RTAPI error?
- N.McA.
- Visitor
I installed to my primary hard drive, and its the only OS on my system. I had to use a slightly unconventional install method because of cd-drive driver issues. I used a usb made with UnetBootin, but this install method worked perfectly on a different system.
However, on this system, I can run neither the latency test nor EMC itself.
EMC gives this error message (on pastebin because of the size)
pastebin.com/LE6jvwYx
The latency test gives these errors when run in terminal as root:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
RTAPI: ERROR: could not open shared memory (errno=2)
RTAPI: Locked memory limit is 64KiB, recommended at least 20480KiB.
This can cause the error 'could not open shared memory'.
For more information, see
http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?LockedMemory
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Thanks so much to anyone who can help, I want to get cutting!
-N
Have you tried both?
Rick G
wiki.linuxcnc.org/emcinfo.pl?TroubleShooting
Does the problem computer have more than one core?
If so can you disable all but one core in the bios?
also
wiki.linuxcnc.org/emcinfo.pl?TroubleShoo...lcpus_Boot_parameter
It has been noted that some computers (older?) do not seem to work with 10.04 but are fine with 8.04 the reverse may also be true.
Rick G
RTPI ERROR: Unexpected realtime delayon task1
This message will only display once per session.
run the latency test and resolve before continuing,
LAG TEST
max interval 1000634
max jitter 5009
last interval 998450
(off the scale would you say?! i would)
ABOVE IS THE DETAIL:
I have recently built another machine and am using it to run my mill off a fresh livecd install.
BigJohnT sent me looking for the isocpu thing a ma bob which is why i am here.
my system is a
intel quadcore Q6600 2.4ghz
4gig 6400 9-9-9-7 ram
nvidia graphics card
asus motherboard
apparently this is because i have 3 more cpu cores then emc2 needs (odd because the last working machine was a coreduo 2 2.6ghz dualcore ran ok.. for a boat anchor)
after reading that confusing lump of crap what the hell am i suppose to do to ubuntu 10.04 so that i may get emc2.4 to work??????
LAG TEST
max jitter 5009
No, that all looks fine. You might need to run the test for longer to see the problem, or stress the system (glxgears for example, opening web browsers, that sort of thing) to see the problem.
All that matters is the "max jitter" and 5000 is very good.
What is your base period in the INI file?
where should i be looking for that ini file? and on that note if you need any other information... tell me how and where and its yours to scrutinize.
my system is now ridiculously fast following the isolcpus tutorial!!! I get about 12000 doing my best stress test as compared to 5000 which was moving a window around and letting the screen saver go because that is the most stress this operator console gets.
But it didnt help with the RTAPI errors and i was working on the assumption of less then 30,000 is "functional". I have never had the other figures in the millions before... even on the roll my own kernels.
Maybe I am reading the figures you posted wrong, but my interpretation is that you asked for a 1,000,000nS servo thread, and the worst-case jitter on that is 5009nS and the last servo period was 998450, ie 1550nS shorter than requested.
I don't think that 998450 is a jitter number.
my bad!
on an interesting note; the emc2 2.4 package and emc2 -dev packages have shown up in synaptic as an {!} instead of a green box
i found this out after all i got was an error report after restarting the console
i wonder what happens when i upgrade/reinstall?!
