Netmos 9865 pci parallel port help
- chadrat6458
10 Jun 2016 02:45 #75744
by chadrat6458
Netmos 9865 pci parallel port help was created by chadrat6458
New to linux. I can't seem to get my machine to move in the stepperconf or linuxcnc. I think I have the latest version installed. Attached is my lspci and hal file. I have an openbuilds ox machine. It has 2 y axis steppers. No limit or homing switches yet. I have the Netmos 9865 single port pci card.
Thanks.
Thanks.
10 Jun 2016 09:28 #75750
Replied by andypugh on topic Netmos 9865 pci parallel port help
It looks like parport_pc has found the parallel port, so rather than using cfg="0x1008 out" you could try "0 out" and let the system worry about the actual memory addresses.
However, it may be that the parallel port is working fine, but the drives are not being enabled.
Do the motor shafts turn by hand when the system is powered off? Do they still turn by hand with the system powered up? How about when LinuxCNC is turned on? I don't see any outputs in the HAL to enable the stepper drives (and that is often perfectly OK) but it would be useful to know that the drives are being enabled before looking at parport problems.
- chadrat6458
10 Jun 2016 22:42 #75792
by chadrat6458
Replied by chadrat6458 on topic Netmos 9865 pci parallel port help
They are locked.
O out does not make a difference.
Keling 4030 drivers. C10 bob
11 Jun 2016 10:22 #75810
So, it looks like the drives are enabled. I think the next thing to check is if the parallel port is working.
Do you have any inputs wired up the BoB? You can observe those in the "Watch" tab of halshow. (In Axis you can get to that from Machine->Show HAL Config, otherwise open a terminal window and type "halcmd loadusr halshow"
If you can see the state of some parallel port pins change when you toggle input pins then that indicates that the parallel port is configured and working. If you can't see that it doesn't necessarily mean that it isn't, though.
It might be worth switching the polarity of the step pulses, that is a check-box next to the pin in Stepconf.
- joe
11 Jun 2016 14:20 - 11 Jun 2016 14:21 #75818
by joe
Replied by joe on topic Netmos 9865 pci parallel port help
That's my configuration too - C10 with 3x4030s. I got lazy and plugged both y into one driver instead of trying to configure the slave axis.
It's been a couple of years but I remember having the same problems at first - motors locked when I powered the board, but couldn't talk to it with the computer. I think it turned out to be my wiring between the driver and the motors was off, or I'd messed up one of the (2?) pull up/down switches on the C10. If you want to post a pic or description of how you've wired it, I'll take it out to the workshop and open mine up for comparison.
Last edit: 11 Jun 2016 14:21 by joe. Reason: changed machine to computer.
- chadrat6458
12 Jun 2016 02:47 #75842
by chadrat6458
- chadrat6458
12 Jun 2016 02:48 #75843
by chadrat6458
- joe
12 Jun 2016 03:32 #75844
by joe
Looks good:
In the interior square part of your board, there are three jumpers spaced out in a row.
The far right one is pullup/down for 2-9 and it shold be on 1-2(pulldown). It looks right in the pic
The middle one decides if you're using 2-9 for input or output. It should be 1-2output, looks right in the pic.
The far left one controls the other ports, which are used for input (probes/limit switches/estop etc). It's set to pulldown on mine.
Looks different:
In your pic - upper right corner is a jumper that sets the COM ports to 5V or ground. It should be 5V. It looks like you've got it set to ground? On mine it's set to 5V and it takes the 5V input on the bottom left of your board and sends it to each 4030 (from the COM to the DIR+, and then the DIR+ and PUL+ are jumpered together on the board.)
Looks different:
- chadrat6458
12 Jun 2016 18:46 #75868
by chadrat6458
Switched the jumper now getting a RTAPI error.
- joe
12 Jun 2016 19:04 #75869
by joe
That's a different problem. Did you run a latency test?
Time to create page: 0.182 seconds
