Netmos 9865 pci parallel port help
15 Jun 2016 13:46 #76075
Hang on, you have already proved that the parallel port is working. Switching parallel ports now just takes you right back to the beginning.
You should definitely be able to see the direction pin changing state with a voltmeter at this point.
Replied by andypugh on topic Netmos 9865 pci parallel port help
None of that worked. I am tired of messing with the pci card. I am looking for a Dell with a built in parallel port.
- chadrat6458
15 Jun 2016 14:32 #76081
by chadrat6458
Replied by chadrat6458 on topic Netmos 9865 pci parallel port help
not sure what to check next.
15 Jun 2016 14:35 #76083
As a starting point, can you see the direction pin changing voltage, with a voltmeter, when you jog left then right?
- chadrat6458
15 Jun 2016 14:39 #76084
by chadrat6458
I will try it.
so multimeter the x dir pin, y dir pin and z dir pin?
15 Jun 2016 14:52 #76087
Yes, and see if they match what HAL says it is doing with the pins.
Follow the signals from BoB input to BoB output to the drives.
- chadrat6458
15 Jun 2016 15:07 #76089
by chadrat6458
How do I check BoB input?
15 Jun 2016 15:31 #76096
Maybe on the back of the PCB if you can't see any exposed pins on the top.
- Thank you received: 1480
15 Jun 2016 15:35 #76097
Replied by Todd Zuercher on topic Netmos 9865 pci parallel port help
You kind of already have tested one of them pin 10 with your e-stop.
Depending whether you have them configured for pull up or pull down, connect them to ground or 5v, and watch for the indicator to change in Linuxcnc.
- chadrat6458
15 Jun 2016 15:50 #76100
by chadrat6458
They are set up for pull up.
15 Jun 2016 17:02 #76108
Then you would connect them to ground.
Something else you might be able to try, is connecting a wire from your step/dir output pins to input pins (disconnect them from the drive first). Then check to see if you can see the input being triggered by the output in Linuxcnc.
Time to create page: 0.403 seconds
