PRECISE 12.04
I have done a install with exactly this document: wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
What I teste it worke exept the update with the update manager ( I dont know the word for the english function )
The Error is: Installation von Paketen erforderlich, denen nicht vertraut werden kann
Diese Aktion würde die Installation von Paketen aus nicht authentifizierten Software-Paketquellen erfordern.
Does somebody have a hint?
Best regards
Thomas
Installation of packages required, which can not be trusted
This action would require the installation of packages from unauthenticated software package sources.
The error is the source packages are not signed, or do not have a gpg key.
What is it you are trying to update?
If it is Sebs kernel packages, I think he still has not signed them.
Do apt-get update && apt-get upgrade from a terminal and you should be able to override the default N/y to install
this works.
Now is the next problem
the path lib/firmware/hm2 is not present,
where can I get the actual firmwares or how to install?
Thomas
but now is a different problem:
axis-remote crashed with TclError in_init_(): coudldn't connect to display":0.0"
If so, likely to be an X forwarding problem, need some idea exactly what you are doing
noc ssh connection, just start Linuxcnc and after some seconds much alarms occur ( like this i wrote )
in the moment all works,
I think this all was "1 time alarms"
hopefully it works now
Thomas
It can be very sensitive, if you open 2 ssh connections to a remote host, sometimes you get reams of errors to do with being unable to resolve display etc.
I seem to be limited to 1 forwarded X display log in and 1 text login when I access my server
New in this excellent forum, I'm using linuxcnc for 2 years now.
I just used the same instructions to get linuxcnc on 12.10 from a brand new installation (new machine) : wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
Everything went well up to the reboot step : when I check the real time kernel using "uname -r", I still get : 3.8.0-35-generic, and not the new one : 3.4.55-rtai-2
What is the way to force linux to use the new one ? I suppose there is another file to update ?
Regards
