Using ngcgui with axis
05 Jun 2011 20:56 #10325
by flintmill
Replied by flintmill on topic Re:Using ngcgui with axis
got rid of loadtool error -now unable to open file <move> corrected that then <line> then <spin>
now OK
now OK
05 Jun 2011 21:00 #10326
by BigJohnT
Replied by BigJohnT on topic Re:Using ngcgui with axis
I'm working though the same thing... I use ngcgui every day on my lathe but I wrote all the subs for that so I know how they work... let me know if you find any more.
05 Jun 2011 21:31 #10327
by flintmill
also <dir> and <cross> and <dot>
Have just copied all ngc files over now!!!
but getting error message File ended with no percent sign or program end but last line is
33: (ngcgui :m2 line added) m2 (g54 activated)
05 Jun 2011 21:36 #10328
by flintmill
I try again and I get unknown mcode- I think I will start to build up my own library - might be a lot quicker than trying to understand other peoples work without full documentation.
many thanks for your patience and help John
05 Jun 2011 21:39 - 05 Jun 2011 21:46 #10329
by BigJohnT
LOL, I'm up to that same point... are you trying to run slot?
Just comment out the M110 in spin.ngc and it works.
When you have worked out a sub you can add it to the subroutines section.
Last edit: 05 Jun 2011 21:46 by BigJohnT.
06 Jun 2011 08:47 #10335
by flintmill
I think I understand enough about the g, m and o code of emc2 to attempt a subroutine but not sure where the s/r specifies to axis the tab information. I have programmed in a number of languages in the dim past usually for languages under windows such as pascal and delphi
06 Jun 2011 11:01 #10339
by BigJohnT
I started a thread in the Subroutines section describing how to create your own subs.
www.linuxcnc.org/component/option,com_ku...,10338/lang,english/
Time to create page: 0.082 seconds
