Fatal Errors Installing on Parallels.
10 years 8 months ago #69934 by ned7
Replied by ned7 on topic Fatal Errors Installing on Parallels.
Have upped the VM's RAM to 2G (my usual allocation for a VM) from 768M. No effect.
Updated to 2.7.4. No effect.
Debug file information:
/usr/bin/linuxcnc: line 857: 9415 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
10 years 8 months ago #69937 by ned7
Parallels doesn't offer much to tweak for the display.
Increased display memory from 128M to 256M. No effect.
Turned off 3D acceleration. No effect.
Disabled vertical synchronization. No effect.
Reverted all display parameters to previous values: 128M, 3D acceleration on, vertical sync enabled.
New error log attached.
10 years 8 months ago #69940 by ned7
Installed software-based OpenGL using
sudo apt-get install libgl1-mesa-swx11
No effect. Seg error at the same line number.
10 years 8 months ago #69949 by ned7
I've put a fair amount of time and effort into this without success.
Andy mentioned that he runs LinuxCNC axis sim on VMWare Fusion. I can take a hint. Right now I'm using a trial of Fusion, but I will definitely be buying it. Remains to be seen whether I replace Parallels (which is excellent, other than this one problem) or run both.
If anyone gets LinuxCNC axis running on Parallels, I'd like to know about it. If you're just trying to get it running, use Fusion.
10 years 8 months ago - 10 years 8 months ago #69950 by Amedee
Replied by Amedee on topic Fatal Errors Installing on Parallels.
Out of curiosity, I tried the 2.7 Live CD with VirtualBox on my old Mac, and it runs without problem (With default settings, that is only 12MB video memory and no video acceleration).
From your log file:
[ 52.427574] axis[3824]: segfault at 9e62000 ip b768d421 sp bfee7ea8 error 6 in libc-2.13.so[b7572000+15e000]
Is very strange because it is the python executable crashing in libc -- that does not happen very often.
Does it generates a 'core' somewhere? that would allows us to get at stack trace...
Last edit: 10 years 8 months ago by Amedee.
10 years 8 months ago #69971 by ned7
I haven't solved the problem, but I've got where I wanted to go by using Fusion instead.
If you want to pursue the error, I will help. I threw away the Parallels VM, but I am sure I can reproduce the error. How do I get you the core ?
Time to create page: 0.271 seconds
