How to Install Debian 8.2 "Jessie" and LinuxCNC2.7
- Thank you received: 5325
08 Feb 2016 22:43 - 11 Feb 2016 14:39 #69791
Replied by PCW on topic How to Install Debian 8.2 "Jessie" and LinuxCNC2.7
Depends on the hardware, in my experience Preempt-RT has similar latency to RTAI on fast hardware
(Sandy bridge range) and significantly worse latency that RTAI on slow hardware ( Intel Atoms etc )
Last edit: 11 Feb 2016 14:39 by PCW.
- vre
- Thank you received: 17
08 Feb 2016 23:15 - 09 Feb 2016 00:42 #69793
by vre
Replied by vre on topic How to Install Debian 8.2 "Jessie" and LinuxCNC2.7
RTAI linuxcnc will be available for jessie i386 or amd64 ?
repos here are empty
linuxcnc.org/dists/jessie/2.7-rtai/
Last edit: 09 Feb 2016 00:42 by vre.
- jepler
- User is blocked
- Thank you received: 33
09 Feb 2016 03:05 #69813
by jepler
Replied by jepler on topic How to Install Debian 8.2 "Jessie" and LinuxCNC2.7
Unfortunately, subsequent to the original announcement of an RTAI kernel that works on Debian Jessie, we found that the kernels (32- and 64-bit) both regularly crash the buildbot system. (buildbot is both our continuous integration system as well as our package building system) so those "builders" have been disabled until someone comes up with a solution.
As a result, we aren't able to offer pre-built linuxcnc packages for those configurations at the moment.
It is not clear whether this problem affects "real" systems, because in our buildbot, each OS we build for is running virtualized (by qemu, I think). So at the moment you can download the kernel images from us as .deb packages, but you'll need to do your own (RIP) build of LinuxCNC. To me, it looked a little bit like the error might only occur when running as a VM on a very overloaded host, but I don't know for certain and I haven't installed this kernel on a non-virtual system (or even a virtual one for that matter)
- Amedee
- Thank you received: 13
09 Feb 2016 09:08 #69827
by Amedee
Replied by Amedee on topic How to Install Debian 8.2 "Jessie" and LinuxCNC2.7
Interesting...
So far, my Jessie/RTAI is stable and never crashed, but apart from running latency tests and configuring LinuCNC I haven't done any real work with it as I'm learning LinuxCNC and building my router at the same time...
- vre
11 Feb 2016 14:33 #69992
by vre
From which repo have you downloaded-intalled jessie/rtai ?
Interesting...
- Amedee
11 Feb 2016 14:53 - 11 Feb 2016 14:53 #69994
by Amedee
Last edit: 11 Feb 2016 14:53 by Amedee.
- mstrick96
11 Feb 2016 15:58 #69997
by mstrick96
Replied by mstrick96 on topic How to Install Debian 8.2 "Jessie" and LinuxCNC2.7
As Inunderstand it, Jessie's kernel is not real time. Doesn't this mean the latency is going to be too high?
I I have LinuxCNC running well on Jessie now, but only with the standard kernel. When I replaced the kernel with the real time kernel from Wheezy, it didn't work well with my wifi.
Does anyone have a real time kernel running well on Jessie with LinuxCNC?
- Amedee
11 Feb 2016 17:13 #70001
by Amedee
Same answer than my post above
Time to create page: 0.680 seconds
