New install
- Rick G
- Thank you received: 155
30 Apr 2013 17:16 #33431
by Rick G
Replied by Rick G on topic New install
Are you running windows?
Did you...
It seems in the past some have copied the file to a CD instead of burning the image. Not the same thing.
Rick G
Did you...
Burning the ISO in Windows
1. Download and install Infra Recorder, a free and open source image burning program: infrarecorder.org/
2. Insert a blank CD in the drive and select Do nothing or Cancel if an auto-run dialog pops up.
3. Open Infra Recorder, and select the Actions menu, then Burn image.
Rick G
- Thank you received: 4966
30 Apr 2013 19:55 #33437
Perhaps someone in the US could send you a CD?
Replied by andypugh on topic New install
I have tried these instructions at least four times.
- BigJohnT
- Thank you received: 1175
30 Apr 2013 20:43 #33441
by BigJohnT
It does sound like your skipping a step or something else. If the md5sum is different each time use the wget method to download the file. Use a CD. Use the proper method to burn the ISO to the disk not copy the file to the disk. Use the recommended software and methods to burn the ISO to the disk.
Where are you located?
Replied by BigJohnT on topic New install
- TarHeelTom
30 Apr 2014 04:18 #46483
by TarHeelTom
Replied by TarHeelTom on topic New install
I've been trying all day to install infrarcorder, and it appears to be full of virus or virii, or something.
I'm now attempting to install "Free DVD ISO Burner" from cjnet. Time will tell if it works or not.
Tom
Tom
Time to create page: 0.114 seconds
