Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
9 years 4 months ago #95121 by PKM
What exactly did you do after issuing "../debian/configure uspace ; debuild -uc -us"?
9 years 4 months ago #95133 by Gommiswald
9 years 4 months ago #95137 by PKM
OK, so the debs were created but you haven't installed anything.
Just go to the home folder and find linuxcnc-uspace_2.8.0... .deb, double click it and choose Install.
You might want to install the docs too.
9 years 4 months ago #95140 by Gommiswald
Hi
Now it works. I had to go to my personal folder and unpack the linuxcnc-uspace-2.8.0.... package. And then I made it like cncnoob1979 in the blue notice. Very fine, but it lasted a long time to do everything.
Thanks for your help! It is great to have such a forum!
Greetings from Switzerland
Daniel
9 years 4 months ago #95141 by Gommiswald
Thanks - I think, that our posts did crossing...
9 years 4 months ago #95180 by chrisrusk
Hi everyone, I've run into bit of an problem trying to use this guide to install Linuxcnc on Ubuntu Gnome 16.04. I first tried the install on 64bit, then switched to 32bit in case that was the issue.
I am following post 2 and I manage to install everything without any errors, until I start up linuxcnc. Running it from the command line and choosing the standard axis sample configuration, I get this output:
chris@chris-desktop:~$ linuxcnc LINUXCNC - 2.8.0~pre1 Machine configuration directory is '/home/chris/linuxcnc/configs/sim.axis-1' Machine configuration file is 'axis.ini' Starting LinuxCNC... Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal Note: Using POSIX realtime Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal Found file(lib): /usr/share/linuxcnc/hallib/check_xyz_constraints.hal note: MAXV max: 5.000 units/sec 300.000 units/min note: LJOG max: 5.000 units/sec 300.000 units/min note: LJOG default: 0.250 units/sec 15.000 units/min waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> USRMOT: ERROR: command timeout waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> waiting for s.joints<0>, s.kinematics_type<0> Waiting for component 'inihal' to become ready.USRMOT: ERROR: command timeout ..........USRMOT: ERROR: command timeout ..waiting for s.joints<0>, s.kinematics_type<0> ........USRMOT: ERROR: command timeout ..................A configuration error is preventing LinuxCNC from starting. More information may be available when running from a terminal. Shutting down and cleaning up LinuxCNC... ..USRMOT: ERROR: command timeout .........USRMOT: ERROR: command timeout ..........USRMOT: ERROR: command timeout ....... <commandline>:0: milltask exited without becoming ready Note: Using POSIX realtime LinuxCNC terminated with an error. You can find more information in the log: /home/chris/linuxcnc_debug.txt and /home/chris/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal chris@chris-desktop:~$
Linuxcnc starts and shows the splash screen, and then crashes. I tried tklinuxcnc as well, in case it was a graphics issue, but that had the same result.
This is my linuxcnc print file:
RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 INIFILE=/home/chris/linuxcnc/configs/sim.axis-1/axis.ini VERSION=1.0 PARAMETER_FILE=sim.var TASK=milltask HALUI=halui DISPLAY=axis COORDINATES=X Y Z KINEMATICS=trivkins Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Starting TASK program: milltask Starting DISPLAY program: axis Killing task linuxcncsvr, PID=3176 Killing task milltask, PID=3220 Timeout, trying kill -9 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments
This is my linuxcnc debug file:
3659 PID TTY STAT TIME COMMAND 3707 PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 R+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 R+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND 3707 pts/1 S+ 0:00 milltask -ini /home/chris/linuxcnc/configs/sim.axis-1/axis.ini PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components
Another thing to note is that Latency test gives no output, it runs fine, however, all values remain at zero.
Any help with the matter would be greatly appreciated. I would prefer to get this running using Ubuntu Gnome, seeing as i am using a 22 inch touch screen and would prefer the interface of Gnome.
Thanks, Chris.
Time to create page: 0.391 seconds
