is anyone having issues installing Teamviewer with this kernel? I'm running vanilla Jessie with the RT-PREEMPT kernel install right on top of lxde. Everyting installs fine and I can run LinuxCNC but when I try to install Teamviewer so I can get some support and help, I get the following error. I'm running:
Linux cnc 3.18.13-rt10mah+ #3 SMP PREEMPT RT Sat Jun 20 00:51:55 CEST 2015 x86_64 GNU/Linux
root@cnc:/home/chris/Downloads# dpkg -i teamviewer_11.0.57095_i386.deb
(Reading database ... 126307 files and directories currently installed.)
Preparing to unpack teamviewer_11.0.57095_i386.deb ...
/opt/teamviewer/tv_bin/script/tvw_main: line 145: /opt/teamviewer/tv_bin/wine/bin/wineserver: cannot execute binary file: Exec format error
Removed symlink /etc/systemd/system/multi-user.target.wants/teamviewerd.service.
Unpacking teamviewer (11.0.57095) over (11.0.57095) ...
Setting up teamviewer (11.0.57095) ...
Job for teamviewerd.service failed. See 'systemctl status teamviewerd.service' and 'journalctl -xn' for details.
Processing triggers for menu (2.1.47) ...
root@cnc:/home/chris/Downloads# systemctl status teamviewerd.service
● teamviewerd.service - TeamViewer remote control daemon
Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled)
Active: failed (Result: exit-code) since Wed 2016-04-27 17:39:59 EDT; 3min 33s ago
Process: 1975 ExecStart=/opt/teamviewer/tv_bin/teamviewerd -d (code=exited, status=203/EXEC)
Apr 27 17:39:59 cnc systemd[1975]: Failed at step EXEC spawning /opt/teamviewer/tv_bin/teamviewerd: Exec format error
Apr 27 17:39:59 cnc systemd[1]: teamviewerd.service: control process exited, code=exited status=203
Apr 27 17:39:59 cnc systemd[1]: Failed to start TeamViewer remote control daemon.
Apr 27 17:39:59 cnc systemd[1]: Unit teamviewerd.service entered failed state.
