Problem using emc2-install.sh
- grey1beard
27 Jun 2011 21:09 - 27 Jun 2011 21:54 #10906
by grey1beard
Problem using emc2-install.sh was created by grey1beard
I've just gone through the painful process of upgrading 8.04 to 10.04 onto the Toshiba A30 laptop I use as a coding /viewing machine, and having got past the blank screen by installing an Intel driver ppa, and am now trying to add emc2.
Before the install of emc2 was complete, I got an error message that there was a broken package that would have to be mended.
"E:/var/cache/apt/archives/rtai-modules-2.6.32-122-rtai_3.8.1-linuxcnc1_i386.deb: trying to overwrite '/etc/udev/rules.d/99-rtai.rules', which is also in package rtai-modules-2.6.24-16-rtai 0"
was the detail, but as a newbie, I haven't the faintest idea how to move past this.
Can anybody help, or should I post into the ubuntu forum for help there ?
EDIT I added the posting to the Ubuntu forum, in case it's one for them rather than an EMC2 .
Last edit: 27 Jun 2011 21:54 by grey1beard. Reason: Update info
- grey1beard
27 Jun 2011 22:08 #10908
by grey1beard
Replied by grey1beard on topic Re:Problem using emc2-install.sh
Is it as simple as removing the rtai-modules-2.6.24-16-rtai 0 package ?
Do I need this one ? Is it replaced by the newer one ?
- grey1beard
28 Jun 2011 21:36 #10934
by grey1beard
I think I've found the solution by tracking down and reading the EMC documentation Wiki: Ubuntu10.04PackageNotes.
Under known problems is this very one.
Tomorrow will tell.
Tomorrow will tell.
- grey1beard
29 Jun 2011 11:11 #10943
by grey1beard
Yes, that seems to have done the trick.
So onward and upward, hopefully.
There ought to be an Emoticon for crossed fingers !
29 Jun 2011 11:38 #10944
Replied by andypugh on topic Re:Problem using emc2-install.sh
Glad to hear you are getting there.
I am not sure that a live-CD re-install might not be easier (I am not sure if you keep your data in that case)
- grey1beard
29 Jun 2011 12:12 #10946
by grey1beard
Hi Andy.
I remember an old saying "If you want to get there, I wouldn't start from here.......![;) ;)](/media/kunena/emoticons/wink.png)
Regards
Regards
- grey1beard
11 Jul 2011 21:13 #11433
by grey1beard
Well, things didn't quite work out. ![:( :(](/media/kunena/emoticons/sad.png)
Having got EMC2 loaded several days ago, I've only just round to opening it.
Except that I haven't - opened it.
If i try opening the sim-axis I get an EMC2 splash window, then an Error window with a long page of info.
Rather than quote it all here, I believe there's a way of posting it without it showing (hidden) unless you click on it.
I've done it once before, but memory fails me (again !).
Can someone oblige with instructions, then I can add it.
11 Jul 2011 21:53 #11436
by BigJohnT
Replied by BigJohnT on topic Re:Problem using emc2-install.sh
You can copy it to a txt file and attach that to your message... also you can do dmesg > error.txt and the output of dmesg is send to a text file so you don't lose any of it.
- grey1beard
11 Jul 2011 22:16 #11439
by grey1beard
11 Jul 2011 23:33 #11442
Can you type
uname -r
I just want to check you are using the rtai-patched kernel.
uname -r
Time to create page: 0.095 seconds
