Linux CNC and Xunbutu
- metal89
24 Apr 2015 18:49 #58081
by metal89
Linux CNC and Xunbutu was created by metal89
I am new to Linux world.
Is it possible to install Linux CNC on Xunbutu?
If yes how have I to proceed because I'm not a "sudo" warrior.
Regards
Regards
- Thank you received: 4951
24 Apr 2015 20:30 #58083
I have it running on Lubuntu, and that was fairly easy.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Instal...ed_LinuxCNC_packages
Follow the instructions there (or change the URL to say "precise" if you are on 14.04)
Replied by andypugh on topic Linux CNC and Xunbutu
- metal89
24 Apr 2015 23:30 #58087
by metal89
Replied by metal89 on topic Linux CNC and Xunbutu
- metal89
25 Apr 2015 00:08 #58088
by metal89
I attached a screenshot of the dependencies that are lacking.
25 Apr 2015 00:09 #58089
Hmm, I see.
Well, all it is really doing is setting up the software sources, which you can do by hand.
However, I just noticed that I don't know what version of Xubuntu you are using. Is your version of Xubuntu based on Precise Pangolin, Lucid Lynx or Trusty Tahr?
the lucid script aborts on Xunbutu.
Hmm, I see.
- metal89
25 Apr 2015 03:39 #58093
by metal89
Xubuntu 14.04 Trusty
See attachment for details
my desktop is Xfce 4.10
Patrick
Patrick
25 Apr 2015 04:14 #58097
That is likely to be fun.
You are probably going to have to compile LinuxCNC from source. (not actually very difficult) but the real problem is likely to be the realtime kernel.
Which kernel version does 14.04 need?
- metal89
25 Apr 2015 13:08 #58105
by metal89
the kernel is 3.16.0
see attachment for full details
25 Apr 2015 20:14 #58112
Well, there _is_ someone running LinuxCNC on an RTAI version of that kernel:
mail.rtai.org/pipermail/rtai/2014-December/026592.html
How much of a voyage of discovery do you fancy?
- Thank you received: 5123
25 Apr 2015 21:58 #58118
Replied by PCW on topic Linux CNC and Xunbutu
If you are building on a unsupported distribution,, Preemt-RT realtime kernels are
typically easier to build than RTAI based kernels, however Preemt-RT typically has worse
latency figures than RTAI.
If you are doing software stepping, RTAI is best. If you have a servo system or a hardware
step generator. Preemt-RT is fine. Preemt-RT is probably ok for software
stepping if you have recent (and fast) hardware:
freeby.mesanet.com/h97-g3258-preemt-rt.png
Time to create page: 0.114 seconds
