LinuxCNC for possible use with G540/X-Carve
  • netfoot
  • netfoot's Avatar Topic Author
  • New Member
  • New Member
27 Jan 2016 01:13 #69142 by netfoot
Replied by netfoot on topic LinuxCNC for possible use with G540/X-Carve
OK, as suggested, after beginning the latency test, I started eight instances of GLXGears, began steaming a video off the net, also set a webcam to send video out to another computer, downloaded 16 GBytes of data, accessed the HD constantly, switched back and forth between four desktops and a dozen or so windows and kept moving them around, and generally "used" the machine. Oh, and I did a system update. After about 10 minutes, the jitter numbers were: 4778 and 5310. From what I can gather, those numbers are acceptable.
Honestly, I don't expect to use the machine for very much other than running LinuxCNC itself, but that might involve reading G-Code off an NFS mounted filesystem, and it might involve streaming a video of progress to another system on the LAN. And there is every possibility I might want to pop open a browser and look something up or check for something online.
27 Jan 2016 07:22 #69148 by ArcEye
Replied by ArcEye on topic LinuxCNC for possible use with G540/X-Carve
Looks like a very suitable candidate for software stepping.
I would suggest you take up the offer of the configuration already in use by another user and once you are running can tweak and 'personalise' as you wish.
27 Jan 2016 08:41 #69149 by geoffs
Replied by geoffs on topic LinuxCNC for possible use with G540/X-Carve
My latency figures are around the 12000 mark and (so far) I've had no problems with anything I've tried to cut on the X-Carve.
Stepconf tells me the step rate is just over 40,000 steps/sec. (does that mean per axis or is it a total?)
27 Jan 2016 10:10 #69150 by ArcEye
I haven't seen that, but then have not used stepconf for a long time.
The max number of steps is decided by the frequency of the thread and the step type.
Type 0 can run one step per 2 polls of make_pulses, maximum.
What is the BASE_THREAD = figure in your .ini file? ( [EMCMOT] section )
27 Jan 2016 10:46 - 27 Jan 2016 10:47 #69151 by geoffs
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 35283
SERVO_PERIOD = 1000000
Last edit: 27 Jan 2016 10:47 by geoffs.
27 Jan 2016 11:24 - 27 Jan 2016 11:25 #69152 by ArcEye
You can use the spreadsheet here work out your figures for yourself
www.linuxcnc.org/docs/devel/html/motion/...rs.html#_no_guessing
Need your stepper driver timings in addition to the max jitter figure.
You might be able to get your base-thread figure down near 30,000 depends upon the other factors, but if it runs OK and does not miss any steps, I would leave it alone B)
The figure is a total, the number of signals stepgen emits is not reliant upon how many axes are specified, all it does is shift a bit pin value for each axis, if that axis position_fb is less than position_cmd.
The stepper driver uses this to generate the actual step, so the timings of the driver are often a limiting factor.
Last edit: 27 Jan 2016 11:25 by ArcEye.
The following user(s) said Thank You: geoffs
27 Jan 2016 11:46 - 27 Jan 2016 11:47 #69153 by geoffs
I'm all for leaving things that work, alone :)
Not sure where this info is (.stepconf?) so here are all the config files for my setup.
Last edit: 27 Jan 2016 11:47 by geoffs.
27 Jan 2016 12:22 - 27 Jan 2016 12:28 #69154 by ArcEye
From xyz-carve.stepconf
<property name="dirhold" type="float" value="700.0"/>
  <property name="dirsetup" type="float" value="700.0"/>
<property name="stepspace" type="float" value="2500.0"/>
  <property name="steptime" type="float" value="2500.0"/>
<property name="latency" type="float" value="16000.0"/>
Those are the figures it is working with
Note however that the xyz-carve.hal file does not use the step timings just leaves them to be set by the thread speed, this is quite normal.
The dirhold and the dirsetup are longer than the figures you provided
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 16700
setp stepgen.0.dirsetup 16700
Last edit: 27 Jan 2016 12:28 by ArcEye.
27 Jan 2016 13:41 #69155 by geoffs
All parameters were created by stepconf, I don't yet know enough to manually tweak things.
27 Jan 2016 14:03 #69157 by ArcEye
The ones in the top box were entered by you, you just need to be sure those are correct and in the correct base
Manufacturers sometimes use nanoseconds, sometimes microseconds and sometimes a mix
www.geckodrive.com/geckodrive-step-motor-drives/g540.html
If it works, I should leave it, the main values are the step ones and those are taken care of by stepconf using thread length.
The dirsetup etc might be able to be tweaked at bit, they do appear to be 8x higher than the Gecko spec sheet and over twice what you input.
You can try manually editing the hal and ini files when you are happy doing it.
Time to create page: 0.119 seconds
