EMC2 won't start, errors
- Arthur Dent
30 Dec 2011 18:11 #16126
by Arthur Dent
EMC2 won't start, errors was created by Arthur Dent
I just did a normal install from the livecd. Stepconf runs, EMC and the latency test do not. Mind you I don't have a machine hooked up yet, nor even a parallel port, those are coming soon. Emc will let me pick a configuration, but then it spits out an error. Latency test just spits out an error.
Output of "emc":
Output of "latency-test":
Debug file is attached.
The same happens when I run from the livecd.
Any ideas?
Output of "emc":
cnc@cnc-desktop:~$ emc
EMC2 - 2.4.6
Machine configuration directory is '/home/cnc/emc2/configs/Work,_Dammit!'
Machine configuration file is 'Work,_Dammit!.ini'
Starting EMC2...
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_sched.ko': -1 Cannot allocate memory
Realtime system did not load
Shutting down and cleaning up EMC2...
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
Cleanup done
EMC terminated with an error. You can find more information in the log:
/home/cnc/emc_debug.txt
and
/home/cnc/emc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
cnc@cnc-desktop:~$ latency-test
Any ideas?
30 Dec 2011 18:34 #16127
by cncbasher
Replied by cncbasher on topic Re:EMC2 won't start, errors
it's probably looking for a parrell port , so if you dont have one fitted , could be a problem
basicly the realtime kernel is not loading because it cant load the step configuration you have requested .
try loading in simulation mode , or a simulation config
- Arthur Dent
30 Dec 2011 18:59 #16128
by Arthur Dent
Replied by Arthur Dent on topic Re:EMC2 won't start, errors
I was wondering if that might be the problem. Seems to me the latency test would still run without a port though. Oh well, I guess I'll put it in sim mode and hold off on further fiddling until I get my pci-parallel card.
Thanks for the quick and helpful reply.
30 Dec 2011 19:05 #16129
by cncbasher
let us know if it works ok in sim mode ,
30 Dec 2011 19:21 #16130
Replied by PCW on topic Re:EMC2 won't start, errors
can you post the output of dmesg?
sounds like the real time portion did not load
(maybe the dreaded LAPIC not found error)
- Arthur Dent
30 Dec 2011 20:25 #16131
by Arthur Dent
I can't for the life of me figure out how to set up emc in simulator mode after having installed it with the livecd.
Here's dmesg:
Here's dmesg:
cnc@cnc-desktop:~$ dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009c400 (usable)
[ 0.000000] BIOS-e820: 000000000009c400 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e7000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bff90000 (usable)
[ 0.000000] BIOS-e820: 00000000bff90000 - 00000000bffa0000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bffa0000 - 00000000bffe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bffe0000 - 00000000c0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000140000000 (usable)
[ 0.000000] DMI present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xbff90 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000140000000 aka 5120M
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000c0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009c400 (usable)
[ 0.000000] modified: 000000000009c400 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e7000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 00000000bff90000 (usable)
[ 0.000000] modified: 00000000bff90000 - 00000000bffa0000 (ACPI data)
[ 0.000000] modified: 00000000bffa0000 - 00000000bffe0000 (ACPI NVS)
[ 0.000000] modified: 00000000bffe0000 - 00000000c0000000 (reserved)
[ 0.000000] modified: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] modified: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] modified: 00000000fff00000 - 0000000100000000 (reserved)
[ 0.000000] modified: 0000000100000000 - 0000000140000000 (usable)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 377fe000 @ 10000-15000
[ 0.000000] RAMDISK: 37371000 - 37fefba6
[ 0.000000] Allocated new RAMDISK: 008b5000 - 01533ba6
[ 0.000000] Move RAMDISK from 0000000037371000 - 0000000037fefba5 to 008b5000 - 01533ba5
[ 0.000000] ACPI: RSDP 000fbff0 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT bff90000 00040 (v01 092209 RSDT1209 20090922 MSFT 00000097)
[ 0.000000] ACPI: FACP bff90200 00084 (v01 A M I OEMFACP 12000601 MSFT 00000097)
[ 0.000000] ACPI: DSDT bff90450 097A5 (v01 ASR85 ASR85171 00000171 INTL 20051117)
[ 0.000000] ACPI: FACS bffa0000 00040
[ 0.000000] ACPI: APIC bff90390 00080 (v01 092209 APIC1209 20090922 MSFT 00000097)
[ 0.000000] ACPI: MCFG bff90410 0003C (v01 092209 OEMMCFG 20090922 MSFT 00000097)
[ 0.000000] ACPI: OEMB bffa0040 00073 (v01 092209 OEMB1209 20090922 MSFT 00000097)
[ 0.000000] ACPI: AAFT bff99c00 00027 (v01 092209 OEMAAFT 20090922 MSFT 00000097)
[ 0.000000] ACPI: INFO bffa00c0 00124 (v01 092209 AMDINFO 20090922 MSFT 00000097)
[ 0.000000] ACPI: NVHD bffa01f0 00284 (v01 092209 NVHDCP 20090922 MSFT 00000097)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2183MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] node 0 low ram: 00000000 - 377fe000
[ 0.000000] node 0 bootmap 00011000 - 00017f00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 00377fe000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [000009c400 - 0000100000] BIOS reserved ==> [000009c400 - 0000100000]
[ 0.000000] #5 [00008b1000 - 00008b4137] BRK ==> [00008b1000 - 00008b4137]
[ 0.000000] #6 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #7 [00008b5000 - 0001533ba6] NEW RAMDISK ==> [00008b5000 - 0001533ba6]
[ 0.000000] #8 [0000011000 - 0000018000] BOOTMAP ==> [0000011000 - 0000018000]
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000bff90
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009c
[ 0.000000] 0: 0x00000100 -> 0x000bff90
[ 0.000000] On node 0 totalpages: 786204
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1535200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3948 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4368 pages used for memmap
[ 0.000000] HighMem zone: 554626 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x2008
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 17, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: BIOS IRQ0 pin2 override ignored.
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 24
[ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:3ec00000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c3000000 s74936 r0 d23368 u1048576
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u1048576 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 780060
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=22211ec5-5d25-422b-be37-8cbc89cbaab5 ro quiet splash
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 15726080 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000bff90)
[ 0.000000] Memory: 3081984k/3145280k available (4539k kernel code, 61876k reserved, 1928k data, 620k init, 2235976k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:440
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 3600.095 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 7200.19 BogoMIPS (lpj=14400380)
[ 0.004012] Security Framework initialized
[ 0.004024] AppArmor: AppArmor initialized
[ 0.004029] Mount-cache hash table entries: 512
[ 0.004091] Initializing cgroup subsys ns
[ 0.004093] Initializing cgroup subsys cpuacct
[ 0.004096] Initializing cgroup subsys memory
[ 0.004100] Initializing cgroup subsys devices
[ 0.004101] Initializing cgroup subsys freezer
[ 0.004102] Initializing cgroup subsys net_cls
[ 0.004111] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.004113] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.004114] CPU: Physical Processor ID: 0
[ 0.004115] CPU: Processor Core ID: 0
[ 0.004117] mce: CPU supports 6 MCE banks
[ 0.004123] using C1E aware idle routine
[ 0.004127] Performance Events: AMD PMU driver.
[ 0.004130] ... version: 0
[ 0.004131] ... bit width: 48
[ 0.004132] ... generic registers: 4
[ 0.004134] ... value mask: 0000ffffffffffff
[ 0.004135] ... max period: 00007fffffffffff
[ 0.004136] ... fixed-purpose events: 0
[ 0.004137] ... event mask: 000000000000000f
[ 0.004139] Checking 'hlt' instruction... OK.
[ 0.020367] ACPI: Core revision 20090903
[ 0.030619] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.030621] ftrace: allocating 21003 entries in 42 pages
[ 0.034366] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.034818] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
[ 0.036001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[ 0.036001] ...trying to set up timer (IRQ0) through the 8259A ...
[ 0.036001] ..... (found apic 0 pin 0) ...
[ 0.078321] ....... works.
[ 0.078322] CPU0: AMD Phenom(tm) II X4 955 Processor stepping 03
[ 0.080001] Booting processor 1 APIC 0x1 ip 0x6000
[ 0.008000] Initializing CPU#1
[ 0.008000] CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
[ 0.008000] CPU: L2 Cache: 512K (64 bytes/line)
[ 0.008000] CPU: Physical Processor ID: 0
[ 0.008000] CPU: Processor Core ID: 1
[ 0.164101] CPU1: AMD Phenom(tm) II X4 955 Processor stepping 03
[ 0.164111] checking TSC synchronization [CPU#0 -> CPU#1]: passed.
[ 0.168041] Booting processor 2 APIC 0x2 ip 0x6000
[ 0.008000] Initializing CPU#2
[ 0.008000] CPU: Processor Core ID: 2
[ 0.256038] CPU2: AMD Phenom(tm) II X4 955 Processor stepping 03
[ 0.256057] checking TSC synchronization [CPU#0 -> CPU#2]: passed.
[ 0.260048] Booting processor 3 APIC 0x3 ip 0x6000
[ 0.008000] Initializing CPU#3
[ 0.008000] CPU: Processor Core ID: 3
[ 0.348107] CPU3: AMD Phenom(tm) II X4 955 Processor stepping 03
[ 0.348126] checking TSC synchronization [CPU#0 -> CPU#3]: passed.
[ 0.352008] Brought up 4 CPUs
[ 0.352010] Total of 4 processors activated (28801.56 BogoMIPS).
[ 0.353396] CPU0 attaching sched-domain:
[ 0.353398] domain 0: span 0-3 level MC
[ 0.353399] groups: 0 1 2 3
[ 0.353403] CPU1 attaching sched-domain:
[ 0.353405] domain 0: span 0-3 level MC
[ 0.353406] groups: 1 2 3 0
[ 0.353409] CPU2 attaching sched-domain:
[ 0.353410] domain 0: span 0-3 level MC
[ 0.353412] groups: 2 3 0 1
[ 0.353415] CPU3 attaching sched-domain:
[ 0.353416] domain 0: span 0-3 level MC
[ 0.353417] groups: 3 0 1 2
[ 0.353473] devtmpfs: initialized
[ 0.353473] regulator: core version 0.5
[ 0.353473] NET: Registered protocol family 16
[ 0.353473] EISA bus registered
[ 0.353473] Trying to unpack rootfs image as initramfs...
[ 0.353473] ACPI: bus type pci registered
[ 0.353473] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.353473] PCI: Not using MMCONFIG.
[ 0.353473] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=9
[ 0.353473] PCI: Using configuration type 1 for base access
[ 0.353473] PCI: Using configuration type 1 for extended access
[ 0.353473] bio: create slab <bio-0> at 0
[ 0.353473] ACPI: EC: Look up EC in DSDT
[ 0.359894] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.365442] ACPI: Interpreter enabled
[ 0.365443] ACPI: (supports S0 S5)
[ 0.365449] ACPI: Using IOAPIC for interrupt routing
[ 0.365483] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.369755] PCI: MCFG area at e0000000 reserved in ACPI motherboard resources
[ 0.369756] PCI: Using MMCONFIG for extended config space
[ 0.378795] ACPI Warning: Incorrect checksum in table [OEMB] - 4A, should be 49 (20090903/tbutils-314)
[ 0.379077] ACPI: No dock devices found.
[ 0.379352] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.379587] pci 0000:00:01.0: reg 10 io port: [0x2f00-0x2fff]
[ 0.379621] pci 0000:00:01.1: reg 10 io port: [0x2900-0x293f]
[ 0.379630] pci 0000:00:01.1: reg 20 io port: [0x2d00-0x2d3f]
[ 0.379634] pci 0000:00:01.1: reg 24 io port: [0x2e00-0x2e3f]
[ 0.379651] pci 0000:00:01.1: PME# supported from D3hot D3cold
[ 0.379656] pci 0000:00:01.1: PME# disabled
[ 0.379707] pci 0000:00:01.3: reg 10 32bit mmio: [0xf5e80000-0xf5efffff]
[ 0.379825] pci 0000:00:02.0: reg 10 32bit mmio: [0xf5e7f000-0xf5e7ffff]
[ 0.379845] pci 0000:00:02.0: supports D1 D2
[ 0.379846] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.379848] pci 0000:00:02.0: PME# disabled
[ 0.379868] pci 0000:00:02.1: reg 10 32bit mmio: [0xf5e7ec00-0xf5e7ecff]
[ 0.379892] pci 0000:00:02.1: supports D1 D2
[ 0.379893] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.379895] pci 0000:00:02.1: PME# disabled
[ 0.379919] pci 0000:00:04.0: reg 10 32bit mmio: [0xf5e7d000-0xf5e7dfff]
[ 0.379939] pci 0000:00:04.0: supports D1 D2
[ 0.379940] pci 0000:00:04.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.379943] pci 0000:00:04.0: PME# disabled
[ 0.379962] pci 0000:00:04.1: reg 10 32bit mmio: [0xf5e7e800-0xf5e7e8ff]
[ 0.379986] pci 0000:00:04.1: supports D1 D2
[ 0.379987] pci 0000:00:04.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.379989] pci 0000:00:04.1: PME# disabled
[ 0.380026] pci 0000:00:07.0: reg 10 32bit mmio: [0xf5e78000-0xf5e7bfff]
[ 0.380050] pci 0000:00:07.0: PME# supported from D3hot D3cold
[ 0.380052] pci 0000:00:07.0: PME# disabled
[ 0.380103] pci 0000:00:09.0: reg 10 io port: [0xa080-0xa087]
[ 0.380105] pci 0000:00:09.0: reg 14 io port: [0xa000-0xa003]
[ 0.380108] pci 0000:00:09.0: reg 18 io port: [0x9c00-0x9c07]
[ 0.380111] pci 0000:00:09.0: reg 1c io port: [0x9880-0x9883]
[ 0.380113] pci 0000:00:09.0: reg 20 io port: [0x9800-0x980f]
[ 0.380116] pci 0000:00:09.0: reg 24 32bit mmio: [0xf5e76000-0xf5e77fff]
[ 0.380147] pci 0000:00:0a.0: reg 10 32bit mmio: [0xf5e7c000-0xf5e7cfff]
[ 0.380150] pci 0000:00:0a.0: reg 14 io port: [0x9480-0x9487]
[ 0.380153] pci 0000:00:0a.0: reg 18 32bit mmio: [0xf5e7e400-0xf5e7e4ff]
[ 0.380156] pci 0000:00:0a.0: reg 1c 32bit mmio: [0xf5e7e000-0xf5e7e00f]
[ 0.380173] pci 0000:00:0a.0: supports D1 D2
[ 0.380174] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.380177] pci 0000:00:0a.0: PME# disabled
[ 0.380416] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.380422] pci 0000:00:10.0: PME# disabled
[ 0.380693] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.380699] pci 0000:00:12.0: PME# disabled
[ 0.380968] pci 0000:00:13.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.380975] pci 0000:00:13.0: PME# disabled
[ 0.381244] pci 0000:00:14.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.381250] pci 0000:00:14.0: PME# disabled
[ 0.381367] pci 0000:01:08.0: reg 10 32bit mmio: [0xf5fff800-0xf5ffffff]
[ 0.381372] pci 0000:01:08.0: reg 14 io port: [0xbc00-0xbc7f]
[ 0.381401] pci 0000:01:08.0: supports D2
[ 0.381403] pci 0000:01:08.0: PME# supported from D2 D3hot D3cold
[ 0.381406] pci 0000:01:08.0: PME# disabled
[ 0.381429] pci 0000:00:08.0: transparent bridge
[ 0.381432] pci 0000:00:08.0: bridge io port: [0xb000-0xbfff]
[ 0.381434] pci 0000:00:08.0: bridge 32bit mmio: [0xf5f00000-0xf5ffffff]
[ 0.381473] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.381475] pci 0000:02:00.0: PME# disabled
[ 0.381519] pci 0000:00:10.0: bridge io port: [0xc000-0xdfff]
[ 0.381526] pci 0000:00:10.0: bridge 32bit mmio: [0xf6000000-0xfd7fffff]
[ 0.381539] pci 0000:00:10.0: bridge 64bit mmio pref: [0xc0000000-0xdfffffff]
[ 0.381570] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.381572] pci 0000:03:00.0: PME# disabled
[ 0.381605] pci 0000:03:02.0: PME# supported from D0 D3hot D3cold
[ 0.381607] pci 0000:03:02.0: PME# disabled
[ 0.381628] pci 0000:02:00.0: bridge io port: [0xc000-0xdfff]
[ 0.381630] pci 0000:02:00.0: bridge 32bit mmio: [0xf6000000-0xfd7fffff]
[ 0.381634] pci 0000:02:00.0: bridge 64bit mmio pref: [0xc0000000-0xdfffffff]
[ 0.381658] pci 0000:04:00.0: reg 10 32bit mmio: [0xf9000000-0xf9ffffff]
[ 0.381666] pci 0000:04:00.0: reg 14 64bit mmio pref: [0xc0000000-0xcfffffff]
[ 0.381673] pci 0000:04:00.0: reg 1c 64bit mmio: [0xf6000000-0xf7ffffff]
[ 0.381678] pci 0000:04:00.0: reg 24 io port: [0xcc00-0xcc7f]
[ 0.381682] pci 0000:04:00.0: reg 30 32bit mmio pref: [0xf8fe0000-0xf8ffffff]
[ 0.381726] pci 0000:03:00.0: bridge io port: [0xc000-0xcfff]
[ 0.381729] pci 0000:03:00.0: bridge 32bit mmio: [0xf6000000-0xf9ffffff]
[ 0.381732] pci 0000:03:00.0: bridge 64bit mmio pref: [0xc0000000-0xcfffffff]
[ 0.381757] pci 0000:05:00.0: reg 10 32bit mmio: [0xfc000000-0xfcffffff]
[ 0.381764] pci 0000:05:00.0: reg 14 64bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.381772] pci 0000:05:00.0: reg 1c 64bit mmio: [0xfa000000-0xfbffffff]
[ 0.381777] pci 0000:05:00.0: reg 24 io port: [0xdc00-0xdc7f]
[ 0.381781] pci 0000:05:00.0: reg 30 32bit mmio pref: [0xfd7e0000-0xfd7fffff]
[ 0.381825] pci 0000:03:02.0: bridge io port: [0xd000-0xdfff]
[ 0.381827] pci 0000:03:02.0: bridge 32bit mmio: [0xfa000000-0xfd7fffff]
[ 0.381831] pci 0000:03:02.0: bridge 64bit mmio pref: [0xd0000000-0xdfffffff]
[ 0.381907] pci 0000:00:12.0: bridge 64bit mmio pref: [0xf1e00000-0xf1efffff]
[ 0.381974] pci 0000:00:13.0: bridge 64bit mmio pref: [0xf1f00000-0xf1ffffff]
[ 0.382025] pci 0000:00:14.0: bridge io port: [0xe000-0xefff]
[ 0.382032] pci 0000:00:14.0: bridge 32bit mmio: [0xfd800000-0xfebfffff]
[ 0.382045] pci 0000:00:14.0: bridge 64bit mmio pref: [0xf2000000-0xf4ffffff]
[ 0.382093] pci_bus 0000:00: on NUMA node 0
[ 0.382096] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.382290] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.382361] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.MXR0._PRT]
[ 0.382406] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR12._PRT]
[ 0.382448] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR13._PRT]
[ 0.382496] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BRHP._PRT]
[ 0.394276] ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *14
[ 0.394438] ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
[ 0.394599] ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
[ 0.394759] ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
[ 0.394922] ACPI: PCI Interrupt Link [LN0A] (IRQs 16 17 18 19) *10
[ 0.395082] ACPI: PCI Interrupt Link [LN0B] (IRQs 16 17 18 19) *0, disabled.
[ 0.395245] ACPI: PCI Interrupt Link [LN0C] (IRQs 16 17 18 19) *10
[ 0.395406] ACPI: PCI Interrupt Link [LN0D] (IRQs 16 17 18 19) *0, disabled.
[ 0.395566] ACPI: PCI Interrupt Link [LN1A] (IRQs 16 17 18 19) *0, disabled.
[ 0.395727] ACPI: PCI Interrupt Link [LN1B] (IRQs 16 17 18 19) *0, disabled.
[ 0.395887] ACPI: PCI Interrupt Link [LN1C] (IRQs 16 17 18 19) *0, disabled.
[ 0.396058] ACPI: PCI Interrupt Link [LN1D] (IRQs 16 17 18 19) *0, disabled.
[ 0.396231] ACPI: PCI Interrupt Link [LN2A] (IRQs 16 17 18 19) *11
[ 0.396391] ACPI: PCI Interrupt Link [LN2B] (IRQs 16 17 18 19) *0, disabled.
[ 0.396553] ACPI: PCI Interrupt Link [LN2C] (IRQs 16 17 18 19) *0, disabled.
[ 0.396713] ACPI: PCI Interrupt Link [LN2D] (IRQs 16 17 18 19) *0, disabled.
[ 0.396877] ACPI: PCI Interrupt Link [LN3A] (IRQs 16 17 18 19) *15
[ 0.397037] ACPI: PCI Interrupt Link [LN3B] (IRQs 16 17 18 19) *0, disabled.
[ 0.397197] ACPI: PCI Interrupt Link [LN3C] (IRQs 16 17 18 19) *0, disabled.
[ 0.397358] ACPI: PCI Interrupt Link [LN3D] (IRQs 16 17 18 19) *0, disabled.
[ 0.397521] ACPI: PCI Interrupt Link [LN4A] (IRQs 16 17 18 19) *14
[ 0.397681] ACPI: PCI Interrupt Link [LN4B] (IRQs 16 17 18 19) *0, disabled.
[ 0.397841] ACPI: PCI Interrupt Link [LN4C] (IRQs 16 17 18 19) *0, disabled.
[ 0.398002] ACPI: PCI Interrupt Link [LN4D] (IRQs 16 17 18 19) *0, disabled.
[ 0.398163] ACPI: PCI Interrupt Link [LN5A] (IRQs 16 17 18 19) *0, disabled.
[ 0.398324] ACPI: PCI Interrupt Link [LN5B] (IRQs 16 17 18 19) *0, disabled.
[ 0.398485] ACPI: PCI Interrupt Link [LN5C] (IRQs 16 17 18 19) *0, disabled.
[ 0.398646] ACPI: PCI Interrupt Link [LN5D] (IRQs 16 17 18 19) *0, disabled.
[ 0.398808] ACPI: PCI Interrupt Link [LN6A] (IRQs 16 17 18 19) *0, disabled.
[ 0.398969] ACPI: PCI Interrupt Link [LN6B] (IRQs 16 17 18 19) *0, disabled.
[ 0.399129] ACPI: PCI Interrupt Link [LN6C] (IRQs 16 17 18 19) *0, disabled.
[ 0.399290] ACPI: PCI Interrupt Link [LN6D] (IRQs 16 17 18 19) *0, disabled.
[ 0.399452] ACPI: PCI Interrupt Link [LN7A] (IRQs 16 17 18 19) *0, disabled.
[ 0.399612] ACPI: PCI Interrupt Link [LN7B] (IRQs 16 17 18 19) *0, disabled.
[ 0.399772] ACPI: PCI Interrupt Link [LN7C] (IRQs 16 17 18 19) *0, disabled.
[ 0.399934] ACPI: PCI Interrupt Link [LN7D] (IRQs 16 17 18 19) *0, disabled.
[ 0.400110] ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *11
[ 0.400277] ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *15
[ 0.400440] ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *15
[ 0.400604] ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *11
[ 0.400763] ACPI: PCI Interrupt Link [SGRU] (IRQs 20 21 22 23) *0, disabled.
[ 0.400927] ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *7
[ 0.401090] ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *10
[ 0.401253] ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *5
[ 0.401439] ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
[ 0.401603] ACPI: PCI Interrupt Link [UB11] (IRQs 20 21 22 23) *14
[ 0.401767] ACPI: PCI Interrupt Link [UB12] (IRQs 20 21 22 23) *10
[ 0.401843] vgaarb: device added: PCI:0000:04:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.401846] vgaarb: device added: PCI:0000:05:00.0,decodes=io+mem,owns=none,locks=none
[ 0.401848] vgaarb: loaded
[ 0.401913] SCSI subsystem initialized
[ 0.401941] libata version 3.00 loaded.
[ 0.401941] usbcore: registered new interface driver usbfs
[ 0.401941] usbcore: registered new interface driver hub
[ 0.401941] usbcore: registered new device driver usb
[ 0.401941] ACPI: WMI: Mapper loaded
[ 0.401941] PCI: Using ACPI for IRQ routing
[ 0.401941] NetLabel: Initializing
[ 0.401941] NetLabel: domain hash size = 128
[ 0.401941] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.401941] NetLabel: unlabeled traffic allowed by default
[ 0.401941] Switching to clocksource tsc
[ 0.402424] AppArmor: AppArmor Filesystem Enabled
[ 0.402424] pnp: PnP ACPI init
[ 0.402424] ACPI: bus type pnp registered
[ 0.405216] pnp: PnP ACPI: found 11 devices
[ 0.405217] ACPI: ACPI bus type pnp unregistered
[ 0.405219] PnPBIOS: Disabled by ACPI PNP
[ 0.405226] system 00:04: ioport range 0x4d0-0x4d1 has been reserved
[ 0.405227] system 00:04: ioport range 0x800-0x80f has been reserved
[ 0.405229] system 00:04: ioport range 0x2000-0x207f has been reserved
[ 0.405231] system 00:04: ioport range 0x2080-0x20ff has been reserved
[ 0.405232] system 00:04: ioport range 0x2400-0x247f has been reserved
[ 0.405234] system 00:04: ioport range 0x2480-0x24ff has been reserved
[ 0.405236] system 00:04: ioport range 0x2800-0x287f has been reserved
[ 0.405237] system 00:04: ioport range 0x2880-0x28ff has been reserved
[ 0.405240] system 00:04: iomem range 0xfed04000-0xfed04fff has been reserved
[ 0.405241] system 00:04: iomem range 0xfee01000-0xfeefffff has been reserved
[ 0.405245] system 00:06: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.405247] system 00:06: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.405250] system 00:08: ioport range 0x290-0x29f has been reserved
[ 0.405253] system 00:09: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.405256] system 00:0a: iomem range 0x0-0x9ffff could not be reserved
[ 0.405257] system 00:0a: iomem range 0xc0000-0xcffff could not be reserved
[ 0.405259] system 00:0a: iomem range 0xe0000-0xfffff could not be reserved
[ 0.405261] system 00:0a: iomem range 0x100000-0xbfffffff could not be reserved
[ 0.405263] system 00:0a: iomem range 0xfec00000-0xffffffff could not be reserved
[ 0.440045] pci 0000:00:08.0: PCI bridge, secondary bus 0000:01
[ 0.440047] pci 0000:00:08.0: IO window: 0xb000-0xbfff
[ 0.440050] pci 0000:00:08.0: MEM window: 0xf5f00000-0xf5ffffff
[ 0.440052] pci 0000:00:08.0: PREFETCH window: disabled
[ 0.440056] pci 0000:03:00.0: PCI bridge, secondary bus 0000:04
[ 0.440058] pci 0000:03:00.0: IO window: 0xc000-0xcfff
[ 0.440060] pci 0000:03:00.0: MEM window: 0xf6000000-0xf9ffffff
[ 0.440063] pci 0000:03:00.0: PREFETCH window: 0x000000c0000000-0x000000cfffffff
[ 0.440067] pci 0000:03:02.0: PCI bridge, secondary bus 0000:05
[ 0.440068] pci 0000:03:02.0: IO window: 0xd000-0xdfff
[ 0.440071] pci 0000:03:02.0: MEM window: 0xfa000000-0xfd7fffff
[ 0.440074] pci 0000:03:02.0: PREFETCH window: 0x000000d0000000-0x000000dfffffff
[ 0.440077] pci 0000:02:00.0: PCI bridge, secondary bus 0000:03
[ 0.440079] pci 0000:02:00.0: IO window: 0xc000-0xdfff
[ 0.440082] pci 0000:02:00.0: MEM window: 0xf6000000-0xfd7fffff
[ 0.440084] pci 0000:02:00.0: PREFETCH window: 0x000000c0000000-0x000000dfffffff
[ 0.440088] pci 0000:00:10.0: PCI bridge, secondary bus 0000:02
[ 0.440092] pci 0000:00:10.0: IO window: 0xc000-0xdfff
[ 0.440101] pci 0000:00:10.0: MEM window: 0xf6000000-0xfd7fffff
[ 0.440107] pci 0000:00:10.0: PREFETCH window: 0x000000c0000000-0x000000dfffffff
[ 0.440119] pci 0000:00:12.0: PCI bridge, secondary bus 0000:06
[ 0.440120] pci 0000:00:12.0: IO window: disabled
[ 0.440128] pci 0000:00:12.0: MEM window: disabled
[ 0.440134] pci 0000:00:12.0: PREFETCH window: 0x000000f1e00000-0x000000f1efffff
[ 0.440146] pci 0000:00:13.0: PCI bridge, secondary bus 0000:07
[ 0.440147] pci 0000:00:13.0: IO window: disabled
[ 0.440155] pci 0000:00:13.0: MEM window: disabled
[ 0.440162] pci 0000:00:13.0: PREFETCH window: 0x000000f1f00000-0x000000f1ffffff
[ 0.440173] pci 0000:00:14.0: PCI bridge, secondary bus 0000:08
[ 0.440177] pci 0000:00:14.0: IO window: 0xe000-0xefff
[ 0.440186] pci 0000:00:14.0: MEM window: 0xfd800000-0xfebfffff
[ 0.440192] pci 0000:00:14.0: PREFETCH window: 0x000000f2000000-0x000000f4ffffff
[ 0.440207] pci 0000:00:08.0: setting latency timer to 64
[ 0.440458] ACPI: PCI Interrupt Link [LN0A] enabled at IRQ 19
[ 0.440460] alloc irq_desc for 19 on node -1
[ 0.440461] alloc kstat_irqs on node -1
[ 0.440467] pci 0000:00:10.0: PCI INT A -> Link[LN0A] -> GSI 19 (level, low) -> IRQ 19
[ 0.440474] pci 0000:00:10.0: setting latency timer to 64
[ 0.440481] pci 0000:02:00.0: setting latency timer to 64
[ 0.440486] pci 0000:03:00.0: setting latency timer to 64
[ 0.440491] pci 0000:03:02.0: setting latency timer to 64
[ 0.440734] ACPI: PCI Interrupt Link [LN2A] enabled at IRQ 18
[ 0.440735] alloc irq_desc for 18 on node -1
[ 0.440736] alloc kstat_irqs on node -1
[ 0.440742] pci 0000:00:12.0: PCI INT A -> Link[LN2A] -> GSI 18 (level, low) -> IRQ 18
[ 0.440749] pci 0000:00:12.0: setting latency timer to 64
[ 0.440991] ACPI: PCI Interrupt Link [LN3A] enabled at IRQ 17
[ 0.440993] alloc irq_desc for 17 on node -1
[ 0.440994] alloc kstat_irqs on node -1
[ 0.440999] pci 0000:00:13.0: PCI INT A -> Link[LN3A] -> GSI 17 (level, low) -> IRQ 17
[ 0.441006] pci 0000:00:13.0: setting latency timer to 64
[ 0.441248] ACPI: PCI Interrupt Link [LN4A] enabled at IRQ 16
[ 0.441250] alloc irq_desc for 16 on node -1
[ 0.441251] alloc kstat_irqs on node -1
[ 0.441256] pci 0000:00:14.0: PCI INT A -> Link[LN4A] -> GSI 16 (level, low) -> IRQ 16
[ 0.441263] pci 0000:00:14.0: setting latency timer to 64
[ 0.441268] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.441270] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.441271] pci_bus 0000:01: resource 0 io: [0xb000-0xbfff]
[ 0.441273] pci_bus 0000:01: resource 1 mem: [0xf5f00000-0xf5ffffff]
[ 0.441274] pci_bus 0000:01: resource 3 io: [0x00-0xffff]
[ 0.441276] pci_bus 0000:01: resource 4 mem: [0x000000-0xffffffff]
[ 0.441278] pci_bus 0000:02: resource 0 io: [0xc000-0xdfff]
[ 0.441279] pci_bus 0000:02: resource 1 mem: [0xf6000000-0xfd7fffff]
[ 0.441281] pci_bus 0000:02: resource 2 pref mem [0xc0000000-0xdfffffff]
[ 0.441282] pci_bus 0000:03: resource 0 io: [0xc000-0xdfff]
[ 0.441284] pci_bus 0000:03: resource 1 mem: [0xf6000000-0xfd7fffff]
[ 0.441285] pci_bus 0000:03: resource 2 pref mem [0xc0000000-0xdfffffff]
[ 0.441287] pci_bus 0000:04: resource 0 io: [0xc000-0xcfff]
[ 0.441288] pci_bus 0000:04: resource 1 mem: [0xf6000000-0xf9ffffff]
[ 0.441290] pci_bus 0000:04: resource 2 pref mem [0xc0000000-0xcfffffff]
[ 0.441291] pci_bus 0000:05: resource 0 io: [0xd000-0xdfff]
[ 0.441293] pci_bus 0000:05: resource 1 mem: [0xfa000000-0xfd7fffff]
[ 0.441294] pci_bus 0000:05: resource 2 pref mem [0xd0000000-0xdfffffff]
[ 0.441296] pci_bus 0000:06: resource 2 pref mem [0xf1e00000-0xf1efffff]
[ 0.441298] pci_bus 0000:07: resource 2 pref mem [0xf1f00000-0xf1ffffff]
[ 0.441299] pci_bus 0000:08: resource 0 io: [0xe000-0xefff]
[ 0.441301] pci_bus 0000:08: resource 1 mem: [0xfd800000-0xfebfffff]
[ 0.441302] pci_bus 0000:08: resource 2 pref mem [0xf2000000-0xf4ffffff]
[ 0.441325] NET: Registered protocol family 2
[ 0.441379] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.441567] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.441935] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.442113] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.442115] TCP reno registered
[ 0.442157] NET: Registered protocol family 1
[ 0.505602] pci 0000:00:07.0: Enabling HT MSI Mapping
[ 0.505695] pci 0000:00:08.0: Enabling HT MSI Mapping
[ 0.505791] pci 0000:00:09.0: Enabling HT MSI Mapping
[ 0.505893] pci 0000:00:0a.0: Enabling HT MSI Mapping
[ 0.506128] pci 0000:04:00.0: Boot video device
[ 0.506349] Scanning for low memory corruption every 60 seconds
[ 0.506398] audit: initializing netlink socket (disabled)
[ 0.506405] type=2000 audit(1325240095.505:1): initialized
[ 0.510672] highmem bounce pool size: 64 pages
[ 0.510675] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.511477] VFS: Disk quotas dquot_6.5.2
[ 0.511509] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.511812] fuse init (API version 7.13)
[ 0.511857] msgmni has been set to 1654
[ 0.512014] alg: No test for stdrng (krng)
[ 0.512045] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.512047] io scheduler noop registered
[ 0.512048] io scheduler anticipatory registered
[ 0.512049] io scheduler deadline registered
[ 0.512070] io scheduler cfq registered (default)
[ 0.512334] alloc irq_desc for 24 on node -1
[ 0.512335] alloc kstat_irqs on node -1
[ 0.512352] pcieport 0000:00:10.0: irq 24 for MSI/MSI-X
[ 0.512370] pcieport 0000:00:10.0: setting latency timer to 64
[ 0.512724] alloc irq_desc for 25 on node -1
[ 0.512725] alloc kstat_irqs on node -1
[ 0.512740] pcieport 0000:00:12.0: irq 25 for MSI/MSI-X
[ 0.512757] pcieport 0000:00:12.0: setting latency timer to 64
[ 0.513104] alloc irq_desc for 26 on node -1
[ 0.513105] alloc kstat_irqs on node -1
[ 0.513119] pcieport 0000:00:13.0: irq 26 for MSI/MSI-X
[ 0.513137] pcieport 0000:00:13.0: setting latency timer to 64
[ 0.513487] alloc irq_desc for 27 on node -1
[ 0.513488] alloc kstat_irqs on node -1
[ 0.513503] pcieport 0000:00:14.0: irq 27 for MSI/MSI-X
[ 0.513520] pcieport 0000:00:14.0: setting latency timer to 64
[ 0.513720] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.513732] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.513775] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.513777] ACPI: Power Button [PWRB]
[ 0.513811] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.513812] ACPI: Power Button [PWRF]
[ 0.513873] isapnp: Scanning for PnP cards...
[ 0.514468] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.514550] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.514746] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.515268] brd: module loaded
[ 0.515502] loop: module loaded
[ 0.515541] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.515742] Fixed MDIO Bus: probed
[ 0.515759] PPP generic driver version 2.4.2
[ 0.515775] tun: Universal TUN/TAP device driver, 1.6
[ 0.515776] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.515817] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.516092] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 23
[ 0.516094] alloc irq_desc for 23 on node -1
[ 0.516096] alloc kstat_irqs on node -1
[ 0.516102] ehci_hcd 0000:00:02.1: PCI INT B -> Link[LUB2] -> GSI 23 (level, low) -> IRQ 23
[ 0.516109] ehci_hcd 0000:00:02.1: setting latency timer to 64
[ 0.516111] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 0.516130] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 0.516145] ehci_hcd 0000:00:02.1: debug port 1
[ 0.516151] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported
[ 0.516165] ehci_hcd 0000:00:02.1: irq 23, io mem 0xf5e7ec00
[ 0.525492] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 0.525551] usb usb1: configuration #1 chosen from 1 choice
[ 0.525566] hub 1-0:1.0: USB hub found
[ 0.525570] hub 1-0:1.0: 6 ports detected
[ 0.525840] ACPI: PCI Interrupt Link [UB12] enabled at IRQ 22
[ 0.525842] alloc irq_desc for 22 on node -1
[ 0.525843] alloc kstat_irqs on node -1
[ 0.525849] ehci_hcd 0000:00:04.1: PCI INT B -> Link[UB12] -> GSI 22 (level, low) -> IRQ 22
[ 0.525857] ehci_hcd 0000:00:04.1: setting latency timer to 64
[ 0.525859] ehci_hcd 0000:00:04.1: EHCI Host Controller
[ 0.525877] ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 2
[ 0.525890] ehci_hcd 0000:00:04.1: debug port 1
[ 0.525896] ehci_hcd 0000:00:04.1: cache line size of 64 is not supported
[ 0.525910] ehci_hcd 0000:00:04.1: irq 22, io mem 0xf5e7e800
[ 0.537492] ehci_hcd 0000:00:04.1: USB 2.0 started, EHCI 1.00
[ 0.537544] usb usb2: configuration #1 chosen from 1 choice
[ 0.537557] hub 2-0:1.0: USB hub found
[ 0.537562] hub 2-0:1.0: 6 ports detected
[ 0.537594] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.537838] ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 21
[ 0.537840] alloc irq_desc for 21 on node -1
[ 0.537841] alloc kstat_irqs on node -1
[ 0.537847] ohci_hcd 0000:00:02.0: PCI INT A -> Link[LUB0] -> GSI 21 (level, low) -> IRQ 21
[ 0.537854] ohci_hcd 0000:00:02.0: setting latency timer to 64
[ 0.537856] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 0.537875] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 3
[ 0.537893] ohci_hcd 0000:00:02.0: irq 21, io mem 0xf5e7f000
[ 0.578003] Freeing initrd memory: 12794k freed
[ 0.595562] usb usb3: configuration #1 chosen from 1 choice
[ 0.595579] hub 3-0:1.0: USB hub found
[ 0.595585] hub 3-0:1.0: 6 ports detected
[ 0.595870] ACPI: PCI Interrupt Link [UB11] enabled at IRQ 20
[ 0.595873] alloc irq_desc for 20 on node -1
[ 0.595874] alloc kstat_irqs on node -1
[ 0.595881] ohci_hcd 0000:00:04.0: PCI INT A -> Link[UB11] -> GSI 20 (level, low) -> IRQ 20
[ 0.595891] ohci_hcd 0000:00:04.0: setting latency timer to 64
[ 0.595893] ohci_hcd 0000:00:04.0: OHCI Host Controller
[ 0.595912] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 4
[ 0.595932] ohci_hcd 0000:00:04.0: irq 20, io mem 0xf5e7d000
[ 0.651535] usb usb4: configuration #1 chosen from 1 choice
[ 0.651548] hub 4-0:1.0: USB hub found
[ 0.651554] hub 4-0:1.0: 6 ports detected
[ 0.651584] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.651629] PNP: No PS/2 controller found. Probing ports directly.
[ 0.654333] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.654338] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.654380] mice: PS/2 mouse device common for all mice
[ 0.654439] rtc_cmos 00:05: RTC can wake from S4
[ 0.654459] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.654504] rtc0: alarms up to one year, y3k, 114 bytes nvram
[ 0.654555] device-mapper: uevent: version 1.0.3
[ 0.654636] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.654705] device-mapper: multipath: version 1.1.0 loaded
[ 0.654707] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.654766] EISA: Probing bus 0 at eisa.0
[ 0.654771] Cannot allocate resource for EISA slot 2
[ 0.654785] EISA: Detected 0 cards.
[ 0.654786] cpuidle: using governor ladder
[ 0.654787] cpuidle: using governor menu
[ 0.655014] TCP cubic registered
[ 0.655092] NET: Registered protocol family 10
[ 0.655322] lo: Disabled Privacy Extensions
[ 0.655486] NET: Registered protocol family 17
[ 0.655499] Using IPI No-Shortcut mode
[ 0.655537] registered taskstats version 1
[ 0.656144] rtc_cmos 00:05: setting system clock to 2011-12-30 10:14:55 UTC (1325240095)
[ 0.656146] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.656147] EDD information not available.
[ 0.866746] isapnp: No Plug & Play device found
[ 0.866767] Freeing unused kernel memory: 620k freed
[ 0.866931] Write protecting the kernel text: 4540k
[ 0.866948] Write protecting the kernel read-only data: 1668k
[ 0.876651] udev: starting version 151
[ 0.889250] ahci 0000:00:09.0: version 3.0
[ 0.889539] ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 23
[ 0.889543] ahci 0000:00:09.0: PCI INT A -> Link[LSA0] -> GSI 23 (level, low) -> IRQ 23
[ 0.889572] alloc irq_desc for 28 on node -1
[ 0.889573] alloc kstat_irqs on node -1
[ 0.889581] ahci 0000:00:09.0: irq 28 for MSI/MSI-X
[ 0.889642] ahci 0000:00:09.0: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl RAID mode
[ 0.889645] ahci 0000:00:09.0: flags: 64bit ncq sntf led clo pmp pio sxs boh
[ 0.889648] ahci 0000:00:09.0: setting latency timer to 64
[ 0.897745] scsi0 : ahci
[ 0.898522] scsi1 : ahci
[ 0.898565] scsi2 : ahci
[ 0.898682] scsi3 : ahci
[ 0.898868] scsi4 : ahci
[ 0.902877] scsi5 : ahci
[ 0.902955] Linux agpgart interface v0.103
[ 0.902986] ata1: SATA max UDMA/133 abar m8192@0xf5e76000 port 0xf5e76100 irq 28
[ 0.902989] ata2: SATA max UDMA/133 abar m8192@0xf5e76000 port 0xf5e76180 irq 28
[ 0.902991] ata3: SATA max UDMA/133 abar m8192@0xf5e76000 port 0xf5e76200 irq 28
[ 0.902992] ata4: SATA max UDMA/133 abar m8192@0xf5e76000 port 0xf5e76280 irq 28
[ 0.902994] ata5: SATA max UDMA/133 abar m8192@0xf5e76000 port 0xf5e76300 irq 28
[ 0.902995] ata6: SATA max UDMA/133 abar m8192@0xf5e76000 port 0xf5e76380 irq 28
[ 0.903014] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 0.903294] ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 22
[ 0.903297] forcedeth 0000:00:0a.0: PCI INT A -> Link[LMAC] -> GSI 22 (level, low) -> IRQ 22
[ 0.903300] forcedeth 0000:00:0a.0: setting latency timer to 64
[ 0.904696] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 19
[ 0.904699] ohci1394 0000:01:08.0: PCI INT A -> Link[LNKA] -> GSI 19 (level, low) -> IRQ 19
[ 0.916757] [drm] Initialized drm 1.1.0 20060810
[ 0.963518] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[19] MMIO=[f5fff800-f5ffffff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 1.013510] usb 1-6: new high speed USB device using ehci_hcd and address 4
[ 1.152618] usb 1-6: configuration #1 chosen from 1 choice
[ 1.225516] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.229522] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.385531] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.385540] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.385545] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.385550] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.386623] ata2.00: ATA-8: ST3500413AS, JC45, max UDMA/133
[ 1.386625] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.386629] ata5.00: ATAPI: TSSTcorp CDDVDW TS-H653N, UO00, max UDMA/100, ATAPI AN
[ 1.386654] ata3.00: ATA-8: ST3500413AS, JC45, max UDMA/133
[ 1.386656] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.386668] ata1.00: ATA-8: ST3500413AS, JC45, max UDMA/133
[ 1.386670] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 1.387814] ata5.00: configured for UDMA/100
[ 1.387952] ata2.00: configured for UDMA/133
[ 1.387973] ata3.00: configured for UDMA/133
[ 1.388029] ata1.00: configured for UDMA/133
[ 1.388087] scsi 0:0:0:0: Direct-Access ATA ST3500413AS JC45 PQ: 0 ANSI: 5
[ 1.388170] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.388220] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.388238] scsi 1:0:0:0: Direct-Access ATA ST3500413AS JC45 PQ: 0 ANSI: 5
[ 1.388245] sd 0:0:0:0: [sda] Write Protect is off
[ 1.388246] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.388257] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.388310] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1.388340] sda:
[ 1.388353] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.388380] sd 1:0:0:0: [sdb] Write Protect is off
[ 1.388381] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.388394] scsi 2:0:0:0: Direct-Access ATA ST3500413AS JC45 PQ: 0 ANSI: 5
[ 1.388396] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.388473] sd 2:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.388489] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 1.388494] sd 2:0:0:0: [sdc] Write Protect is off
[ 1.388495] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 1.388511] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.388559] sdb:
[ 1.388587] sdc:
[ 1.389104] scsi 4:0:0:0: CD-ROM TSSTcorp CDDVDW TS-H653N UO00 PQ: 0 ANSI: 5
[ 1.393133] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.393136] Uniform CD-ROM driver Revision: 3.20
[ 1.393196] sr 4:0:0:0: Attached scsi CD-ROM sr0
[ 1.393226] sr 4:0:0:0: Attached scsi generic sg3 type 5
[ 1.395959] sdc1 sdc2 sdc3 sdc4
[ 1.395983] sdc: p2 size 1701679104 exceeds device capacity, limited to end of disk
[ 1.395997] sdc: p3 ignored, start 1701885952 is behind the end of the disk
[ 1.395999] sdc: p4 ignored, start 1827715072 is behind the end of the disk
[ 1.396100] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 1.400818] unknown partition table
[ 1.400917] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1.402966] sda1 sda2 sda3 sda4
[ 1.402989] sda: p2 size 1701679104 exceeds device capacity, limited to end of disk
[ 1.403003] sda: p3 ignored, start 1701885952 is behind the end of the disk
[ 1.403004] sda: p4 ignored, start 1827715072 is behind the end of the disk
[ 1.403105] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.405149] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x732 @ 1, addr 00:19:66:a2:d4:50
[ 1.405151] forcedeth 0000:00:0a.0: highdma csum pwrctl mgmt gbit lnktim msi desc-v3
[ 1.418241] nouveau 0000:04:00.0: PCI INT A -> Link[LN0A] -> GSI 19 (level, low) -> IRQ 19
[ 1.418246] nouveau 0000:04:00.0: setting latency timer to 64
[ 1.419287] vga16fb: initializing
[ 1.419290] vga16fb: mapped to 0xc00a0000
[ 1.419314] fb0: VGA16 VGA frame buffer device
[ 1.419409] [drm] nouveau 0000:04:00.0: Detected an NV50 generation card (0x450100a2)
[ 1.419868] [drm] nouveau 0000:04:00.0: Attempting to load BIOS image from PRAMIN
[ 1.518067] [drm] nouveau 0000:04:00.0: ... appears to be valid
[ 1.518069] [drm] nouveau 0000:04:00.0: BIT BIOS found
[ 1.518071] [drm] nouveau 0000:04:00.0: Bios version 60.80.06.00
[ 1.518072] [drm] nouveau 0000:04:00.0: BIT table 'A' not found
[ 1.518074] [drm] nouveau 0000:04:00.0: TMDS table revision 2.0 not currently supported
[ 1.518075] [drm] nouveau 0000:04:00.0: BIT table 'd' not found
[ 1.518076] [drm] nouveau 0000:04:00.0: Found Display Configuration Block version 4.0
[ 1.518079] [drm] nouveau 0000:04:00.0: DCB connector table: VHER 0x40 5 6 2
[ 1.518080] [drm] nouveau 0000:04:00.0: 0: 0x00001030: type 0x30 idx 0 tag 0x07
[ 1.518082] [drm] nouveau 0000:04:00.0: 1: 0x00002130: type 0x30 idx 1 tag 0x08
[ 1.518083] [drm] nouveau 0000:04:00.0: 2: 0x00000210: type 0x10 idx 2 tag 0xff
[ 1.518085] [drm] nouveau 0000:04:00.0: 3: 0x00000211: type 0x11 idx 2 tag 0xff
[ 1.518086] [drm] nouveau 0000:04:00.0: 4: 0x00000213: type 0x13 idx 2 tag 0xff
[ 1.518088] [drm] nouveau 0000:04:00.0: Raw DCB entry 0: 04000320 00000028
[ 1.518089] [drm] nouveau 0000:04:00.0: Raw DCB entry 1: 01000322 00000030
[ 1.518090] [drm] nouveau 0000:04:00.0: Raw DCB entry 2: 02011310 00000028
[ 1.518092] [drm] nouveau 0000:04:00.0: Raw DCB entry 3: 02011312 00000030
[ 1.518093] [drm] nouveau 0000:04:00.0: Raw DCB entry 4: 010223f1 00c1c020
[ 1.518101] [drm] nouveau 0000:04:00.0: Parsing VBIOS init table 0 at offset 0xB52A
[ 1.545031] usb 4-3: new low speed USB device using ohci_hcd and address 2
[ 1.553158] [drm] nouveau 0000:04:00.0: Parsing VBIOS init table 1 at offset 0xB713
[ 1.569017] [drm] nouveau 0000:04:00.0: Parsing VBIOS init table 2 at offset 0xC847
[ 1.569025] [drm] nouveau 0000:04:00.0: Parsing VBIOS init table 3 at offset 0xC8FD
[ 1.577098] [drm] nouveau 0000:04:00.0: Parsing VBIOS init table 4 at offset 0xCAAB
[ 1.577100] [drm] nouveau 0000:04:00.0: Parsing VBIOS init table at offset 0xCB10
[ 1.612001] [drm] nouveau 0000:04:00.0: 0xCB10: Condition still not met after 20ms, skipping following opcodes
[ 1.612007] [drm] nouveau 0000:04:00.0: 0xA92E: parsing output script 0
[ 1.612008] [drm] nouveau 0000:04:00.0: 0xA92E: parsing output script 0
[ 1.612010] [drm] nouveau 0000:04:00.0: 0xA0CE: parsing output script 0
[ 1.650020] xor: automatically using best checksumming function: pIII_sse
[ 1.666020] Console: switching to colour frame buffer device 80x30
[ 1.668497] pIII_sse : 14414.000 MB/sec
[ 1.668498] xor: using function: pIII_sse (14414.000 MB/sec)
[ 1.670251] device-mapper: dm-raid45: initialized v0.2594b
[ 1.767536] usb 4-3: configuration #1 chosen from 1 choice
[ 1.775978] usbcore: registered new interface driver hiddev
[ 1.781618] input: LITEON Technology USB Multimedia Keyboard as /devices/pci0000:00/0000:00:04.0/usb4/4-3/4-3:1.0/input/input3
[ 1.781654] generic-usb 0003:046D:C312.0001: input,hidraw0: USB HID v1.10 Keyboard [LITEON Technology USB Multimedia Keyboard] on usb-0000:00:04.0-3/input0
[ 1.781666] usbcore: registered new interface driver usbhid
[ 1.781667] usbhid: v2.6:USB HID core driver
[ 1.795294] [TTM] Zone kernel: Available graphics memory: 430190 kiB.
[ 1.795295] [TTM] Zone highmem: Available graphics memory: 1548178 kiB.
[ 1.795301] [drm] nouveau 0000:04:00.0: 768 MiB VRAM
[ 1.804641] [drm] nouveau 0000:04:00.0: 512 MiB GART (aperture)
[ 1.806508] [drm] nouveau 0000:04:00.0: Allocating FIFO number 1
[ 1.808558] [drm] nouveau 0000:04:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 1.808868] [drm] nouveau 0000:04:00.0: Detected a DAC output
[ 1.808869] [drm] nouveau 0000:04:00.0: Detected a TMDS output
[ 1.808871] [drm] nouveau 0000:04:00.0: Detected a DAC output
[ 1.808872] [drm] nouveau 0000:04:00.0: Detected a TMDS output
[ 1.808873] [drm] nouveau 0000:04:00.0: DCB encoder 1 unknown
[ 1.808875] [drm] nouveau 0000:04:00.0: Detected a DVI-I connector
[ 1.808914] [drm] nouveau 0000:04:00.0: Detected a DVI-I connector
[ 1.944647] device-mapper: dm-raid45: /dev/sda is raid disk 0
[ 1.944649] device-mapper: dm-raid45: /dev/sdb is raid disk 1
[ 1.944651] device-mapper: dm-raid45: /dev/sdc is raid disk 2
[ 1.944653] device-mapper: dm-raid45: 128/128/256 sectors chunk/io/recovery size, 80 stripes
[ 1.944654] algorithm "xor_64", 2 chunks with 5750MB/s
[ 1.944655] RAID5 (left symmetric) set with net 2/3 devices
[ 1.985067] [drm] nouveau 0000:04:00.0: allocated 1920x1080 fb: 0x40250000, bo f696be00
[ 1.985107] fb1: nouveaufb frame buffer device
[ 1.985108] registered panic notifier
[ 1.985111] [drm] Initialized nouveau 0.0.15 20090420 for 0000:04:00.0 on minor 0
[ 1.985122] nouveau 0000:05:00.0: enabling device (0000 -> 0003)
[ 1.985395] ACPI: PCI Interrupt Link [LN0C] enabled at IRQ 18
[ 1.985398] nouveau 0000:05:00.0: PCI INT A -> Link[LN0C] -> GSI 18 (level, low) -> IRQ 18
[ 1.985403] nouveau 0000:05:00.0: setting latency timer to 64
[ 1.986537] [drm] nouveau 0000:05:00.0: Detected an NV50 generation card (0x450100a2)
[ 1.986996] [drm] nouveau 0000:05:00.0: Attempting to load BIOS image from PRAMIN
[ 1.987017] [drm] nouveau 0000:05:00.0: ... BIOS signature not found
[ 1.987018] [drm] nouveau 0000:05:00.0: Attempting to load BIOS image from PROM
[ 2.080021] usb 3-1: new full speed USB device using ohci_hcd and address 2
[ 2.216078] ieee1394: Host added: ID:BUS[0-00:1023] GUID[008f130067270600]
[ 2.295577] usb 3-1: configuration #1 chosen from 1 choice
[ 2.608018] usb 3-3: new low speed USB device using ohci_hcd and address 3
[ 2.707075] [drm] nouveau 0000:05:00.0: ... appears to be valid
[ 2.707078] [drm] nouveau 0000:05:00.0: BIT BIOS found
[ 2.707080] [drm] nouveau 0000:05:00.0: Bios version 60.80.08.00
[ 2.707081] [drm] nouveau 0000:05:00.0: BIT table 'A' not found
[ 2.707083] [drm] nouveau 0000:05:00.0: TMDS table revision 2.0 not currently supported
[ 2.707084] [drm] nouveau 0000:05:00.0: BIT table 'd' not found
[ 2.707086] [drm] nouveau 0000:05:00.0: Found Display Configuration Block version 4.0
[ 2.707088] [drm] nouveau 0000:05:00.0: DCB connector table: VHER 0x40 5 6 2
[ 2.707090] [drm] nouveau 0000:05:00.0: 0: 0x00001030: type 0x30 idx 0 tag 0x07
[ 2.707092] [drm] nouveau 0000:05:00.0: 1: 0x00002130: type 0x30 idx 1 tag 0x08
[ 2.707093] [drm] nouveau 0000:05:00.0: 2: 0x00000210: type 0x10 idx 2 tag 0xff
[ 2.707095] [drm] nouveau 0000:05:00.0: 3: 0x00000211: type 0x11 idx 2 tag 0xff
[ 2.707097] [drm] nouveau 0000:05:00.0: 4: 0x00000213: type 0x13 idx 2 tag 0xff
[ 2.707098] [drm] nouveau 0000:05:00.0: Raw DCB entry 0: 04000320 00000028
[ 2.707100] [drm] nouveau 0000:05:00.0: Raw DCB entry 1: 01000322 00000030
[ 2.707102] [drm] nouveau 0000:05:00.0: Raw DCB entry 2: 02011310 00000028
[ 2.707103] [drm] nouveau 0000:05:00.0: Raw DCB entry 3: 02011312 00000030
[ 2.707105] [drm] nouveau 0000:05:00.0: Raw DCB entry 4: 010223f1 00c1c023
[ 2.707175] [drm] nouveau 0000:05:00.0: Adaptor not initialised
[ 2.707176] [drm] nouveau 0000:05:00.0: Running VBIOS init tables
[ 2.707217] [drm] nouveau 0000:05:00.0: Parsing VBIOS init table 0 at offset 0xB5FD
[ 2.813521] usb 3-3: configuration #1 chosen from 1 choice
[ 2.823592] input: Mouse USB Laser Mouse as /devices/pci0000:00/0000:00:02.0/usb3/3-3/3-3:1.0/input/input4
[ 2.823635] generic-usb 0003:FFC0:0040.0002: input,hidraw1: USB HID v1.11 Mouse [Mouse USB Laser Mouse] on usb-0000:00:02.0-3/input0
[ 2.836046] [drm] nouveau 0000:05:00.0: Parsing VBIOS init table 1 at offset 0xB7E6
[ 2.856022] [drm] nouveau 0000:05:00.0: Parsing VBIOS init table 2 at offset 0xC9AB
[ 2.856056] [drm] nouveau 0000:05:00.0: Parsing VBIOS init table 3 at offset 0xCA61
[ 2.864123] [drm] nouveau 0000:05:00.0: Parsing VBIOS init table 4 at offset 0xCC18
[ 2.864125] [drm] nouveau 0000:05:00.0: Parsing VBIOS init table at offset 0xCC7D
[ 2.884017] [drm] nouveau 0000:05:00.0: 0xA9B0: parsing output script 0
[ 2.884020] [drm] nouveau 0000:05:00.0: 0xA9B0: parsing output script 0
[ 2.884022] [drm] nouveau 0000:05:00.0: 0xA10C: parsing output script 0
[ 3.036419] [drm] nouveau 0000:05:00.0: 768 MiB VRAM
[ 3.045741] [drm] nouveau 0000:05:00.0: 512 MiB GART (aperture)
[ 3.047597] [drm] nouveau 0000:05:00.0: Allocating FIFO number 1
[ 3.049656] [drm] nouveau 0000:05:00.0: nouveau_channel_alloc: initialised FIFO 1
[ 3.049975] [drm] nouveau 0000:05:00.0: Detected a DAC output
[ 3.049977] [drm] nouveau 0000:05:00.0: Detected a TMDS output
[ 3.049978] [drm] nouveau 0000:05:00.0: Detected a DAC output
[ 3.049980] [drm] nouveau 0000:05:00.0: Detected a TMDS output
[ 3.049981] [drm] nouveau 0000:05:00.0: DCB encoder 1 unknown
[ 3.049983] [drm] nouveau 0000:05:00.0: Detected a DVI-I connector
[ 3.050029] [drm] nouveau 0000:05:00.0: Detected a DVI-I connector
[ 3.154518] No connectors reported connected with modes
[ 3.154522] [drm] Initialized nouveau 0.0.15 20090420 for 0000:05:00.0 on minor 1
[ 3.402793] EXT4-fs (dm-4): mounted filesystem with ordered data mode
[ 4.885689] udev: starting version 151
[ 5.256393] i2c i2c-6: nForce2 SMBus adapter at 0x2d00
[ 5.256396] ACPI: resource nForce2_smbus [0x2e00-0x2e3f] conflicts with ACPI region SM00 [0x2e00-0x2e3f]
[ 5.256398] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 5.256399] nForce2_smbus 0000:00:01.1: Error probing SMB2.
[ 5.309247] lp: driver loaded but no devices found
[ 5.316861] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 5.435173] cfg80211: Calling CRDA to update world regulatory domain
[ 5.596803] type=1505 audit(1325258100.439:2): operation="profile_load" pid=701 name="/sbin/dhclient3"
[ 5.596957] type=1505 audit(1325258100.439:3): operation="profile_load" pid=701 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 5.597044] type=1505 audit(1325258100.439:4): operation="profile_load" pid=701 name="/usr/lib/connman/scripts/dhclient-script"
[ 5.648845] HDA Intel 0000:00:07.0: power state changed by ACPI to D0
[ 5.649103] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 21
[ 5.649106] HDA Intel 0000:00:07.0: PCI INT A -> Link[LAZA] -> GSI 21 (level, low) -> IRQ 21
[ 5.649109] hda_intel: Disable MSI for Nvidia chipset
[ 5.649125] HDA Intel 0000:00:07.0: setting latency timer to 64
[ 5.763622] usbcore: registered new interface driver snd-usb-audio
[ 6.010785] phy0: Selected rate control algorithm 'minstrel'
[ 6.011157] phy0: hwaddr 00:15:af:84:13:89, RTL8187vB (default) V1 + rtl8225z2, rfkill mask 2
[ 6.021931] rtl8187: Customer ID is 0x00
[ 6.021953] Registered led device: rtl8187-phy0::tx
[ 6.021962] Registered led device: rtl8187-phy0::rx
[ 6.022423] rtl8187: wireless switch is on
[ 6.022442] usbcore: registered new interface driver rtl8187
[ 6.282853] cfg80211: World regulatory domain updated:
[ 6.282856] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.282858] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 6.282860] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 6.282861] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 6.282862] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 6.282864] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 6.288961] hda_codec: ALC889A: BIOS auto-probing.
[ 6.532067] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:07.0/input/input5
[ 6.617876] vmap allocation for size 4198400 failed: use vmalloc=<size> to increase size.
[ 6.636767] vmap allocation for size 4198400 failed: use vmalloc=<size> to increase size.
[ 6.637020] vmap allocation for size 2101248 failed: use vmalloc=<size> to increase size.
[ 6.652672] vmap allocation for size 4198400 failed: use vmalloc=<size> to increase size.
[ 6.652938] vmap allocation for size 2101248 failed: use vmalloc=<size> to increase size.
[ 6.653583] vmap allocation for size 4198400 failed: use vmalloc=<size> to increase size.
[ 6.653814] vmap allocation for size 2101248 failed: use vmalloc=<size> to increase size.
[ 7.751686] ppdev: user-space parallel port driver
[ 9.245620] vgaarb: device changed decodes: PCI:0000:05:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 9.245623] vgaarb: device changed decodes: PCI:0000:04:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 9.704128] [drm] nouveau 0000:04:00.0: Allocating FIFO number 2
[ 9.706153] [drm] nouveau 0000:04:00.0: nouveau_channel_alloc: initialised FIFO 2
[ 9.732768] [drm] nouveau 0000:04:00.0: 0xA932: parsing output script 1
[ 9.732784] [drm] nouveau 0000:04:00.0: 0x7C66: parsing clock script 0
[ 10.173947] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.214394] alloc irq_desc for 29 on node -1
[ 10.214396] alloc kstat_irqs on node -1
[ 10.214403] forcedeth 0000:00:0a.0: irq 29 for MSI/MSI-X
[ 10.214589] eth0: no link during initialization.
[ 10.214980] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 52.165592] wlan0: direct probe to AP 00:11:6b:29:a4:c4 (try 1)
[ 52.165604] wlan0: deauthenticating from 00:11:6b:29:a4:c4 by local choice (reason=3)
[ 52.166092] wlan0: direct probe to AP 00:11:6b:29:a4:c4 (try 1)
[ 52.172344] wlan0: direct probe responded
[ 52.172347] wlan0: authenticate with AP 00:11:6b:29:a4:c4 (try 1)
[ 52.178217] wlan0: authenticated
[ 52.178227] wlan0: associate with AP 00:11:6b:29:a4:c4 (try 1)
[ 52.180993] wlan0: RX AssocResp from 00:11:6b:29:a4:c4 (capab=0x431 status=0 aid=1)
[ 52.180995] wlan0: associated
[ 52.182831] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 52.305438] padlock: VIA PadLock not detected.
[ 62.364011] wlan0: no IPv6 routers present
[ 101.171541] I-pipe: Domain RTAI registered.
[ 101.171545] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 101.171547] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 101.171608] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 101.171609] PIPELINE layers:
[ 101.171611] fb3b5e20 9ac15d93 RTAI 200
[ 101.171612] c085cb20 0 Linux 100
[ 101.184481] __ratelimit: 30 callbacks suppressed
[ 101.184483] vmap allocation for size 2101248 failed: use vmalloc=<size> to increase size.
[ 101.184485] RTAI[malloc]: failed to initialize the global heap (size=2097152 bytes).
[ 103.548532] I-pipe: Domain RTAI unregistered.
[ 103.548601] RTAI[hal]: unmounted.
[ 120.371258] I-pipe: Domain RTAI registered.
[ 120.371261] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 120.371263] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 120.371324] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 120.371326] PIPELINE layers:
[ 120.371327] fe685e20 9ac15d93 RTAI 200
[ 120.371328] c085cb20 0 Linux 100
[ 120.382236] vmap allocation for size 2101248 failed: use vmalloc=<size> to increase size.
[ 120.382238] RTAI[malloc]: failed to initialize the global heap (size=2097152 bytes).
[ 122.566408] I-pipe: Domain RTAI unregistered.
[ 122.566479] RTAI[hal]: unmounted.
cnc@cnc-desktop:~$
30 Dec 2011 20:50 #16132
Replied by PCW on topic Re:EMC2 won't start, errors
also earlier:
might be related
Pretty clear trying to allocate 2101248 bytes from a 2097152 pool wont work
but why this is happening just on your system, I have no idea (above my pay grade)
also earlier:
might be related
- Arthur Dent
31 Dec 2011 02:00 #16145
by Arthur Dent
Replied by Arthur Dent on topic Re:EMC2 won't start, errors
Hmm. This might have to do with the fact that my computer has two Nvidia 8800GTX graphics cards eating all the vmalloc space (I dual boot Ubuntu and Windows 7). I guess I'll be researching how to increase vmalloc size.
- Arthur Dent
31 Dec 2011 04:02 #16147
by Arthur Dent
Solved.
Add "vmalloc=512M" between the quotes in the "GRUB_CMDLINE_LINUX_DEFAULT=" line so as to make something like:
That number probably could have been less, like 256M.
Don't forget to update Grub:
cd /etc/default
sudo gedit grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash vmalloc=512M"
sudo update-grub
28 Mar 2012 09:21 - 28 Mar 2012 09:25 #18840
by centaur
Replied by centaur on topic EMC2 won't start, errors
Hi Folks - I too am experiencing grief with starting EMC and I don't have a clue what to do. Fresh install from the latest Live CD.
At the desktop I select EMC from the applications menu and choose the Sherline 3 axis inch simulation and here is what I get (attached text file). Looking at the file but not really understanding what I'm seeing, it appears that evrything is failing.
Sure could use some guru input - Thanx
Last edit: 28 Mar 2012 09:25 by centaur.
Time to create page: 0.172 seconds
