New install
23 Apr 2013 01:06 #33015 by mtlservices
New install was created by mtlservices
I am trying to install Linux CNC 2.5.0 on a new computer. I downloaded file from site. Went to check if The MD5SUM of the CD is 76dc2416b917679b71255e464ede84ec) is present and it said that it is did not match. Where do I go from here.
23 Apr 2013 04:16 - 23 Apr 2013 04:16 #33026 by BigJohnT
Replied by BigJohnT on topic New install
Download the ISO again and read the Getting Started Guide for instructions.
Last edit: 23 Apr 2013 04:16 by BigJohnT.
23 Apr 2013 08:07 #33036 by mtlservices
Replied by mtlservices on topic New install
I dont see any getting started instructions on this link only this 1. The Software
2. The Operating System
3. Getting Help
3.1. IRC
3.2. Mailing List
3.3. LinuxCNC Wiki
4. Getting LinuxCNC
4.1. Normal Download
4.2. Multi-session Download
4.3. Burning the CD
4.4. Testing LinuxCNC
4.5. Installing LinuxCNC
4.6. Updates to LinuxCNC
23 Apr 2013 17:12 #33048 by ArcEye
Replied by ArcEye on topic New install
Hi
The links are there
Try going to www.linuxcnc.org/index.php/download which repeats and links to the relevant bits
Sequence is simply
Download iso
Check iso with md5sum
Burn iso to CD
Boot CD and Install
If you are trying to download from a windoze machine, try right clicking and 'Save As', sometimes IE especially corrupts downloads by trying to be clever.
24 Apr 2013 23:20 #33152 by mtlservices
I have tried to download in three different computers and when I check the sum it is never the same. It does not have a save as option only a save option. It saves it in my downloads.
24 Apr 2013 23:49 #33154 by ArcEye
All I can suggest is that you burn the .iso to CD and see if it boots
Just be sure you burn direct from the .iso and don't drag and drop it into some windoze GUI that then creates another .iso with that one inside it.
Google whatever software you have to find how, I only know about linux
30 Apr 2013 03:51 #33406 by mtlservices
I downloaded software from linux. The MD5SUM number matched. So I burn image file to DVD. I formatted a new hard drive and tried to boot from DVD. I gives me message could not find a file. I just do not understand why I am having so much problems with such a simple task.
30 Apr 2013 06:28 #33416 by BigJohnT
Did you follow the instructions here?
www.linuxcnc.org/docs/html/common/Gettin...ml#_getting_linuxcnc
30 Apr 2013 07:24 #33420 by mtlservices
I have tried these instructions at least four times.
30 Apr 2013 14:53 - 30 Apr 2013 15:09 #33426 by ArcEye
We can't assist without some more info
Which version of the Live CD?
Onto what computer?
What precisely was the message and when exactly did it occur?
PS
Why did you use a DVD?
If it was because the image would not fit on a CD, you have probably done what I warned about in post 33154
Last edit: 30 Apr 2013 15:09 by ArcEye.
Time to create page: 0.099 seconds
