Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
8 years 4 months ago #111452 by AGK
I want to do that: wiki.linuxcnc.org/cgi-bin/wiki.pl?Translation
I think I have done this:
sudo sudo apt-get install git-core git-gui gitk
git config --global user.name "Your full name"
git config --global user.email "you@example.com"
And at least the connection check:
git clone git://github.com/zultron/smictrl.git
I had it misunderstood, no new source, only for checking. No new syntax.
And now the connection check well done, but the connection to "git clone git: //git.linuxcnc.org/git/emc2.git linuxcnc-dev" don't work for me?
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago - 8 years 4 months ago #111453 by ozzyrob
AGK wrote: I want to do that: wiki.linuxcnc.org/cgi-bin/wiki.pl?Translation
That is very old and will not work.
This is what you need to use, but you have previously tried and this did not work.
git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
Can you try this and paste the ouput:
GIT_TRACE=2 git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
Last edit: 8 years 4 months ago by ozzyrob.
8 years 4 months ago #111455 by AGK
Here the output, It seems that it work now.
agk@debian:~$ GIT_TRACE=2 git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
trace: built-in: git 'clone' 'git://github.com/linuxcnc/linuxcnc.git' 'linuxcnc-dev'
Cloning into 'linuxcnc-dev'...
trace: run_command: 'index-pack' '--stdin' '-v' '--fix-thin' '--keep=fetch-pack 1701 on debian'
trace: exec: 'git' 'index-pack' '--stdin' '-v' '--fix-thin' '--keep=fetch-pack 1701 on debian'
trace: built-in: git 'index-pack' '--stdin' '-v' '--fix-thin' '--keep=fetch-pack 1701 on debian'
remote: Counting objects: 203281, done.
remote: Compressing objects: 100% (286/286), done.
remote: Total 203281 (delta 338), reused 584 (delta 326), pack-reused 202669
Receiving objects: 100% (203281/203281), 116.82 MiB | 1.84 MiB/s, done.
Resolving deltas: 100% (154990/154990), done.
Checking out files: 100% (5093/5093), done.
agk@debian:~$
  • ozzyrob
  • New Member
  • New Member
8 years 4 months ago #111460 by ozzyrob
8 years 4 months ago #111499 by AGK
Yes it works. Can I see somewhere if individual chapters have already been translated or worked on? Currently I can only see it if I open a de.txt-file and look if the content in German. Exist a easier way to prof this?
8 years 4 months ago #111511 by Sparky961
Grotius wrote: After trying multiple 64 bit installations on ubuntu and mint with compiling different kernels. I found the simple solution over here
iso file debian stretch 64 bit super fast program, super stability, linux and glade pre installed debian 64 bit with linuxcnc
I should have been following this thread earlier, as it is very relevant to what I'm having trouble with as well. I admit I haven't read each post yet but I intend to when I have some spare time.
In reading this one, it got me wondering if there's a different version of Glade that's installed for amd64 than i386.
See this thread for my "journey": forum.linuxcnc.org/41-guis/34646-ui-deve...vironment-setup-help
It's a little fuzzy now with all the different things I've tried since, but I'm sure that I didn't see Glade (at least in the Applications->Development menu) after installing. I installed glade packages and got into trouble with versions, compatibility, and missing libraries. As things stand, I can have either a version with uspace or a working glade development environment but not both.
I've downloaded a few versions of Mint to try next.
Time to create page: 0.250 seconds
