Can't seem to fit the iso onto a cd
- steveharr
26 Mar 2014 01:54 #45249
by steveharr
Can't seem to fit the iso onto a cd was created by steveharr
Hello, I'm having trouble fitting the ISO onto a CD. The CD seems to be about 4 MB short of space!
Anyone else have this issue, is there a way to solve it?
Steve.
Steve.
- ArcEye
- Thank you received: 758
26 Mar 2014 02:29 #45251
by ArcEye
Replied by ArcEye on topic Can't seem to fit the iso onto a cd
Hi
This happens when people use windoze to burn the CD normally.
You need a program which burns a CD from the iso image, not a drag and drop file burner, which treats the iso as a file and then creates another iso from it and the result is too big to fit the CD
- ArcEye
26 Mar 2014 02:34 #45252
by ArcEye
See this post with details of a windoze program that works and how to use it
www.linuxcnc.org/index.php/english/forum...stall?start=10#33431
- BigJohnT
- Thank you received: 1175
26 Mar 2014 05:11 #45264
by BigJohnT
There is a step by step to burn the ISO to the CD in the online manual as well as on the download page.
www.linuxcnc.org/docs/html/common/Getting_EMC.html
JT
Replied by BigJohnT on topic Can't seem to fit the iso onto a cd
Steve.
JT
- steveharr
26 Mar 2014 16:22 - 26 Mar 2014 16:32 #45272
by steveharr
Replied by steveharr on topic Can't seem to fit the iso onto a cd
Those were the instructions I followed, tried three times, didn't work either time. I have burned plenty of bootable cd's from disk images in the past, but this doesn't seem to work. I tried: infrarecorder, ImgBurn and CDBurnerXP. All have the facility to burn ISO image to disc. All had the same problem. And the MD5 sum checked out.
Last edit: 26 Mar 2014 16:32 by steveharr.
- BigJohnT
26 Mar 2014 18:24 #45274
by BigJohnT
I do see that there is a different version on the web site than I have.
My current version is:
ubuntu-10.04-linuxcnc2-i386.iso
vs what is on the web site
ubuntu-10.04-linuxcnc3-i386.iso
I can't download anything so someone else will have to verify the current version.
JT
JT
- steveharr
26 Mar 2014 19:16 #45277
by steveharr
I downloaded the one with 'linuxcnc3'
- ArcEye
26 Mar 2014 23:18 #45284
by ArcEye
That is the latest one I have
MD5SUM = 76dc2416b917679b71255e464ede84ec
File size 709820K (693 MB)
Burnt to CD just fine using wodim (cdrecord fork)
- Thank you received: 4904
27 Mar 2014 07:25 #45297
(74 or 80 minutes)
en.wikipedia.org/wiki/CD-ROM#CD-ROM_format
I don't recall how big the ISO is.
Replied by andypugh on topic Can't seem to fit the iso onto a cd
Some CDs have more capacity than others.Hello, I'm having trouble fitting the ISO onto a CD..
(74 or 80 minutes)
- ArcEye
27 Mar 2014 13:49 - 27 Mar 2014 13:50 #45304
by ArcEye
Andy Pugh wrote:
You need a 700MB 80min CD-R, the 640MB 70min ones have been obsolete for years.
Last edit: 27 Mar 2014 13:50 by ArcEye.
Time to create page: 0.482 seconds
