EMC2 on Puppy linux.
29 Oct 2011 13:06 #14376 by eslavko
Replied by eslavko on topic Re:Curious for puppy too
Rick G wrote:
Is this where you started?
www.puppylinux.com/about.htm
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Emc_Puppy
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?CoolCnc.0.5
Yes it's this. But somwhere deep is live CD compilation. And I do from live CD. (not build from myself)
29 Oct 2011 13:18 #14377 by ArcEye
Replied by ArcEye on topic Re:Curious for puppy too
All I can find is this
www.thecooltool.com/produktgruppe.php?la...itel=CoolCNC+-+Linux
but all the links now appear dead or removed.
29 Oct 2011 15:14 #14380 by eslavko
I can't finf on wiki too...
But same thing is there
cuteminds.com/index.php/en/puppy
29 Oct 2011 15:16 #14382 by eslavko
and interesting things maybe on
www.murga-linux.com/puppy/viewtopic.php?p=11578
29 Oct 2011 17:35 #14390 by MonkeyKnight
Replied by MonkeyKnight on topic Re:Curious for puppy too
Would you be able to upload the version of PL that you are currently using? Perhaps it would be a good start for anyone to try to make it current.
29 Oct 2011 17:55 #14391 by eslavko
the link on post #14380 has link to ISO file from where I installed all the think
07 Nov 2011 16:11 #14650 by ArcEye
I've run out of time on this, without a successful result.
The best candidate I found for the distro, was Puppy Linux Lupu 511, which is linked to the Ubuntu Lucid repositories, so is easily updated and runs a fairly recent kernel (2.6.34 I think off the top of my head).
It is light enough to install easily on a slow old pentium desktop and has quite a good default interface.
I may well use it in the future if I have to press an old machine into service.
Wasted some time with Lubuntu and a couple of other distros, only to find that they though 4.1GB disk space was 'light'!
I was able to compile a variety of new kernels for Lupu, but hit problems compiling rtai.
The existing PL kernels are quite heavily patched themselves for squashfs, aufs etc and this seemed to conflict with the rtai patch. Rtai patched OK apparently, but then either produced a non-running kernel or one which magma would not compile against.
With more time would have had to sit down and run diff against the rtai .config and the PL .config and try to figure out where the conflicts were and if they were resolvable.
Hope someone else has more success
07 Nov 2011 16:35 #14652 by eslavko
I'm intrested on light linux capable to run EMC with AXIS interface...
But my knowledge on Linux and C is just to low to be capable to do that by myself.
It's not need to be Puppy linux just some 'light' one..
08 Nov 2011 07:31 #14667 by ArcEye
I'll try to have another play with this later, probably try for a Debian small installation image so that it will run an unpatched clean kernel, and work from there.
Work piling up at present.
11 Sep 2014 03:05 - 11 Sep 2014 03:31 #51047 by vtcnc
Replied by vtcnc on topic Re:Curious for puppy too
An old topic, sorry, but I've just been having a go at getting LinuxCNC to run on Puppy Linux.
www.murga-linux.com/puppy/viewtopic.php?t=95640
I've succeeded in getting a Lucid 528 puppy going with an RT kernel (2.6.33.5-rt25) (i686).
I'd like to first try just loading a lucid packaged binary version of Linuxcnc, but my problem is puppy doesnt use apt-get as a package manager.
Is there a way I can just download the .deb directly without apt?
Thanks!
Last edit: 11 Sep 2014 03:31 by vtcnc.
Time to create page: 0.219 seconds
