RTL8111 Wired network connection setup?
- gismofx
29 Sep 2016 20:03 #81085
by gismofx
RTL8111 Wired network connection setup? was created by gismofx
Can a moderator move this thread here:
forum.linuxcnc.org/forum/pathpilot/30880...ards-and-cards#81068
Also, I'm having some trouble setting up a wired Ethernet connection with the realtek RTL8111 network port. Anyone have any tips on how to setup properly? Can we get this driver put into the Linux CNC iso?
- Thank you received: 5334
29 Sep 2016 20:09 #81086
Replied by PCW on topic RTL8111 Wired network connection setup?
Did you try the latest LinuxCNC ISO (Wheezy)
- gismofx
29 Sep 2016 20:15 #81087
by gismofx
I have the latest stable version. I grabbed it last week.
Replied by gismofx on topic RTL8111 Wired network connection setup?
30 Sep 2016 00:47 - 30 Sep 2016 00:48 #81091
I just tried the LinuxCNC Wheezy ISO distribution (with RTAI kernel) on a Motherboard
with a RTL8111 ( A intel D510) , and it seems ok
I did not test extensively but ping works, large file copies are OK, and a ssh session was fine
(no trouble in about 10 minutes of normal network stuff)
Heres the dmesg info
1.650555] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.651290] r8169 0000:01:00.0: eth0: RTL8168d/8111d at 0xf8010000, 38:60:77:
1a:b9:9a, XID 081000c0 IRQ 16
[ 1.651308] r8169 0000:01:00.0: eth0: jumbo features [frames: 9200 bytes, tx
checksumming: ko]
and lspci
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI E
xpress Gigabit Ethernet controller (rev 03)
What specific problem do you have with the RTL8111 on Wheezy?
checksumming: ko]
and lspci
Last edit: 30 Sep 2016 00:48 by PCW.
- gismofx
30 Sep 2016 01:20 - 30 Sep 2016 02:27 #81093
by gismofx
I'm using
this mobo
I have no problems during install and it seems to to actually connect to the internet during the installation when it goes through the Ethernet configuration, but when it boot up, it seems to use the R8169 driver. I get no connection to the internet, no IP. I tried to install the latest RTL8111 driver from realtek's site and followed their readme file and I get no errors during install. Again, I get no connection. I've tried multiple ports on the router and multiple cables to rule that out. Also, oddly, my router shows this computer as a connected device.
I am currently trying Ubuntu Precise, but that doesn't seem to install...
I just did a fresh install: Here's the output:
Link is not ready? Link down? How can I correct that?
dmesg | grep eth
[ 1.495278] r8169 0000:01:00.0: eth0: RTL8168b/8111b at 0xf801c000, f4:4d:30:08:ed:e1, XID 0c000800 IRQ 28
[ 1.495285] r8169 0000:01:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 10.868324] r8169 0000:01:00.0: eth0: link down
[ 10.868552] ADDRCONF(NETDEV_UP): eth0: link is not ready
lspci
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 0c)
Subsystem: Elitegroup Computer Systems Device 8116
Flags: bus master, fast devsel, latency 0, IRQ 28
I/O ports at e000 [size=256]
Memory at fea00000 (64-bit, non-prefetchable) [size=4K]
Memory at d0800000 (64-bit, prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: r8169Link is not ready? Link down? How can I correct that?
Last edit: 30 Sep 2016 02:27 by gismofx.
- Thank you received: 4151
30 Sep 2016 12:41 #81102
Replied by rodw on topic RTL8111 Wired network connection setup?
I would be checking the physical network connection. "Link Down" reported on my Netgear smart switch means there is no connection. I recently had problems with a Zebra label printer that refused to connect to the network. The problem was that it could not auto negotiate a connection on a Gigabit switch. The solution was to configure a port on the switch at a lower speed or use a 10/100 switch. Eventually the link came up on a 10 mb full duplex setting and the printer was happy. Lucky ZPL label formats are usually just a few lines.
Oh and don't do what I did and plug the printer into the patch panel and not the actual switch!
- gismofx
30 Sep 2016 13:11 #81104
by gismofx
I've tried multiple ports and cables. I don't think my current router will allow manipulation of the port speed(unless I load DD-WRT firmware). The port on the mobo lights lights up when I plug in and even in the router control panel it shows "Debian" as a connected device.
30 Sep 2016 13:58 #81108
Did you try manually setting up the link?
Does it work with any OS? maybe you just have bad hardware
- gismofx
30 Sep 2016 16:33 #81112
by gismofx
Possibly, but it seems to connect when it installs because when I boot, it knows there updates to be installed.
I don't know how to manually set up the link. I need some assistance with the correct commands to do so.
- gismofx
04 Oct 2016 02:09 #81201
by gismofx
I just tried a the latest version of debian and internet works out of the box. Is there a way to the ethernet work on the LinuxCNC distro?
Time to create page: 0.121 seconds
