ISO install of LinuxCNC on Debian 8 & Mint LMDE 2
10 years 7 months ago #72220 by cncnoob1979
cncbasher,
I just tired to get all the dependencies installed for Glade 2. Needless to say - I got to into dependency H*** about 4 hours worth.
Looks like i'm going back to Wheezy. My main goal would be to use the highest operating system and still be able to update via the build bot .. and use glade 2 for editing panels. So far the only contender will be Wheezy at the moment. Unless someone else has a suggestion. I love Linux Mint.. I hate wheezy...
10 years 7 months ago #72221 by newbynobi
@cncnoob1979
I have glade-gtk2 running fine on Jessie!
Here are the sources:
Glade3-gtk2 Source
Use Glade3-3.8.5 as all lower releases are buggy.
After installing you have to start glade with the command glade-gtk2, otherwise the standard glade will start.
Here is a very good tutorial in Spanish, I followed that one.
If you need the GladeVCP widgets, you will have to copy them from the link mentioned on that page.
Good luck.
Norbert
10 years 7 months ago #72229 by islander261
well I tried to get glade as described above but things must not have worked out right. when I thought I was finished with install I tried this:
jd@plasma1 ~ $ glade-gtk2 glade-gtk2: command not found
so then I tried the test from the tut:
jd@plasma1 ~ $ glade-3 (glade-3:21981): GladeUI-CRITICAL **: Unable to load module 'gladegnome' from any search paths (glade-3:21981): GladeUI-WARNING **: Could not find glade_gtk_widget_depends in /usr/local/lib/glade3/modules/libgladegtk.so or in global namespace GladeUI-Message: No displayable values for property GtkToolPalette::icon-size GladeUI-Message: No displayable values for property GtkToolItemGroup::ellipsize GladeUI-Message: No displayable values for property GtkToolItemGroup::header-relief (glade-3:21981): GladeUI-WARNING **: Could not find glade_gtk_entry_depends in /usr/local/lib/glade3/modules/libgladegtk.so or in global namespace (glade-3:21981): GladeUI-WARNING **: Could not find glade_gtk_size_group_depends in /usr/local/lib/glade3/modules/libgladegtk.so or in global namespace (glade-3:21981): GladeUI-WARNING **: Could not find glade_gtk_treeview_depends in /usr/local/lib/glade3/modules/libgladegtk.so or in global namespace (glade-3:21981): GladeUI-CRITICAL **: Unable to load module 'gladegnome' from any search paths (glade-3:21981): GladeUI-WARNING **: Failed to load external library 'gladegnome' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_app_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeApp" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeApp' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_druid_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeDruid" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeDruid' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_druid_page_edge_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeDruidPageEdge" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeDruidPageEdge' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_druid_page_standard_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeDruidPageStandard" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeDruidPageStandard' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_icon_selection_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeIconSelection" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeIconSelection' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_icon_entry_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeIconEntry" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeIconEntry' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_href_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeHRef" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeHRef' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_date_edit_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeDateEdit" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeDateEdit' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_app_bar_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeAppBar" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeAppBar' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_dialog_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeDialog" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeDialog' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_about_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeAbout" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeAbout' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_message_box_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeMessageBox" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeMessageBox' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_property_box_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomePropertyBox" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomePropertyBox' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_entry_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeEntry" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeEntry' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_file_entry_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeFileEntry" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeFileEntry' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_pixmap_entry_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomePixmapEntry" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomePixmapEntry' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_color_picker_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeColorPicker" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeColorPicker' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_font_picker_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeFontPicker" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeFontPicker' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_pixmap_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomePixmap" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomePixmap' (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeApp' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeDruid' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeIconSelection' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeHRef' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeDateEdit' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeIconEntry' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeAppBar' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeDialog' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeAbout' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeMessageBox' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomePropertyBox' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeEntry' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeFileEntry' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomePixmapEntry' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeColorPicker' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeFontPicker' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomePixmap' in a widget group (glade-3:21981): GladeUI-CRITICAL **: Unable to load module 'gtksourceview-2.0' from any search paths (glade-3:21981): GladeUI-WARNING **: Failed to load external library 'gtksourceview-2.0' (glade-3:21981): GladeUI-CRITICAL **: Unable to load module 'gladegnome' from any search paths (glade-3:21981): GladeUI-WARNING **: Failed to load external library 'gladegnome' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "bonobo_dock_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "BonoboDock" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'BonoboDock' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "bonobo_dock_item_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "BonoboDockItem" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'BonoboDockItem' (glade-3:21981): GladeUI-CRITICAL **: Unable to load module 'gladegnome' from any search paths (glade-3:21981): GladeUI-WARNING **: Failed to load external library 'gladegnome' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_canvas_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeCanvas" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeCanvas' (glade-3:21981): GladeUI-WARNING **: We could not find the symbol "gnome_icon_list_get_type" (glade-3:21981): GladeUI-WARNING **: Could not get the type from "GnomeIconList" (glade-3:21981): GladeUI-WARNING **: Failed to load the GType for 'GnomeIconList' (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeCanvas' in a widget group (glade-3:21981): GladeUI-WARNING **: Tried to include undefined widget class 'GnomeIconList' in a widget group GladeUI-Message: Glade needs artwork; a default icon will be used for the following classes: HAL_CheckButton needs an icon named 'widget-gladevcp-hal_checkbutton' EMC_FileChooserButton needs an icon named 'widget-gladevcp-vcp_filechooserbutton' HAL_Button needs an icon named 'widget-gladevcp-hal_button' EMC_FileChooserDialog needs an icon named 'widget-gladevcp-vcp_filechooserdialog' HAL_HBox needs an icon named 'widget-gladevcp-hal_hbox' HAL_Graph needs an icon named 'widget-gladevcp-hal_graph' HAL_RadioButton needs an icon named 'widget-gladevcp-hal_radiobutton' HAL_HScale needs an icon named 'widget-gladevcp-hal_hscale' HAL_GremlinPlus needs an icon named 'widget-gladevcp-hal_gremlin_plus' HAL_ToggleButton needs an icon named 'widget-gladevcp-hal_togglebutton' GtkSourceView needs an icon named 'widget-gtksourceview-gtksourceview' OffsetPage needs an icon named 'widget-gladevcp-offsetpage' HAL_ProgressBar needs an icon named 'widget-gladevcp-hal_progressbar' PyNgcGui needs an icon named 'widget-gladevcp-pyngcgui' HAL_Label needs an icon named 'widget-gladevcp-hal_label' EMC_SourceView needs an icon named 'widget-gladevcp-vcp_sourceview' HAL_ComboBox needs an icon named 'widget-gladevcp-hal_combobox' EMC_MDIHistory needs an icon named 'widget-gladevcp-vcp_mdihistory' HAL_SpinButton needs an icon named 'widget-gladevcp-hal_spinbutton' HALIO_HScale needs an icon named 'widget-gladevcp-halio_hscale' HAL_VScale needs an icon named 'widget-gladevcp-hal_vscale' HAL_Table needs an icon named 'widget-gladevcp-hal_table' State_Sensitive_Table needs an icon named 'widget-gladevcp-state_sensitive_table' HAL_HideTable needs an icon named 'widget-gladevcp-hal_hidetable'
Wow, that's a pile off errors but glade did open in it's own window. I will start looking for the problem but will appreciate any hints on where to look.
10 years 7 months ago - 10 years 7 months ago #72230 by cncnoob1979
Hey! Islander261 and newbynobi,
Here is the contents of my usr/local/lib/pkgconfig/gladeui-1.0.pc
prefix=/usr/local exec_prefix=${prefix} libdir=${exec_prefix}/lib datarootdir=${prefix}/share datadir=${datarootdir} includedir=${prefix}/include/libgladeui-1.0 catalogdir=${datarootdir}/glade3/catalogs pixmapdir=${datarootdir}/glade3/pixmaps moduledir=${exec_prefix}/lib/glade3/modules Name: Glade Description: Glade interface designer library URL: http://glade.gnome.org Version: 3.8.5 Requires: gtk+-2.0 >= 2.14.0 libxml-2.0 >= 2.4.0 Libs: -L${libdir} -lgladeui-1 Cflags: -I${includedir}
I believe this is the config of the program. I checked it and seems that I have the exact same error as islander does.
Perhaps you have something different? Im running LMDE 2 now... just reinstalled.
Seems to me that we don't have the libs for the HAL containers..
newbynobi,
can you please tell me what files you have under your /usr/local/lib/glade3/modules/ folder? I have a total of 4 files in that directory.
I followed the install direction on that website exactly...
EDIT: newbynobi, Did you install [move the downloaded hal widgets] on a fresh install of glade?
EDIT: I am currently reading the Manual here:
developer.gnome.org/gladeui/3.8/index.html
Hopefully I can figure this out...looks like we are just missing something.... it finds the components as you can see in the error message.
The Glade palette and other components use icons to represent the various widget classes. It is a good idea to provide icons for your widget classes, as this enhances the user interface.
Glade uses the GTK+ GtkIconTheme facility to provide icons for widget classes. Any icon available in the current icon theme can be used as an icon for a widget class.
By default, an icon name of the format "widget-CATALOG_NAME-GENERIC_NAME" is assigned to every widget class. CATALOG_NAME is the value of catalog name attribute, and GENERIC_NAME is the value of an widget class's generic name attribute.
To explicity set an icon name for a widget class, the "icon-name" attribute of the "glade-widget-class" element can be specified. This will override the default icon name assigned to the widget class.
Icon files can be installed under any system icon theme folder.
Last edit: 10 years 7 months ago by cncnoob1979.
10 years 7 months ago #72295 by newbynobi
@John,
i have the same infos, if I do start from terminal, but all is working fine.
So do not care about the warning stuff.
Norbert
10 years 7 months ago #72296 by newbynobi
@cncnoob1979
here is a screenshot.
Norbert
Time to create page: 0.123 seconds
