PRECISE 12.04
07 Feb 2014 04:53 #43614 by tld70
PRECISE 12.04 was created by tld70
Hello,
I have done a install with exactly this document: wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
What I teste it worke exept the update with the update manager ( I dont know the word for the english function )
The Error is: Installation von Paketen erforderlich, denen nicht vertraut werden kann
Diese Aktion würde die Installation von Paketen aus nicht authentifizierten Software-Paketquellen erfordern.
Does somebody have a hint?
Best regards
Thomas
07 Feb 2014 15:30 - 07 Feb 2014 17:37 #43622 by ArcEye
Replied by ArcEye on topic PRECISE 12.04
Installation of packages required, which can not be trusted
This action would require the installation of packages from unauthenticated software package sources.
The error is the source packages are not signed, or do not have a gpg key.
What is it you are trying to update?
If it is Sebs kernel packages, I think he still has not signed them.
Do apt-get update && apt-get upgrade from a terminal and you should be able to override the default N/y to install
Last edit: 07 Feb 2014 17:37 by ArcEye.
The following user(s) said Thank You: tld70
07 Feb 2014 23:01 #43624 by tld70
Replied by tld70 on topic PRECISE 12.04
Thank you
this works.
Now is the next problem
the path lib/firmware/hm2 is not present,
where can I get the actual firmwares or how to install?
Thomas
08 Feb 2014 00:29 #43625 by ArcEye
Go to
buildbot.linuxcnc.org/hm2/dists/hm2-firmware/
and choose the appropriate flavour
08 Feb 2014 15:11 #43635 by tld70
Thanks, it works,
but now is a different problem:
axis-remote crashed with TclError in_init_(): coudldn't connect to display":0.0"
08 Feb 2014 15:29 #43636 by ArcEye
I suspect you are connecting remotely via ssh?
If so, likely to be an X forwarding problem, need some idea exactly what you are doing
08 Feb 2014 16:19 #43638 by tld70
I only installed a new systen to test in VM Ware
noc ssh connection, just start Linuxcnc and after some seconds much alarms occur ( like this i wrote )
in the moment all works,
I think this all was "1 time alarms"
hopefully it works now
Thomas
08 Feb 2014 19:45 #43641 by ArcEye
If you are running through a virtual machine, then again probably a X forwarding error rather than anything to do with linuxcnc.
It can be very sensitive, if you open 2 ssh connections to a remote host, sometimes you get reams of errors to do with being unable to resolve display etc.
I seem to be limited to 1 forwarded X display log in and 1 text login when I access my server
09 Feb 2014 19:12 #43657 by yvobrico
Replied by yvobrico on topic PRECISE 12.04
New in this excellent forum, I'm using linuxcnc for 2 years now.
I just used the same instructions to get linuxcnc on 12.10 from a brand new installation (new machine) : wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
Everything went well up to the reboot step : when I check the real time kernel using "uname -r", I still get : 3.8.0-35-generic, and not the new one : 3.4.55-rtai-2
What is the way to force linux to use the new one ? I suppose there is another file to update ?
Regards
09 Feb 2014 20:19 #43660 by ArcEye
If you weren't offered a choice of kernels including the new one, then you probably did not do update-grub before rebooting
Time to create page: 0.364 seconds
