Netmos 9865 pci parallel port help
17 Jun 2016 11:29 #76206
That message is information only. It's a concern, but won't stop the machine running.
Have you taken Axis out of e-stop and turned it on? (top left pair of buttons, or F1 then F2)
If the motors turn freely when Axis in on, and there is no movement in Axis then this may well be the amp-enable signals (though the wiring diagram shows the amp-enables of the drives unconnected. The stepconf axis test does not toggle the amp-enable signals, but the final configuration produced does (but of course, this can only have any effect if the enables are wired up)
The wiring diagram suggests that the amp-enables are 5V for on (or disconnected for on), ie apply 0V to ENA- to turn off the drive.
Replied by andypugh on topic Netmos 9865 pci parallel port help
Getting an Unexpected Realtime Delay message in axis. No motor movement.
- chadrat6458
17 Jun 2016 12:19 #76211
by chadrat6458
Replied by chadrat6458 on topic Netmos 9865 pci parallel port help
I did not take Axis out of e-stop or turned it on. I will try it. Thanks.
- chadrat6458
18 Jun 2016 03:30 #76238
by chadrat6458
taking Axis out of e-stop or turning it on worked!
Just need to tweak my settings. I have it microstep set to 8. I thinking going down to 4 for x and y. X and Y seem a little choppy. Any ideas on how to smooth them out?
Thanks!
Thanks!
18 Jun 2016 10:19 #76249
You could try lower acceleration numbers.
- Thank you received: 7490
18 Jun 2016 22:26 #76270
Replied by tommylight on topic Netmos 9865 pci parallel port help
Make the timings longer and also the base thread.
That will smooth the drives.
Regards,
Tom
Regards,
Tom
18 Jun 2016 23:30 #76271
I don't think this is true.
19 Jun 2016 23:20 #76295
It actually is for chinese drives. Cheap drives use slow optocouplers that tend to be very picky for timing and also very slow to react.
The drive power set low can do that same choppy movement, but that can be checked by lowering the machine velocity.
Regards,
Tom
Regards,
Tom
19 Jun 2016 23:22 #76296
I am sorry Andy, i just read my post again and it says "drives", i meant motors.
- chadrat6458
27 Jun 2016 15:24 #76710
by chadrat6458
What is a good starting point for max_acceleration and max_velocity? Thanks.
- Thank you received: 1480
27 Jun 2016 15:34 - 27 Jun 2016 15:38 #76712
Replied by Todd Zuercher on topic Netmos 9865 pci parallel port help
That depends, how heavy are the moving parts, how powerful are the motors, gear reduction?
These are the settings I have on an old Digitaltool CNC router, 20 inches/sec^2 acceleration rate and 10 inches/sec (600ipm).
But what will work best for your machine will depend on your machine.
For the most part you will want to set the acceleration as high as you can without loosing steps even at the highest speed you will use, minus a safety margin.
Last edit: 27 Jun 2016 15:38 by Todd Zuercher.
Time to create page: 0.156 seconds
