Samba
- TarHeelTom
Anyone know is the LiveCD includes the "samba" package (which is the main packet forwarding doodad, as I understand it) ?
Tom
- TarHeelTom
See this topic
www.linuxcnc.org/index.php/english/compo...mit=6&start=12#16323
You can update some things without problems, but unless something does not work, you are just version number chasing.
I would disable all updates except for emc, or disable updates altogether.
- TarHeelTom
As this is a brand new machine, it's got nothing loaded which can't be easily replaced.
More results later.
Tom
- TarHeelTom
Is there an easy way to block Update Manager from updating the OS?
How can I recognize which files I DO NOT want to update?
How do I start samba?
How do I convince samba to start automatically each time I power up the computer?
Tom
- TarHeelTom
Doesn't the possibility exist that a server may generate some wildly fluctuating latencies? I take it you don't want a dedicated EMC2 machine then.
The server will be a desktop, located in a bedroom, to function as a second general purpose computer for the household, as well as a server. It WILL allow me to crank up EMC2 in either axis or sherline, and watch the progress of the gcode, but with no machine attached.
My garage is unheated, unless I'm running the Bridgeport. Nice to be able to run emc2 from a warmer (or cooler) location.
But you are probably right.
Tom
Tom, did you visit the link in my previous message about the OS updating?
Once configured by usually right clicking on a directory and tell it to share it samba will be there from then on.
