Problem using emc2-install.sh
- grey1beard
The result is 2.6.32- 122-rtai
I had a problem with the rtai when I was trying to do the original install, so perhaps it's still wrong ?
Edit - I should have added at the start that I'm only using EMC2 on this laptop to check out my g code give me the expected tool path in Axis before transferring to my workshop system.
- grey1beard
In the Debug file information, it suggests going to the wiki.linuxcnc.org/cgi-bin/emcinfo.pl?LockedMemory page.
Followed that advice, and there it says
I tried that, but my Terminal responded with " command not found".Solution
Edit /etc/security/limits.conf with your favorite text editor (e.g., sudo gedit /etc/security/limits.conf). Add the following line
* - memlock 20480
So I went into my file system to /etc/security/limits.conf and it has at the bottom of the file
#@student - maxlogins 4
# End of file
* hard memlock 20480 #EMC2
(I note that the spacing of the text I have put here isn't exactly the same as appears in the file, but I assume that is irrelevant.)
Not being familiar with the way the file should be edited, I left well alone, and have come back for further help and advice.
EDIT I see that the /security/limits.conf is a read only file. Relevant ?
To temporarily raise the limit for the current session, use the following command:
ulimit -l 20480
Is this line to be done in terminal, as an alternative to editing the limits.conf file ?
Looks more appropriate to my needs ?
Looking round the forums, I think it is one of the manifestations of this problem:
wiki.linuxcnc.org/emcinfo.pl?TroubleShoo..._t_run_missing_lapic
- grey1beard
Ran dsmeg | less, and extracted the following -
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ9 used by override.
so I assume lapic is OK ?
That would be my interpretation, but I am a long way out of my depth here.so I assume lapic is OK ?
- grey1beard
.......That would be my interpretation, but I am a long way out of my depth here.
and I'm treading water, too.
EDIT As a "fingers crossed" trial, I've just run the code ulimit -l 20480 in Terminal, then tried running EMC2, but it made no difference.
The error window spells out exactly the same fault.
- grey1beard
He's discovered that he had several linux kernels which might be conflicting, though this wasn't his final solution. (He has both 10.04 and 10.10 installed)
So I used synaptic to see what I had, and found the following :
Package linux-image-2.6.24-16-rtai Installed 2.6.24-16.30.linuxcnc.4
Package linux-image-2.6.32-122-rtai Installed 2.6.32-122.35.rtai
Package linux-image-2.6.32-32.generic Installed 2.6.32-32.62
Do I have any potential problems here ?
- grey1beard
I've just downloaded it, but knowing that my laptop has graphics issues(has the Intel 855 chip onboard) I've got quite a bit of preparation to do before I start.
Bye for now,
