New machine, after update CNC gone
28 Oct 2012 00:02 #25894
by ArcEye
If you do the legwork and find out which module it is, I can try to build it.
Also would need to know which exact kernel it was that worked, 12.04 lists kernels 3.2.0-23 to 3.2.0-32 and it is possible support came in somewhere in that range and might not have been present initially.
Replied by ArcEye on topic New machine, after update CNC gone
You need to build the module against the 10.04 kernel, so need the source code. The module built for 12.04 will not work.Maybe there is a way to find out what module it is and update that specific module?
The Ubuntu forum search engine will be what you needHow can I find out?
28 Oct 2012 18:59 #25936
by ArcEye
Does this help?
Looks like someone installed 11.04 OK once the BIOS setting for SATA were amended
askubuntu.com/questions/62904/clean-install-hd-problems
Another reference also speaks of changing BIOS SATA setting from 'Compatibility' to AHCI to enable a HDD to be recognised, so perhaps see what you can achieve with BIOS changes first?
The following user(s) said Thank You: Soundreflections
- Soundreflections
28 Oct 2012 23:18 #25948
by Soundreflections
Replied by Soundreflections on topic New machine, after update CNC gone
Hi ArcEye,
Thank you so much! I have just come back from a open day at my flying club (radio control), and saw your post.
Set SATA to AHCI, system boots fine now on own SATA port!
Now to find out if I followed the right procedures before posting that my machine setup won't work!
Again thanks!
Regards
Peet
Again thanks!
Regards
Peet
Time to create page: 0.162 seconds
