root password
- lendrum
- ArcEye
- Thank you received: 758
The answer is none.
Ubuntu are a complete PITA when it comes to root logins etc. They want to deny use of root for everything.
Fortunately there are ways around it.
Easiest way, from a terminal:-
$ sudo passwd root
When prompted for a password, give your user password
When prompted for the root password, give something suitable
Now enter
$ sudo passwd -u root
You will get a reply like 'password expiry info updated' or similar
Now enter
$ su root
Enter the root password when prompted
You should now have a root prompt '#' and you are ready to go.
If you use gdm, you will probably have to edit gdm.conf to allow a root login.
You may also want to go into user manager and make sure that root is a member of all groups etc.
Seem to recall not everything was ticked.
- BigJohnT
- Thank you received: 1176
- lendrum
I need root to change rtapi.conf to shut down the smi interupt that delays the real time system. Is there a better way to do that?
- BigJohnT
- Thank you received: 4997
Thanks to ArcEye for the route to the root. I will try that.
gksudo gedit will open gedit with the power to edit everything.
Note that on a 2.5 LiveCD there is an /etc/emc2/rtapi.conf file, but editing that won't help.
You need to edit /etc/linuxcnc/rtapi.conf.
(Which reminds me, I ought to fix the Wiki)
- lendrum
I tested sudo gedit and it works so the root password is not needed.
The lathe is running great now. Thanks for all your help.
- BigJohnT
- johnl2
Thanks and sorry for butting in!
- ArcEye
Wheezy asks if you want to set up a root password and then very often does nothing
These instructions will allow you to set one
www.linuxcnc.org/index.php/english/forum...rrect-password#52203
