Linux CNC and Xunbutu
25 Apr 2015 23:09 #58120 by metal89
Replied by metal89 on topic Linux CNC and Xunbutu
Some information to enlarge the picture.
1/ Model engineering is one of my hobby and I would like to upgrade a chinese bench mill to CNC. So I don't need an Indy 500 racing CNC. Accuracy is better than speed for me.
2/ I plan to use a pcDuino to manage the stepper motors. pcDuino works with Linux Unbuntu. That's the reason of the choice of Xubuntu.
The problem is that I am not a seasoned user of Linux . I am not skilled enough to tweak the kernel by myself . For that reason I need trusty step by step process.
Patrick
25 Apr 2015 23:11 #58121 by metal89
Patrick
25 Apr 2015 23:46 - 25 Apr 2015 23:46 #58123 by PCW
Replied by PCW on topic Linux CNC and Xunbutu
I would not suggest this route unless you want to spend a lot of time on kernel issues
a BBB and machinekit is a better starting point if you want a working ARM based CNC system
and not an adventure in bleeding edge kernel hacking
Last edit: 25 Apr 2015 23:46 by PCW.
26 Apr 2015 01:44 #58125 by metal89
I guess that BBB=Beaglebone Black
I found that BBB preloaded with Debian
Is it OK?
I suppose that "machinekit" is that one
I have to learn BBB from scratch. Would mind to help me find a smart place to start?
Patrick
26 Apr 2015 01:47 #58126 by metal89
sorry BBB link missing
26 Apr 2015 01:50 #58127 by metal89
Don't know what happened
BBB from Adafruit
www.adafruit.com/product/1876
26 Apr 2015 16:05 - 26 Apr 2015 16:07 #58131 by ArcEye
Replied by ArcEye on topic Linux CNC and Xunbutu
Is it OK?
Patrick
This is the forum
groups.google.com/forum/#!forum/machinekit
Most of the BBB's use Debian with a Xenomai kernel, there are pre-built images you can download,
don't buy one with an image, it won't be the right one.
They use capes to add IO, step generation etc.
You just need to take time to work through the site and then search the forum posts.
Last edit: 26 Apr 2015 16:07 by ArcEye.
The following user(s) said Thank You: metal89
Time to create page: 1.094 seconds
