New machine, after update CNC gone
- Soundreflections
27 Oct 2012 17:05 #25877
by Soundreflections
New machine, after update CNC gone was created by Soundreflections
I have decided to buy a new cheap machine for CNC, as I am having problems with my "lying arround" machines.
Firstly I kept getting the "busybox" prompt, saying it can't find a filesystem. The solution was to use USB adaptors on my DVD and Hard drives, then switch to internal SATA after update/upgrade.
Now I have the help files, but no programs in my "applications/CNC". How can I get CNC back?
Peet
Peet
- Soundreflections
27 Oct 2012 17:23 #25878
by Soundreflections
Replied by Soundreflections on topic New machine, after update CNC gone
I have now re-enabled linuxcnc in the repository, trying to install linuxcnc always gets me the error that there are broken packages, I do not get this error otherwise.
should I re-format and begin again?
27 Oct 2012 19:02 #25879
by BigJohnT
Replied by BigJohnT on topic New machine, after update CNC gone
Are you using an old LiveCD to install LinuxCNC with. The current one fixes some errors that occurred during the install. The iso file name should have a 3 in it.
For old computers download and use the 8.04 LiveCD.
- Soundreflections
27 Oct 2012 19:15 #25880
by Soundreflections
Hi John,
At first I thought the CD, which was fine, may be broken, so I downloaded ubuntu-10.04-linuxcnc3-i386.iso this morning. All the packages were there, I ran the latency test while upgrading, after restart it was gone.
It seems the update procedure disabled and removed it, so I re-enabled the repository, edited it to match the notice on the forum and reloaded.
Now I can select linuxcnc in synaptic, but it shows an immediate error that I can't fix.
- Soundreflections
27 Oct 2012 19:27 #25881
by Soundreflections
I am just going to re-install, then update, not upgrade to the latest LTS.
Will see how that works.
27 Oct 2012 19:39 - 27 Oct 2012 19:39 #25882
by BigJohnT
If you upgraded Ubuntu that will break everything!
You can upgrade anything but the operating system.
Last edit: 27 Oct 2012 19:39 by BigJohnT.
- Soundreflections
27 Oct 2012 19:56 #25883
by Soundreflections
Thanks,
I now have re-installed, about to update.
I have read that one should not upgrade to anything but a LTS, this was to 10.4.1 LTS, so I assumed it OK. Lesson learned.
Thanks for the help!
- Soundreflections
27 Oct 2012 21:00 #25886
by Soundreflections
I now have a new problem. My main board (MSI H61M-P20 (G3))'s SATA ports don't work on Linux, unless I do the upgrade to 12.04.1 LTS.
I can only run with a USB/serial adaptor on my HDD.
Please help - how can I update the main drivers without loosing CNC again?
I have updated all packages, Synaptic and Update manager assure me my system is up to date, but 12.04.1 LTS is available for upgrade.
27 Oct 2012 21:33 #25887
by ArcEye
Replied by ArcEye on topic New machine, after update CNC gone
Hi
There are dozens of links to that board on the Ubuntu forums but none obviously giving this info.
It might be possible to build it for 10.04, otherwise you are stuck with just running a simulator on 12.04
What is the name of driver which supports the SATA controller on your board under 12.04?My main board (MSI H61M-P20 (G3))'s SATA ports don't work on Linux, unless I do the upgrade to 12.04.1 LTS.
- Soundreflections
27 Oct 2012 22:59 #25892
by Soundreflections
How can I find out? I am not that good with Linux yet. I know that upgrading to 12.04.1 solves the problem, so Linux can handle the controllers. Maybe there is a way to find out what module it is and update that specific module?
Peet
Peet
Time to create page: 0.121 seconds
