replacement of GEDIT with Mousepad
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Jun 2016 18:51 #75456 by RotarySMP
replacement of GEDIT with Mousepad was created by RotarySMP
I have installed 2.7.0, from the live dis image, and it looks like GEDIT was replaced with MOUSEPAD.
In the machine INI, in the [DISPLAY] section I added
EDITOR = mousepad
but the edit button in LINUXCNC still doesn't work.
Any advise please?
Mark
04 Jun 2016 04:25 #75478 by cmorley
Replied by cmorley on topic replacement of GEDIT with Mousepad
You could download gedit.
Which screen are you using?
Chris M
  • RotarySMP
  • Platinum Member
  • Platinum Member
04 Jun 2016 12:06 #75482 by RotarySMP
Replied by RotarySMP on topic replacement of GEDIT with Mousepad
Thanks Chris,
I don't have the lathe controller connected to a net work, at present. Shouldn't mousepad work just the same? If GEDIT is necessary, I'll drap the conrtoller, monitor and keyboard up the office and hang it on a LAN cable.
Mark
04 Jun 2016 15:24 #75491 by andypugh
Replied by andypugh on topic replacement of GEDIT with Mousepad
It should allow you to edit G-code just the same, yes. But it doesn't do syntax-highlighting, or let you open more than one file at a time, and is hideous otherwise in too many ways to enumerate.
I strongly recommend installing gedit. :-)
05 Jun 2016 07:28 - 05 Jun 2016 07:37 #75517 by Rick G
Replied by Rick G on topic replacement of GEDIT with Mousepad
Did you comment out or delete the
EDITOR                  = gedit
or any other EDITOR = line?
and then add
EDITOR                  = mousepad
Works fine here, also double check your spelling and Caps
EDITOR                  = mousepad
should work
but
EDITOR                  = Mousepad
will not.
Rick G
Last edit: 05 Jun 2016 07:37 by Rick G.
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 Jun 2016 07:09 #75541 by RotarySMP
Thanks Rick and Andy
I had replaced "gedit" with "mousepad". I checked, and hadn't used a capital M.
I'll load the current 2.7.4 (as I have a 2.7.0 image at present. I'll add gedit at the same time.
Mark
06 Jun 2016 09:24 #75546 by andypugh
I wouldn't bother reinstalling, just update LinuxCNC and install gedit from the Synaptic package manager.
  • RotarySMP
  • Platinum Member
  • Platinum Member
06 Jun 2016 19:03 #75573 by RotarySMP
I hung this computor on a Lan cable, and updated to 2.7.4. Thanks, for the suggestion, as that went really easy.
I also had a problem that could access SUDO through programs like the update manager, but it wouldn#t accept my password for SUDO through the terminal. Solved that by booting to recovery root and adding this profile to SUDO.
I still can't install Gedit though. I tried both apt-get...
boley@Boley-4LV:~$ sudo apt-get install gedit
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package gedit
and aptitude...
boley@Boley-4LV:~$ sudo aptitude install gedit
Couldn't find any package whose name or description matched "gedit"
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Sorry to bug with Linux Newbie ignorance.
Mark
06 Jun 2016 20:43 #75586 by andypugh
That's a surprise. Is there any sign of it if you open Synaptic and do a search?
06 Jun 2016 23:24 - 11 Jun 2016 11:09 #75599 by BigJohnT
Replied by BigJohnT on topic replacement of GEDIT with Mousepad
To install gedit in a terminal do:
sudo apt-get install -y gedit/trusty gedit-common/trusty gedit-plugins/trusty
Hmm, that may only work on Ubuntu based distros like LinuxMint...
Or do like Andy said and open the Synaptic Package Manager and type gedit in the search box.
Edit: fix typo in command
JT
Last edit: 11 Jun 2016 11:09 by BigJohnT.
Time to create page: 0.202 seconds
