RTL8111 Wired network connection setup?
- Thank you received: 1480
04 Oct 2016 04:14 #81203
Replied by Todd Zuercher on topic RTL8111 Wired network connection setup?
What version of Debian were you able to get the ethernet to work? If it is Jessie, it isn't hard to install Linuxcnc on it using Preempt-Rt and Buildbot
- gismofx
04 Oct 2016 10:55 #81210
by gismofx
I tried: "debian-live-8.6.0-i386-xfce-desktop" I'm happy to try some alternatives distros if necessary. Is XCFE preferred for LinuxCNC? Can you explain step-by-step how to install LinuxCNC or provide a link?
Replied by gismofx on topic RTL8111 Wired network connection setup?
04 Oct 2016 14:23 #81212
The first thing you need to do is install a Preempt-RT patched kernel (or apply the patch yourself). The last time I installed Jessie, a Preempt-RT kernel was available to install pre-compiled from Debian Backports using Synaptic. It appears to no longer be available there.
04 Oct 2016 20:29 #81231
I just installed a Preemt-RT patched Kernal from the Debian archive site add the repository.
deb snapshot-sibelius.debian.org/archive/debian/20160810T050046Z/ jessie-backports main
Then close synaptic and at a command prompt typeThis will let you use Synaptic to install from the old snapshot archives.
Then reopen Synaptic and install
linux-headers-rt-686-pae
after that is installed install
linux-image-rt-6860-pae.
Then reboot into the new kernel, and follow the instructions for installing Linuxcnc from buildbot for the preempt-rt.
sudo apt-get -o Acquire::Check-Valid-Until=false updateThen reopen Synaptic and install
- gismofx
04 Oct 2016 22:32 #81236
by gismofx
Thanks! I'm new to Linux so I don't know all the commands to comfortably make this happen. Would these instructions work?: forum.linuxcnc.org/forum/9-installing-li...ssie-and-linuxcnc2-7
05 Oct 2016 01:13 #81241
Yes except for the real time kernel installation, because they are not currently available in jessie-backports. For some reason the real time patched kernels seem to appear and disappear every few months. I've heard some speculate it is because of pending version upgrades, but I don't understand why the old has to be removed so long before the new is released; (They could easily overlap for a period of time.)
