Problem installing on Jetway NF99FL-525
11 Dec 2014 00:45 #53885 by richardb
Replied by richardb on topic Problem installing on Jetway NF99FL-525
Well, to quote another famous computer, "I'm sorry, ArcEye, but I can't do that".
The system shuts down rather than hangs, so the console window only shows up for a second before the system powers off.
I did notice that the last bit of text on screen seems to be something about the network manager, though. After that I get a blank screen with a mouse icon in the middle, then it goes to the text screen with the shutdown details.
Not sure if that is helpful, but there you go.
11 Dec 2014 01:05 - 11 Dec 2014 01:06 #53888 by ArcEye
Replied by ArcEye on topic Problem installing on Jetway NF99FL-525
If only it was a HAL 9000, it could tell us what was wrong :laugh:
The fact that it shuts down in normal boot suggests there is something terminal with the network driver.
I would be tempted if it were me, to go back to plan A), albeit for a different reason and try an install of a standard Debian Wheezy distro
If that does not work, it is a debian thing, if it does it is something different in the way the 3.4.9 kernel was built possibly.
At least we will know what way to look
As I said, just a cursory search threw up some quite major bugs in the driver with debian, some 2012 but others the summer of this year
Before doing that however, boot into recovery mode
Then from the terminal
/etc/init.d/networking restart
and see what that produces
Also the output from
ifconfig
Last edit: 11 Dec 2014 01:06 by ArcEye.
11 Dec 2014 01:19 #53890 by richardb
Hah, if it was Hal, it would work, but use the CNC to try and kill me as soon as it was running, then tell me to take a stress pill afterwards.
Okay, tried the network restart thing. Got two things: a message about restart being deprecated because it may not re enable some devices and another msg about "reconfiguring network interfaces...done".
Config shows just the loopback interface.
I will try the vanilla Debian install later on today.
11 Dec 2014 11:02 #53904 by richardb
Okay, I tried the standard debian install (from www.debian.org/releases/stable/debian-installer/) and it installed fine with no issues. Network works, no halts or crashes and no explosions.
So, i am guessing that this has newer drivers or something similar. How do I check that?
11 Dec 2014 15:36 - 11 Dec 2014 19:44 #53908 by ArcEye
I'll have a look at the two kernels and their modules.
It may have to go to the developer who maintains the kernel part of the .iso, no point doing a local fix if it affects all such chips
EDIT
PS
For completeness please do a lspci -vv > lspci-stock.txt with the stock Debian install, just to check it is the e1000e driver in use etc and ls -R -l /lib/modules > modules.txt && ls -R -l /lib/firmware > firmware.txt
Probably best to zip all 3 prints into one archive and attach that
Last edit: 11 Dec 2014 19:44 by ArcEye.
12 Dec 2014 07:26 #53943 by richardb
Sure, here you go. Please let me know what you think: I am eager to get this system up and running.
13 Dec 2014 00:40 #53970 by ArcEye
Hi
Got those thanks.
Interestingly the video chip is not the one the spec sheet detailed and is dealt with by the normal Intel i915 driver,
00:02.0 VGA compatible controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (rev 02) (prog-if 00 [VGA controller])
Kernel driver in use: i915
Both ethernet chips are using the e1000e driver and you seem to have the right drivers built in /lib/modules
You have very few entries in /lib/firmware
If you have an intel processor, you probably need to install firmware-linux-nonfree anyway, because it contains the intel-microcode.
None of this affects the ethernet chips though.
I have contacted the developer who built the kernel and am waiting on a reply.
Over the weekend I will try to build the Intel update code and the kernel 3.2.0-4 code against the 3.4.9-rtai kernel, so that you can substitute them for your existing ones and see if they work
The following user(s) said Thank You: richardb
13 Dec 2014 05:07 #53978 by richardb
Sounds good. This MB is really designed for networking stuff, so I it only has a VGA output. But it is what I have to hand, so in it goes. Let me know when you have a new build and I'll be happy to test it.
13 Dec 2014 20:41 #53990 by ArcEye
Hi
Attached is the e1000e driver I built with the 3.4.55-rtai kernel recently.
3.4.55 is essentially the same kernel as used for the 3.4.9-rtai kernel in the debian.iso
I have tested loading it under 3.4.9-rtai and it loads OK
[ 1629.540973] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 1629.540976] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
Of course I do not have the ethernet chip to test it with though.
File Name: e1000e-3.4.55.zip
File Size:1,062 KB
I tried building the latest Intel driver from their site, but it errored on loading with an undefined reference to functions that should be integral to the driver, so not sure what they have done there.
Reinstall the 3.4.9-rtai based distro and boot in through recovery mode
Rename /lib/modules/3.4-9-rtai-686-pae/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko to e1000e.ko.old
Copy the e1000e.ko driver in the zip to that location in its place
Given the problems you had, only proper way to test will be to reboot , select the normal boot option and see if it stays up and the ethernet link comes up
14 Dec 2014 00:29 #53993 by ArcEye
This is the e1000e driver built from the kernel 3.2.0-4 sources ( the stock debian kernel that worked )
Again built against my 3.4.55-rtai kernel and tested on the 3.4.9-rtai kernel in the debian distro and loads OK
Instructions same as for the previous one
Time to create page: 0.146 seconds
