Netmos 9865 pci parallel port help
10 years 4 months ago #76270 by tommylight
Make the timings longer and also the base thread.
That will smooth the drives.
Regards,
Tom
10 years 4 months ago #76271 by andypugh
tommylight wrote: Make the timings longer and also the base thread.
I don't think this is true.
10 years 4 months ago #76295 by tommylight
It actually is for chinese drives. Cheap drives use slow optocouplers that tend to be very picky for timing and also very slow to react.
The drive power set low can do that same choppy movement, but that can be checked by lowering the machine velocity.
Regards,
Tom
10 years 4 months ago #76296 by tommylight
I am sorry Andy, i just read my post again and it says "drives", i meant motors.
10 years 4 months ago #76710 by chadrat6458
What is a good starting point for max_acceleration and max_velocity? Thanks.
10 years 4 months ago - 10 years 4 months ago #76712 by Todd Zuercher
That depends, how heavy are the moving parts, how powerful are the motors, gear reduction?
These are the settings I have on an old Digitaltool CNC router, 20 inches/sec^2 acceleration rate and 10 inches/sec (600ipm).
But what will work best for your machine will depend on your machine.
For the most part you will want to set the acceleration as high as you can without loosing steps even at the highest speed you will use, minus a safety margin.
Last edit: 10 years 4 months ago by Todd Zuercher.
Time to create page: 0.148 seconds
