Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
8 years 10 months ago - 8 years 10 months ago #103406 by cncnoob1979
I think you are confusing kernel version patches with RT patches. A kernel version patch is different from RT patches.
You will need to download a kernel that you want to use ;
4.14.6 and older
Also you have to download a RT Patch that matches the kernel version number.
4.14.6-rt7 and older (the rt7 means real time ; revision 7) you match the base version of the kernel. Meaning you can use
4.14.6-rt6
4.14.6-rt5
4.14.6-rt4
ect...
I hope i'm not confusing you.
The RT-7 patch
www.kernel.org/pub/linux/kernel/projects...-4.14.6-rt7.patch.gz
The matching Kernel version
www.kernel.org/pub/linux/kernel/v4.x/linux-4.14.6.tar.xz
Last edit: 8 years 10 months ago by cncnoob1979.
8 years 10 months ago #103408 by megaplow
I went with Linux Mint 18.3... Things seem to we working, but I missed that you started with 18.1. There is no need for me to be on the latest greatest. If 18.3 wont work, I can go back and do an 18.1 instal with the 4.9.68 kernel and rt patch.
Whaddia think?
8 years 10 months ago #103411 by cncnoob1979
All distro's are about the same and you should be just fine on 18.3
8 years 10 months ago #103459 by megaplow
I am getting through most of the process a successfully, then the operation fails when the disk is full.
ld: final link failed: sound/pci/vx222/snd-vx222.ko: final close failed: No space left on device
Is it possible to run all these commands in a different location than the home folder?
8 years 10 months ago #103462 by andypugh
I don't think that the problem is where you are running the commands.
How big is the disc?
You might need to (possibly temporarily) remove some stuff to make space.
8 years 10 months ago #103463 by megaplow
I am running on a Minix NEO-ZZ83-4 Pro. It is a fanless all in one machine with a 30g hard drive. I am using a fresh install on linux mint. There is nothing else on the machine. I guess I could delete all the pre installed apps I don't need and try again. I have a 64 gig expansion disk, but I am not sure if using that space for the build process is a good idea.
Time to create page: 0.087 seconds
