How to downgrade?
  • tecno
  • tecno's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Jul 2017 13:03 #96217 by tecno
How to downgrade? was created by tecno
I just managed to upgrade to 2.7.10 but now my PC is soooooooooooooooooooo slow so I need get back to before upgrade.
How do I do that?
Cheers
Bengt
21 Jul 2017 13:20 #96219 by skunkworks
Replied by skunkworks on topic How to downgrade?
What did you upgrade from?
sam
  • tecno
  • Platinum Member
  • Platinum Member
21 Jul 2017 13:42 - 21 Jul 2017 13:44 #96220 by tecno
Replied by tecno on topic How to downgrade?
2.7.9 the version that handles Ethernet board 7i76E
Restarted and now it more or less locks up the PC
linuxcnc-stretch-uspace-i386-r1.iso
Last edit: 21 Jul 2017 13:44 by tecno.
21 Jul 2017 14:05 #96221 by skunkworks
I really doubt the update caused the issue... (I have been running 2.7.10 for a bit)
Could you run a memtest on it and check your hard drive smart data?
What distro? is it the wheezy livecd? did you just apt-get update/upgrade to get it?
  • tecno
  • Platinum Member
  • Platinum Member
21 Jul 2017 14:08 #96222 by tecno
Live CD + update/upgrade
Leaning towards reinstalling 2.7.9 and see what is going on.
OK, this is not the fastest PC but it did act reasonably on 2.7.9
I get some error message about DMI when starting up
21 Jul 2017 14:10 #96223 by skunkworks
Ah - I see. that is a pretty old iso - the latest is r7 - and is really for testing currently.
www.linuxcnc.org/testing-stretch-amd64-rtpreempt/
What is your computer hardware - debian stretch is the latest released operating system - could it be your hardware cannot handle it? You would have to go back to current wheezy linuxcnc livecd. - if that is what you started with.
A note - you shouldn't install a new iso to upgrade linuxcnc. You should have just updated the linuxcnc version on your existing install.
21 Jul 2017 14:14 #96224 by skunkworks
it isn't 2.7.9 vs 2.7.10 - it is whatever os you started with vs Debian stretch.
IE - it is like running mach3 on windows XP - then installing windows 7 and complaining that mach3 is slow.
  • tecno
  • Platinum Member
  • Platinum Member
21 Jul 2017 14:17 - 21 Jul 2017 14:21 #96225 by tecno
r1 (2.7.9) install to start with and it appeared to work, been away for holiday and now I did update/upgrade to 2.7.10
www.fecpos.com/en-global/ams/Products/view/10
Older model with 2G Celeron
Last edit: 21 Jul 2017 14:21 by tecno.
21 Jul 2017 14:22 #96226 by skunkworks
oh - huh.
Then again - I would be looking at your hardware. I bet there is a memory issue or something...
21 Jul 2017 14:24 #96227 by skunkworks
(we communicate as well as my wife and I... Maybe it is me...)
sam
Time to create page: 0.097 seconds
