What Rtai Kernel needed?
24 Oct 2015 03:38 #64197 by Holzwurm56
What Rtai Kernel needed? was created by Holzwurm56
I was not able to install LinuxCNC 2.6 Debian on my pc, so I have install Ubuntu 12.04 and then LinuxCNC 2.6. Then I install the rtai pae kernel. When boot in rtai mode the pc will not work. Maybe the pc is not able to work in pae mode. Is there an rtai kernel available without pae?
Hans
24 Oct 2015 05:03 #64199 by BigJohnT
Replied by BigJohnT on topic What Rtai Kernel needed?
Try the LinuxCNC 2.5 LiveCD with Ubuntu 10.04. You can upgrade to 2.7 after that. If you have older hardware you need older operating system.
JT
24 Oct 2015 22:53 #64221 by Holzwurm56
Replied by Holzwurm56 on topic What Rtai Kernel needed?
Hi BigJohnT,
I do so but its failed, when updating to 2.6 the software does not work with the old rtai kernel.
Hans
24 Oct 2015 23:19 #64223 by BigJohnT
What makes you think the kernel is bad?
You can upgrade from 2.5 to 2.7 without changing any kernels if you follow the upgrade instructions on the wiki.
wiki.linuxcnc.org/cgi-bin/wiki.pl
JT
25 Oct 2015 01:34 #64233 by Holzwurm56
another question. Does someone know why the livecds uses now Debian and not Ubuntu?
Hans
25 Oct 2015 05:46 #64241 by BigJohnT
Did I solve the first issue yet?
Debian was chosen for some good reason and I'm glad Ubuntu 12.04 really looked like a tablet interface to me.
JT
25 Oct 2015 14:39 #64244 by Holzwurm56
Hi BigJohnT,
I am now desparing. O. K. my computer was old and I take a newer computer. I installed LinuxCNC 2.6 and when I start the computer first time I get the message "wrong password", I install sometimes new the same. I download 2.7 with the LiveCD, make the install, start "wrong password". So I am test two days to install LinuxCNC with Debian and was not sucsessfull.
With the Linuxcnc 2.5 Ubuntu-livecd im 10 minutes was the installing perfekt.
Hans
25 Oct 2015 17:38 #64247 by cncbasher
Replied by cncbasher on topic What Rtai Kernel needed?
where is it asking for a password ? on startup or when wanting root access
did you insert username and password at time of install ?
25 Oct 2015 19:02 #64251 by Holzwurm56
the question for password is by statup. When I install I insert username and password.
Hans
25 Oct 2015 19:05 #64252 by BigJohnT
When you start Debian Wheezy it does not ask for your password first. It asks for your user name first then your password. Another annoying feature of backwards progress...
JT
