in the /configs directory.
05 Jun 2011 20:18 #10321
by flintmill
John,
SUCCESS Many thanks - If stepconf always sets up a subdirectory it may be worth modifying instructions for benefit of others
Many thanks
Many thanks
05 Jun 2011 20:26 #10322
by BigJohnT
I'm ahead of you and have fixed the instructions all ready.
05 Jun 2011 20:36 #10323
by flintmill
John,
I spoke too soon, although it worked for simple which has no tool with slot which has tool 1 it fails with message
near line63 of
/home/john/emc2/configs/Taig-mill/auto.ngc: Unable to open file <loadtool>
I haven't been asked to set any tool parameters yet. is this something in emc I have missed or is it from ngcgui?
near line63 of
05 Jun 2011 20:46 #10324
by BigJohnT
Yep, me too... you need to copy in_std.ngc and loadtool.ngc to your nc_files directory.
Time to create page: 0.092 seconds
